Question about Dual XD-7500 CD Player
Power on problem for XD7500
Unit will not power on. Faceplate stays lit even with ignition sw. off. All segments of panel are lit. Power button does nothing. All functions do not work. There is probably a bad circuit component. Anybody know which one?
    Scholar:
  • 98 Answers
Hi. You need to check a few things. make sure you have power on both the red and yellow wire with the key on. If only one has power the radio will not work. If the red and yellow wires are switched it can also affect the way the redio operates. One is constant power for memory the other is key on power so the radio knows to shut off with the ignition key off. also make sure that you have a good ground connection on the black wire.. if nothing works yes you probhably have a bad radio. the dual brand radios are notorious for poor solder connections on the mainboard due to the way they build thier cheap circuit boards..
Posted on Sep 05, 2007
SOURCE:
Plantronics cs50 red power light is not lit
Sorry to hear about your bad luck there. If a hard reset does not work and its not simply the power button is not correctly aligned (try fiddling the pressure up and down if it is loose) then it's likely the device has failed. Even though it's survived other power outages it's still entirely possible the most recent one has caused this failure. I've seen failure of electronics from operating on unstable voltages from solar panels and less than perfect inverter systems and it's always the case that "it's been working fine up until now!"
Mar 01, 2017 | Plantronics Radio Communications
XHDR6435 radio was working fine yesterday, now it will not turn on. the red led behind the faceplate flashed when i turn on the car, and cds will load and eject but the radio will not power up. i habe...
I just Spoke to tech support. This is what they said:
1. Key in the on position and the red power button lit, remove the face plate.
2. On the left bottom side press and hold the reset button, with a pen, for 10 seconds and let go. The red led on the right should flash.
3. Reinstall the face plate.
4. Push power. The unit should come back on.
Mine worked, and i was about to tear it out and return it. So try this first or even call tech support for Dual 1-866-382-5476.
Jun 14, 2011 | Dual Electronics XHDR6435
Dual XD7500 Faceplate Problem
the faceplate has a loose or broken contact on one of the wires on the ribbon wire located in back of where the faceplate mount. the ribbon wire is expensive and you must open the radio and install it. the wire is about 30 bucks plus shipping from the dual company or namsung. you can also find the ribbon wire for sale at ebay.com or parts.com
Jul 16, 2009 | Dual XD-7500 CD Player
Kenwood KDC-X717 - Facplate opens when powered on, stays open. No display.
I've had this problem before. The ribbon cable needs to be replaced. They wear out every few years. Take it in for service. Or do you want to sell it? I need the face plate for mine.
Nov 06, 2008 | Kenwood KDC-X717 CD Player
Detaching faceplate on dual stereo XD 7500
Got to the following lik for your manual: http://www.dualav.com/i/product/manual/xd7500.pdf Refrence page 6 for instructions. With the unit off, press open to allow the front panel to slide down. Genetly squeeze the release tab located on the bottom center underside and pull faceplate down and away from unit to remove. To install insert left side faceplate first then push right side to secure. Hope this Helps L8R
Sep 18, 2007 | Dual XD-7500 CD Player
DUAL XD7500 CD PLAYER PROBLEM
This is what the manual says:
With the unit off, press OPEN to allow the front panel to slide
down. Gently squeeze the release tab located on the bottom
to remove. To install, insert left side faceplate first, then push
Tried it and couldn't get it out.
Sep 05, 2007 | Pioneer DEH-P44 CD Player
Pioneer DEH-P6900UB
make sure that you have power not only to the red wire but also the yellow wire... one is battery power the othe ris ignition on power. If it only is getting one power it might not think the ignition key is on.. also maks sure there is not a reset button somewhere that you can press with a pen...
Aug 27, 2007 | Pioneer DEH-P6900UB CD Player
Head Unit going goofy
If the unit has a removable face take a pencil eraser and try shining up the little contacts on the back of the face and the radio. See if that cleaning helps.
Jun 18, 2007 | JVC Sirius KD-G700 CD Player
Projection display
To fix the projection display that is stuck with four 8's, hold down the hour and miute button at the same time. Keep the buttons pressed down while unplugging the power source then pluging it back it. I did this and the screen works like it did when I first got it.
Ken
Jan 11, 2007 | Homedics SS-4000 Clock Radio
Dual XD-7500 CD Player Logo
430 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
