Question about KitchenAid Dishwashers
Old dishwasher doesn't drain
Model # kuds230b0 kitchenaid superba 1994
how can I can i fix it
  • architectura Mar 12, 2009
    i am not really that handy, however now i have no choice, i p disconnected the drain line and put on the dishwasher a little bid and still drains poorly and there is lots of water in the base of it , my dishwasher doesn't have a pump out botton, what do i do now.
    thank you
  • KitchenAid Master
  • 3,361 Answers
Disconnect the drain line from the sink and put it in a pail.
Turn the timer to a pump out cycle and see what comes out of the drain.
If it still drains poorly, replace the pump impeller.
Posted on Mar 12, 2009
  • steve
    steve Mar 12, 2009
    If you have a shop vac, attach it to the drain line and pull the water out.
    Then call for service to replace the drain impeller kit.
  • steve
    steve Mar 12, 2009
    Thank you.
Kitchen aid dishwasher m # kdfe304dss wont drain , can hear clicking sound from underneith.what do you recommend? 14 months old.
KitchenAid Dishwasher Not Draining - Model KUDP02CRBL0
www.repairclinic.com/RepairHelp/...Dishwasher/...-/KitchenAid-Dishwas...
See All Dishwasher Parts for model KUDP02CRBL0. Cause 1 Drain ... If the drain pump motor is not working, the dishwasher won't drain. To determine if the ...
How to repair a dishwasher, not draining - troubleshoot ...? 6:18https://www.youtube.com/watch?v=rO19zoOyNHAFeb 26, 2014 - Uploaded by AdamDIYMost of the time if it is not draining, the garbage disposal is clogged or there ... If you have a newer model dishwasher that looks different from the one .... But with the help of your video, I was able to show her where her ... How to Fix a Dishwasher thatWill Not Drain : How to repair your home - Duration: 1:50.Missing: kdfe304dssDishwasher Repair-Will Not Drain-Part 2 - YouTube? 4:14https://www.youtube.com/watch?v=dYHTdzQrsBAApr 20, 2013 - Uploaded by Frosty LifeInstructions 1 Press the "Cancel/Drain" button on yourKitchenAid dishwasher after the Clean light comes on to manually drain the standing ...Missing: m ‎kdfe304dssReviews on kitchenaid dishwasher kdfe304dss
Jan 17, 2016 | KitchenAid Dishwashers
Not draining properly
Hello, I would look for a kink or a blockage of the drain hose. Also check the drain pump belt for looseness or breakage.
Jul 30, 2014 | KitchenAid Kitchen Aid Superba Series...
I have a kitchenaide Superba Monterey 21, whisper quiet dishwasher that will not drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Apr 05, 2011 | KitchenAid Dishwashers
KitchenAid Superba series has water in the bottom.
kitchen aid has a drain valve on older models and that could be the problem newer models.the motor goes other dir to drain . yu need to ck the drain out let to disposal an make sure ist clear and hose is not kinked . also be sure there is a drain loop at that point . this prevents back up and bad ordor in dw . hope this helps . mm
Dec 08, 2009 | Washing Machines
Dishwashwer won't start and can't reset to restart
Check the float. (dome shaped thing inside the washer) Mine was stuck but as soon as I lifted up on it and then reseated it I was able to return to normal. Almost too easy. Saved $!
Apr 15, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
It's not draining. i have an older model superba dishwasher and does not drain
check where they are hooked up to promblem not in washer but house lines
Mar 11, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Superba Kudso15l551
check the check valve it may have something in it.
Jun 10, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Dishwasher not draining
look the draining pipe of it, check if there's something blocking it.
Nov 25, 2007 | KitchenAid Architect Series KSRP22FSSS 33"...
Kitchenaid Superba Dishwasher
gagaweaver, couple of things you want to check here. Check the upper spray arm for any clogged holes or cracks along the edges. Position it in the 12:00 position and run the dishwasher for a little, open the door and verify that it has rotated. Make sure the water entering the dishwasher is min. 120 degrees, use a thermometer. Makes sure that there is no large pans or dishes blocking the upper spray arm from spraying onto the inner door. If all that checks out. You will have to remove the lower spray arm, filter cover and chopper cover to make sure the chopper screen is not coated or plugged up. If it is, it will prevent a good flow of water to the upper spray arm. Catriver..post back.
Mar 07, 2007 | KitchenAid 24 in. KUDU02FR Built-in...
Dishwashers Logo
333 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
