Question about Pool & Spa
Temp on hot tub will not heat above 60 degrees
  • 5,245 Answers
Bad thermostat.
Replace thermostat
Posted on Apr 22, 2013
5 Suggested Answers
  • 366 Answers
SOURCE: I have a 2004 great lakes hot tub with a balboa
check to see that the flow switch is working properly, it may not have enough flow on low speed to allow the heater to turn on. Make sure your filter/s is/are clean. If you have a pressure switch instead of a flow switch, it may need to be adjusted or replaced.
Posted on Feb 09, 2010
Coastsider
  • 331 Answers
SOURCE: mystic hot tub doesn't stay hot enough
Is your spa wired for 110Volt or 220V?
Posted on Apr 14, 2010
adamh294
  • 310 Answers
SOURCE: my hot tub control panel keeps showing OH and the
It sounds like your circulation pump is not keeping up with the heater. Check for debris in the pump impeller. If this is 24 hour circulation pump, it is probably failing. New units are about $200 US
Posted on Oct 28, 2010
itcinc1
  • 9 Answers
SOURCE: We just replace the heater in our 2006 Sundance Hot Tub. It heats OK, but doesn't seem to shut off consistently when the optimum temp has been reached. We set the temp at 104 and it wlll continu
Contact Maryland Hot Tub Repair @ 410-304-2463 or see their web site www.maryland-hottub-pool-spa-repair.com/ they specialize in Jacuzzi Sundance Service.
Posted on Dec 10, 2012
Balboa vs500
Your economy spa is equipped with a hot stick. This "hot stick" is nothing more than a PVC manifold that forces the water through multiple 1/2" ports that creates enough friction for the water to heat itself. YOUR HOT TUB HAS NO HEATER. The benefit is that there is no heating element to corrode and replace. The down side is that it takes quite awhile to heat the water. If you start with water that is 55-60 degrees it will easily take 48 hours to hit 100 degrees. Keep in mind that is dependent on the outside air temperature. Good luck with that!
May 02, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Raise temp above 120
Raising temperature above 120 degrees requires service call.
Or change dip switch settings and risk voiding warranty and causing service call expense.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#temperature
Earliest versions of Rheem tankless 2006-8 let you set temperature up to 140 degrees F using remote.
However the hotter setting caused error codes because the burner cannot keep up with both high temperature and large volume of hot water rushing through pipe. Especially in winter with cooler incoming water that must be heated more to reach temperature set point.
The burner simply cannot keep up.
So Rheem changed maximum temperature at remote control to tepid 120 degrees, which is not hot enough for folks wanting hot shower, or folks filling whirlpool tub because water in tub cools before tub fills.
Oct 27, 2012 | Rheem Tankless Water Heater Main Remote...
I have a new Jacuzzi tub with a Rapid In-Line Heater. When I fill the tub the water the initial temp is 67 degrees. The heater only increases the temp to 71 degrees. What is wrong with the heater ,if...
The bath heater you have is not designed to HEAT water - they only Maintain what you start with.
You need to start the bathtub with the hot water you want. It will only heat about 1-2 degrees an hour.
Jan 08, 2011 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Just drained and refilled, plugged back in and hot tub is not heating. Three lights flashing at temp controls. Is there a reset
Most hot tubs have a freeze protection that will lock you out and run the pumps full blast with no heater if the temerature is under 50 degrees F.The circulating pumps create heat until the water temp is above 50 degrees, and then the heater will come on after that.
Hot tubs do this to protect themselves and it is normal operation.
Nov 22, 2010 | Qca Spas Pool & Spa
I just installed my new X400 Dreamaker Spa. I filled it with water (although cold) and it has been warming up for approx. 18 hours and is only at 80 degrees? Is this normal? How long should it take to...
This is normal with the dream maker spa. The dream maker spas are poorly insulated, and only run 120 volts with a very small heater.
When the unit is first filled, the hot tub will not heat full time either. Most new hot tubs will have freeze protection below 50 degrees F. They will recirculate automatically using the friction and the pumps heat to warm the water above 50 degrees, and then the heating unit will kick on. These hot tubs do not heat while the jets are on high either, so once you are in it using the jets on high, the temperature will start to fall.
Now that you are up to 80 degrees, it should heat up fairly quick however.
Nov 19, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
My Reliance 606 40 gallon water heater only heats up enough hot water to fill a bathtub. We've drained it, the pilot light is fine, it heats up the water really hot, but it just doesn't seem to be able to...
How big is your bathtub? Is your water heater set on the hottest setting? What is the temperature of the hot water at the tap?
Keep in mind that hot water can cause severe burns. Children and those with diminished mental capacity can be seriously harmed by hot water.
The "40 Gallon" rating on the water heater is usually the amount of hot water the unit can produce in one hour. So the tank, and the amount of immediately available hot water, might be smaller than 40 gallons.
My bathtub is 2 feet wide by 1 foot deep and 4 feet long. This is 8 cubic feet or almost 60 gallons. So a 40 gallons of water at 120 degrees, mixed with 20 gallons of cold water (60 degrees), fills the tub with 100 degree water. My January cold water is 42 degrees, so it will take 40 gallons at 129 degrees to fill the tub. If the tub is cold to start it will take even hotter water.
So the water heater might be just fine.
Possible solutions:
1. turn the temperature up on your water heater- or the temperature control could be malfunctioning and not getting the water hot enough.
2. insulate your hot water pipes so that the water loses less heat on the way to the tub.
3. bigger water heater.
4. smaller bathtub, or less full bathtub.
Jan 04, 2010 | RELIANCE ELECTRIC WATER HEATER
Overheating problem
It sounds like the problem is in the main control box. Since the tub shuts down after reaching 110 degrees, the high temp sensor is doing its job. This sounds like a job for a qualified professional. Do get a price for the service call as they are usually expensive. Circuit boards start at 200.00 and go up.
Sep 15, 2009 | Jacuzzi 8450-959 Tara Whirlpool Bath 5'-...
QCA Opal hot tub display reading OH.
The tub experienced an overheat situation. This may be due to leaving the t stat turned all the way up and not monitoring or the hi-limit sensor is defective. The hi-limit sensor will shut down the heating cicuit if temp gets above 105 D optimally.the fact that the heater light is on is a good sign that things are working at this point.Whether or not a suitable temp(100-103 D) will be arrived at is to be seen. If spa heat kicks off before set temp is reached then replace hi-limit sensor.
Apr 10, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
Pool & Spa Logo
50 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
