Question about Dishwashers
The CLEAN light is flashing on my Kenmore QuietGuard3 , but it won't clean anything. It starts a cycle for a few minutes, stops and starts flashing clean again. Any suggestions?
  • Dishwashers Master
  • 3,247 Answers
You will have to reset the dishwasher. First try and turn off the mains power and back on after a short time. If the clean light flashing starts again then you go through the hard reset procedure.
press NORMAL WASH then HEATED DRY buttons one after the other until all the lights on the board lit up (3X's). The dishwasher will enter into a cycle; Press Cancel. This should stop the flashing.
If you are supplying dishwasher from hot water inlet then make sure the inlet water temperature stays within the recommended range of 145 deg F.
Posted on Apr 21, 2013
  • 58 Answers
SOURCE: Kenmore Elite Dishwasher clean light ind flashing and won't start
That means the control sensed that the heater in the d/w did not operate 3 times in a row. so the unit locks out. First remove the kick plate and you may have to pull the unit out from under the cab, but check your heater. use a meter to see if it reads open, if so order a heater assy it will come with a new control replace it to. If your heater checks good press in sequence normal wash , heat dry ,normal wash,heat dry , normal wash , heat dry three times within 6 sec all the lights will come on then hit cancel. What that did is reset the control and clear that fault. Keep in mind that d/w does not heat it's own water your incoming water temp should be 120. the d/w will maintain that temp. when starting your d/w first turn on your hot water till it gets hot then start your d/w this insures your unit fills with hot water and not cold
Posted on Jan 09, 2009
  • 188 Answers
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Posted on Feb 20, 2009
  • 188 Answers
SOURCE: Kenmore dishwasher, model 665.170 344 01. "Clean" light keeps flashing and will not stop. Have tried everything in the manual and the light still will not stop flashing.
If the clean light flashes 7 times, pauses then repeats...
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive).
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
SOURCE: ''clean'' light flashing (whirlpool Dishwasher GU2300XTLS1 model)
I had the same problem recently and a repair person came to my home to fix the dishwasher. He said he had to reset the control panel. He did this simply by making sure the soap dispenser door inside the washer was closed, then making sure the main dishwasher door was closed and locked. Then he quickly pushed the Heated Dry button and the Hight Temp wash button alternately. He said each button needed to be pushed twice within five seconds. After he did this all the lights on the control panel came on, then turned themselves off before the washer went in to a test cycle. This simple reset fixed the whole problem. Works great so far.
Posted on Jun 16, 2009
jan mczeal
  • 632 Answers
SOURCE: 'clean' light flashes
Press the normal wash then heated dry buttons in the same sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the cancel button.It will clear any existing faults and makes the dishwasher to operate normally.
To prevent the issue from recurring, run your hot water faucet first to ensure that hot water is present in the entire supply line before starting the filling.
Posted on Oct 18, 2009
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
Clean light keeps blinking; dishwaher won't turn on
Hello Brian, welcome to FixYa.
Based on your post I understand your dishwasher is a Kenmore and the clean light is flashing and it won't start, correct ?
If so, this is usually an error code indicating there was a problem in the heating process the last cycle it ran, however if you could provide the complete model number I could speak specifically to whether it applies to your machine and potentially what to do about it.
Thank you for choosing FixYa and I look forward to your reply.
Regards,
Macmarkus :)
Oct 12, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Icemaking cycle automaticall self stops and cleaning light blinks
ice machine runs one cycle and freezes ice will not release ice block to wire cutter. then after a few minutes the cleaning light starts blinking
Jun 11, 2009 | Kenmore 51lb. Clear Ice Maker
-high temp wash
-heated dry
-high temp wash
-heated dry
Feb 17, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Clean light flashes constanly. Won't clear out to start new cycle
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
-high temp wash
-heated dry
-high temp wash
-heated dry
Jan 03, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Dishwasher - Flashing Lights - wont start
Is the clean light blinking 7 times? If so this means you have a problem with your heating element
Dec 03, 2008 | Kenmore 15899 Built-in Dishwasher
Won't start
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Jan 13, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Quiet guard 3 dishwaher
Sep 23, 2007 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwasher lights blinking
May 11, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
245 people viewed this question
Top Dishwashers Experts
