Question about Vehicle Parts & Accessories
Can't get the hub off
THERE SHOULD BE AN OUTER NUT ON THE SPINDLE THEN A LOCK RING BEHIND THAT AND ANOTHER NUT BEHIND THAT. THE INNER NUT WILL HAVE A SMALL PIN THAT INSERTS INTO THE LOCK RING TO KEEP THE INNER NUT FROM BACKING OFF THE BEARING. THIS WILL REQUIRE A SPECIAL SOCKET THAT YOU CAN BUY FROM THE TOOL TRUCK OR LOCAL PARTS STORE. IF YOU HAVE THE NUTS OFF AND THE HUB WONT COME OFF - THE BEARING IS STUCK ON THE SPINDLE AND A LITTLE PRYING FROM BEHIND THE ROTOR WILL POP THE OIL SEAL OUT AND THE HUB WILL COME OFF THEN YOU CAN REMOVE THE INNER BEARING AND SEAL.
Posted on Apr 21, 2013
Alexrims dm18
The rim should not cause any problem - but you'll need different length spokes.
Rear hubs and front hubs are different widths, have different height hub flanges, and different amounts of "dish" (offset from the center of the hub body.
If your hubs and rims are in good shape; go ahead and re-use them; but you'll need help measuring or want to use a spoke calculator online for the correct length spokes.
Oct 29, 2012 | Alex DM18 Rim - 26 Inch x 32 Hole Black SV
My book doesn't have power
Did you plug it in?
USB Powered Devices:
If you're using USB for power then you either need a powered USB hub or the device must connect directly to the computer's USB port bypassing the hub.
If the USB hub doesn't plug in to the wall socket then it is not a powered hub. Basic USB hubs do not supply power to devices or charge an external device like a cell phone. The hub must be of the powered variety and plug into the wall before you can use it for things like this.
TIP:
Get two USB hubs, one powered and one not. If you're using a USB hub for anything other than connecting a flash drive or your wireless keyboard and mouse receiver, get a powered one. Doing so allows you to charge multiple devices through USB and it will provide power to other peripherals like a laptop cooling pad, external hard drives, etc.
Sep 29, 2012 | Western Digital My Book Essential 1TB...
2005 Kia Sedona Rear Hub and Drum
Use 2 bolts [ same size as screws ] 1.5'' - 2'' or so...thread into 2 screw holes...tighten both evenly untill drum comes off.
Sep 04, 2012 | 2005 Kia Sedona
My 4x4 hubs won't lock on my 96 Isuzu rodeo
I assume they are manual locking hubs? Once you engage the hubs and select 4WD you must reverse a few meters and you will hear them click into place, If they don't lock in your hubs may need servicing, They are quite easy to dismantle and re-grease which you can do yourself if you are handy with mechanical buts and pieces.
Mar 04, 2012 | 1995 Isuzu Rodeo
Where is the driver belkin f5u101pc
There shouldn't be any driver required for this hub. It's a standard USB device. If your computer supports USB 2.0 connections, you should be able to just plug this device in and then plug your addition USB devices into the hub and it should just work.
If you don't have an existing USB port on your computer, then you're out of luck with this device.
Jan 31, 2012 | Belkin (F5U101-MW) Networking Hub
I have sahara n1356 laptop which freezes mouse and keyboard when i start it. what could be a problem
Try following tips:
Try to connect your keyboard and mouse directly to your laptop's USB ports (instead of using the USB hub) and see if they still freeze.
OR
It sounds like you're using an unpowered hub, which in my experience tends to cause most common errors with USB peripherals. It's definitely not recommended to connect any USB devices which aren't supplied with a power adapter (for instance some 2.5" external HDs and those small photo printers). These sort of devices should be connected directly to your laptop at all times.
You could also consider buying a powered hub, i.e. an USB hub which draws its power from a separate power adapter (and not your single laptop USB port).
if it doesn't work you can try this..
Click Start, and type device manager in the Start Search box.
Click Device Manager in the Programs list.
If you are prompted for an administrator password or confirmation, type your password or click Continue.
In the Device Manager dialog box, expand Universal Serial Bus controllers.
Right-click USB Root Hub and then click Properties.
In the USB Root Hub Properties dialog box, click the Power Management tab.
Remove the check from the Allow the computer to turn off this device to save power check box. Repeat steps 1 through 4 for each USB Root Hub listed in the Device Manager.
Under Power settings, check the 'USB settings' -> 'USB selective suspend settings' and make sure it is disabled.
Check Thumbnail, highlighted: Open Device manager, Double click on Universal Serial Bus controller at the bottom, Double Click USB Root Hub, Click Power Management on top right, Uncheck Allow Power...
Hope it works for you.
Sep 20, 2011 | Dell Dimension 8300 PC Desktop
F4U017 Belkin 7 port USB hub. No matter what i do, i cannot get this hub to work, i'm running windows 7 ultimate Home, i've updated and updated, it has got something to do with the...
Rimshot64, you did help someone out here. Two years later, even. And you succeeded where Microsoft "Help," per its tradition, failed. Thank you -- I got my scanner and printer, etc., back, and wasted only half a day uninstalling Microsoft updates (their suggestion).
Aug 02, 2011 | Belkin (F5U237) 7-Port USB Hub
My laptop is simply not recognizing my futaba interlink controller via usb hub. i know the hub works because i plug something else in and it works fine...I'm thinking just bad controller maybe?
Well i'm having the same problem.
My mouse & keyboard work trough the hub, however when i plug an USB-stick in, it wont recognize it.
I've i put my USB-stick in another USB-port, it works.
So try putting your usb, in another USB-port, thats not from your hub.
Jun 19, 2011 | Computers & Internet
Just replaced the friction plates, the clutch spring hub does not seat onto the splines. What did i do wrong?
G'day.
You don't stipulate your bikes model or year which makes this a bit harder.
When you fitted the outer hub(the one the springs sit in)- you've probably miss-aligned it.
Remove the springs again
Remove the hub- & re-fit over next set of posts(turn the outer hub so it dosn't go over the same posts as before) & it should slot all the way in.
If it dosn't-try again
It looks like the outer hub can fit over the spring posts in any position- but it can't.
I hope this works for you.
Regards Andrew Porrelli
May 20, 2011 | kawasaki VN 1500 Vulcan Classic...
I use a Dynex USB 2.0 4-Port hub in a mailing machine. I keep getting brand new hubs that quit and won't power up. Leaving all the same cables and plugging in a new hub and it powers up. I am also...
You are probably putting too much current through the hub. 1 USB port is good for 500mA, and since this splits 1 into 4, you're working with 125mA per device if you have 4 things connected. Find a powered hub instead.
May 06, 2011 | Dynex 4-Port 10 Mbps Ethernet Hub
Vehicle Parts & Accessories Logo
91 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
