Question about Philips Magnavox Learning Universal Remote
Code for a philips universal CLO34 33/06
Need the code
  • 73 Answers
SOURCE: universal remote codes
try this website it might be of help.
http://www.universal-remote.net/philipsmagnavox.html
Posted on Jan 02, 2008
aprmaejun
  • 97 Answers
SOURCE: philips pm 335 universal control
I found the manual for your remote control at:
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/philips/pm335-manual.zip&area=other
I looked for the code for a zenith tv and it looks like they're all 3 digit codes. It lists: 002, 008, 115, 215, 405, 407, 601, 701, 713, 903, and 916. If none of these work, I would suggest programming with the code search.
1. Press and hold "Code Search" button until the red indicator stays on. Release the "Code Search" button.
2. Press and release the desired mode button (TV, DVD, etc.) The red indicator will blink, then stay lit.
3. Press and release the "Code Search" button. The indicator light blinks off.
4. To find the first digit for the code stored under the mode key pressed in step 2, press each numeric key from 0-9 in turn. When the indicator light blinks off the number you pressed is the first digit for the code you are searching for.
5. To find the second digit, repeat step 4, this time when the indicator light blinks off this is the second digit.
6. Repeat step 4 again to find the third digit.
Posted on Jun 21, 2008
VOTIT
  • 2071 Answers
SOURCE: philips universal remote codes for zenith t.v.
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 01, 2008
SOURCE: i need a code for my universal remote from philips
i need a tv code for an apex tv using a universal remote control
Posted on Dec 01, 2009
SOURCE: i have a philips universal sru 3003 and i NEED codes
i have philipsuniversal and i need codes to a panasonic tv
Posted on Jan 16, 2010
I have a Philips universal remote #CL034A and need DVD code for Philips blue ray player #BDP5013?
You can use the code search feature of your Philips universal remote to find something that handles some or all functions of your Philips Blu-ray player. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not contain all possible codes.
May 19, 2016 | Philips Televison & Video
What is the code for programming universal remote for philips 19 in tv model 19PFL3504D/F7
How To Program A Philips Universal Remote ' Codes For ...
codesforuniversalremotes.com/program-philips-universal-remote/
Here is how to Program any Philips Universal Remote Control. Turn on the device you ... Remote Control Codes December 21, 2015 at 1:19 pm. Stephanie,
Codes For Universal Remotes ' Universal Remote Control ...
Universal Remote Control Codes For TV & Audio. ... Codes for Philips Universal Remotes · Sanyo TV Codes for Universal Remotes · Codes for .... I have an 19 inch Emerson flat screen and a RCA universal remote. Please help with the code ..
Dec 28, 2015 | Philips Televison & Video
I need code for philip s remote for a sayno ty
Philips rca universal remote codes sayno vcr dvd combo ...
www.fixya.com > ... > Remote Controls
Universal Philips Magnavox remote for a Sanyodvd vcr combo ? I have a cableremote and need to program my Magnavox vcr/dvd combo into it i have 2 dvds ...
How to Reprogram a Philips Universal Remote Controller ...
science.opposingviews.com > Computers
Dec 21, 2015 | Philips Televison & Video
I need a code for my universal remote from Philips. My TV is JVC. That's the code that i need. Please help me......
I need a code for my universal remote from Philips. My TV is APEX. That's the code that i need. Please help me......
Nov 30, 2009 | Philips Universal PH301S Remote Control
Need codes for a philips universal remote for a
Please go for the above code
Rate here Please !
Sep 05, 2009 | Philips Universal PH301S Remote Control
Need code for philips to enter on universal remote
try these one should work
PHILIPS ..... 002 009 109 202 209 210 310 402 408 508 510 807 901 914 917
Mar 28, 2009 | Philips Universal PH301S Remote Control
Philips pm 335 universal control
Go to www.remotes.com If they dont have it no one will!
Please rate this response and help keep this area FREE!
Jan 23, 2009 | Televison & Video
I lost my remote codes for my philips US2-PM435S
Lost my remote codes for my philips remote. I need the combo codes for a tv, vcr,and dvd.
Apr 20, 2008 | Philips Magnavox Learning Universal Remote
Philips Magnavox Learning Universal Remote Logo
22 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
