Question about Garden
Century 2028 tractor loss of power
Loss of power, changed fuel filter abd bled system of air, idles smooth but loses power under load
  • 109 Answers
SOURCE: model#917.276020 25hp 48
On the bottom of the carb., there is an anti-after fire solenoid, take it off and make sure that it is working with the key switch, it should retract when the key is turned on and go back out when the key is turned off, if it doesn't check the red wire to make sure it is still connected
Posted on Apr 24, 2009
  • 246 Answers
SOURCE: craftsman 20.5 hp. auto trans.lawn tractor loss of drive power
Hello:
>>You can View a Breakdown/IPL of
this Engine at this Site Addy,
http://www.outdoordistributors.com/
and Select the H. Then Select Hydro-
Gear. Then Select Don't have Part
Numbers. Then Enter the Model
Numbers 319-0650. Then Select your
Model and Download the File for
Online Viewing.
From your Description it Sounds like the Internal Pump is Worn and is Loosing Pressure as the Unit Heats Up and the Components Expand from the Heat.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • 127 Answers
SOURCE: loss of power on deere lx277
replace the fuel filter and install the proper way there is a aero stamped on it it must point towards the carb. that will solve your problem
Posted on Jun 26, 2009
  • 203 Answers
SOURCE: motor chokes and misses under moderate load and loses power
Sounds to me as tho it might need a carburetor adjustment, providing there is an adjustment screw on the carb. Sounds like the engine is running a bit lean. Did this problem occur right after the carb cleaning, or was it there in advance? Is there a fuel filter that might be clogged?
Posted on Jan 19, 2010
  • 110 Answers
SOURCE: I have a craftsman 19.5 hp lawn tractor model #
Carb is dirty and leaning out so the governor throttles the engine up & down causing a surge. You can try using a good quality fuel injector cleaner product mixed in the gas. That may help but if that doesn't work it will be best to replace the carb. That is an older engine and the carb is not likely fixable. It is a matter of how much money you want to throw at it. Putting a carb kit in it and giving it a through cleaning has no guarantees then you will still need to spend money on a new carb. The carb for that runs about $165. If you replace it yourself I'd recommend taking pictures as you take it apart so you can see where all the linkages go and you will be able to put it back together without problem. Hope this helps. Please vote yes if you find it helpful.
Posted on Nov 18, 2010
John Deere loses power under pressure what can cause this
what is the unit? have you checked fuel filters air filter? is the tank outlet blocked with debris?
Sep 14, 2014 | Garden
Sabre 17.542hs loss of power
you could have a weak coil and misfiring under a load each cylinder has it own coil on that engine you can get a inline spark tester to see
Sep 03, 2012 | John Deere Garden
I have a Sears Craftsman GT5000 Garden tractor with a 25hp Briggs & Stratton engine. It will not idle down and appears to be "overreving" It back fires and misfires when under a minimal...
Probably would be the governor if the engine was running well - but it isn't.
One thing likely to cause the engine to run faster than idle and not to run smoothly and have a loss of power is an intake air leak or perhaps there is a diaphragm in the carb that has failed.
Fitting new plugs as a knee jerk reaction to trouble sometimes works but it doesn't move a person any closer to a diagnosis unless the spark power has also been tested. A weak spark can aggravate a lean mixture as it is harder to fire than a rich mixture and your description indicates a weak rather than a rich mixture.
Nov 18, 2017 | Craftsman Garden
I have a 1998 f150 truck with a 4.6L engine, starts fine but looses power when I put it in gear.
Sounds like a Fuel problem to me. Seems there is enough fuel to start and idle, but once the engine is placed under a load, it loses power due to a loss of fuel.
I would have the Fuel filter changed first and if the problem continues after that, I would have the fuel system tested to insure the proper pressure. The Fuel pump is in the Fuel Tank, so this can get to be a time consuming, and thus expensive operation if done at a dealership or reputable shop.
You might also check you air filter. There are only 3 things one needs to have a good running engine:
1)Proper Air Mix
2)Proper Fuel Mix
3)Proper Voltage
If any one of these are missing, it causes a problem
RPM
Jul 16, 2011 | Ford F-150 Cars & Trucks
I have a small kubota tractor -L1800DT -deisel motor. It starts but stops a rter a fer seconds running, . When it does go, it slowly fades in power and stops. I have replaced the fuel filter which was...
Andy, a couple of ideas for you: first, check to see if there are two fuel filters. Some Kubotas have one filter in the engine compartment, but another one under the chassis. If you only changed one, you could have another one still plugged up. The other problem that would cause the engine to lose power shortly after starting would be a dirty air filter, so check that too. Good luck! Please rate my solution if helpful, thanks.
Aug 09, 2010 | Woods Kubota Bx 24 Bx 23 Bt610 Bh75 And...
I have a 2004 f350 with the 6L diesel. I get an occasional problem with a loss of power and thick white smoke when I try to accelerate from idle. The motor runs smooth idles smooth no coolant loss. Once I...
if your not loosing water and have white smoke it is unburnt fuel,poss the mass air sensor.(car thinks its cold so putting in double fuel for cold tickover.)
Jul 01, 2010 | Cars & Trucks
Motor chokes and misses under moderate load and loses power
Jan 18, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Subaru liberty/legacy 94 loss of power
SOUNDS LIKE YOU HAVE IT NARROWED DOWN TO THE EXHAUST SYSTEM.THE CONVERTER IS PROBABLY PLUGGED,CHECK THE TEMPS. COMING IN AND OUT.THEY SHOULD ONLY BE A FEW DEGREES DIFFERANT,IF THEY'RE ALOT HIGHER COMEING OUT IT'S PLUGGED.
Oct 11, 2009 | 1994 Subaru Legacy Outdoor
Garden Logo
80 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
