Question about Pentax K1000 35mm SLR Camera
I would like to know what these do
I have just got this pentax k1000 film camera and it came with 4 lens filters could you tell me what they do?
1.) BOWER skylight 49mm
2.) HDYA 49mm PL
3.) Quantaray 55mm 1A
4.) HANIMEX 55mm ploarizing
    Scholar:
  • 124 Answers
Bower is brand name skylight is slightly yellow helps soften light there are diffrent densitys. Filter is mostly used to protect orginal glass of lens from dirt smudges scratches & rough treatment. Keep on lens most of the time.
Hyda brand name. PL 3 i believe to be a dark polarizing filter.
Quantaray 1A4 I believe is a haze or skylight filter.
Haze filter does almost the same as a skylight filter.
Hanimex brand name. Polarizing filter used to shoot through reflective glass or surfaces (water), also in color used to sharpen colors. The reason it is turnable is it is light directional beaning light comes through it at a angal hold up to light & turn it you can see how it darkens or litens. Also can stay on lens when not useing skylight filter.
reason you have 2 is one of each for two diffrent lens, 49mm & 55mm.
Hope this helped. Please rate.Thank You.
Posted on Mar 12, 2009
Can you usePentax k1000 or me super film caamera lens on a Pentax ditigal camera?
Yes, with limitations. The lenses will fit on any Pentax (now Ricoh) digital SLR. You may lose autofocus and/or auto exposure metering.
Oct 19, 2014 | Pentax Cameras
Film cartage broke missing parts
To repair this camera will be well over $100; my opinion not worth it. You would be better served purchasing another camera of the same type from ebay. An alternative terrific camera is the Pentax K1000, better yet K1000 SE. The SE has a split viewfinder, easy to focus. The K1000 have microprism that are more difficult to focus with especially in lower light; need good eyes. Then there is the Pentax K2, that at the time was their top of the line camera. All three cameras can be purchased for about $100-ish. Most will come with the Pentax 50mm f/2.0 lens.
Feb 06, 2014 | Minolta Photography
Asahi pentax sv film advance lever stuck
Without film in the camera it may well read before zero, my K1000, K1000Se, and K2 do that. Press the film rewind button, maybe that will release it for you.
For camera repairs look to:
Eric Hendrickson: http://www.pentaxs.com/index.html
Oct 02, 2012 | Pentax K1000 35mm SLR Camera
My Pentax K1000 ser. # is 6636745. Can you tell me what year and where it was made?
Nothing official mind you- but some folks on the pentaxforums.com put in all their K1000 info and one of the admins complied said info and came up with their own chart.
http://www.pentaxforums.com/forums/pentax-film-slr-discussion/51190-k1000-serial-number-database.html
if their information is true then your camera would have been manufactured between 1977?-1982
run From To years manufactured
1 7 5xx xxx 7 7xx xxx 1976 - 1978?
2 6 0xx xxx 6 9xx xxx 1977? - 1982
3 7 0xx xxx 7 4xx xxx 1982 - 1983
4 7 8xx xxx 8 4xx xxx 1984 - 1989?
5 4 xxx xxx 5 6xx xxx 1989? - 1997
Oct 08, 2009 | Pentax K1000 35mm SLR Camera
Will no longer recognize 4gb sd cards
F4shsk1
are you sure the camera is a Pentax K1000.
the K1000 is a manual 35mm film camera, the only electronics in it are for the light meter. plus a circuit for the flash connections.
Apr 14, 2009 | Pentax K1000 35mm SLR Camera
How do I rewind and take the film out of a pentax k1000?
mhamabrown,
push the rewind button on bottom of camera and turn rewind knob to the right, ( clock wise ) then pull the rewind knob up to open the film door.
Feb 24, 2009 | Pentax K1000 35mm SLR Camera
Can't get my lense off!
You can use any mm lens you want as long as it was made to fit the K1000.
Is the lens a Pentax lens ?
Push the lens release button down and turn lens Clock-wise then while holding release button down quickly turn lens counter clock-wise, it should come right off.
If it did not then it must be disassembled to remove the lens.
Oct 31, 2008 | Pentax K1000 35mm SLR Camera
Film advance lever stuck
The shutter parts are most likely broken. That is usually the tell-tale sign of a broken camera, not advancing. Repairs for film cameras are very expensive and if parts are needed, it may be impossible for a 20+ year old camera. My suggestion is to find a replacement film camera system. Your Ricoh lenses will fit on a Pentax camera, but not work in Auto Mode. Prices of used Pentax cameras with built in motor drives are around $100. Check on line cameras stores. They have lots of use cameras/lense. A lens to use on that is another $75 or so. Only Nikon and Canon make new film cameras anymore. If you want an indestructable K-mount, find a Pentax K1000. Many lenses are available but no motor drive nor auto exposure on that model.
Apr 09, 2008 | Ricoh KR-30SP 35mm SLR Camera
Scratched Negatives
When you say ''back'' of the film do you mean on the emulsion side or the base side. Base can take light scratches can may desapear in processing..Emulsion side is not forgiving...
Hard to tell..Anything along film path can cause scratches, including the back of the cover, film tension, aperture gate..
Hard to suggest anything precisely other than a good check up by registered Pentax rep.
I once spoted a similar problem by loading a camera with he film wounded backwards. That is emulsion facing the back of the camera and base toward the lens. Emulsion being softer, I found a spot where emusion built up (thus scratching on base side). I did not dare fixing it and sent it for repair for a good clean up.
Under proper lighting, you may also want to remove the lens and carefully look for the scratch in the aperture gate. If you see it, problem is before (feeding side).
Good luck. KX is aging but still a good camera
Mar 22, 2008 | Pentax K1000 35mm SLR Camera
Pentax K1000 35mm SLR Camera Logo
164 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Greg Cann
Greg Cann
Are you a Pentax Photography Expert? Answer questions, earn points and help others
