Question about XO Vision XOD1735 Car DVD Player
I just inserted an sd card then somethings gone wrong with the buttons. The power button becomes the volume. The + sign, open button becomes the power. The - sign becomes the menu.
    Problem Solver:
  • 8 Answers
Try taking the card out and reseting unit
Posted on Mar 12, 2009
How can i reset my symbol windows mobile mc7090
did you try this?
  1. Performing a factory reset using phone buttons
    1. Turn the power off.
    2. Press and hold the VOLUME DOWN button, and then briefly press the POWER button. Release the VOLUME DOWN button when you see an icon on the screen.
    3. Then press the following hardware buttons in sequence: VOLUME UP > VOLUME DOWN > POWER > VOLUME DOWN.
Feb 12, 2015 | Symbol MC70 Handheld Mobile Computer (P/N...
I removed the sd card and lost it and now my kurio7s wont go any further than the grey screen with the small computer blinking at me, what do I do now?
Try to insert another sd card and then try to power on the computer again. If that does not work try to reset it by removing the battery for 5 minutes and then replace it and try to power -up again with the sd card inserted.
Dec 19, 2014 | Tablets & eReaders
Please i really need a quick answer on this, am having a problem on my china i9500 it asking me for (4-8) passord and i cant remember it
There is only 2 possible ways, "remembering the password" or "saving important data to a SD card or computer and having to factory reset it".
Incase you want to factory reset it the steps are below. Hope this helps.
step 1 : power down phone & remove SD card "in some cases the SD cards memory has been erased, so remove it to be safe"
step 2 : press and hold the volume up, home button, and the power button at the same time for 5 seconds then release the power key only.
step 3 : wait for the recovery mode to boot up, and then use the volume buttons to navigate to "wipe data & factory reset"
(Incase of SD card use) step 4 : when your device is has booted up it will start up as if you just got the phone. When your done setting up your device, insert the SD and allow it to load into the device. (With some smart phones it might be safer to power down the device and then insert the SD card, allowing it to boot up with the phone)
Now you're all set. Hope this helped.
Oct 30, 2014 | Samsung I9500 Galaxy S4 16GB Quad-Band GSM...
How to unlock apps on nextbook
1. Back up everything you feel is important before you start.
2. Charge your device to 75% or more before you begin to prevent unwanted shutdowns.
3. This method will only work for the versions of Nextbook 8 bought before August 2013. Check the back of the tablet and if the serial number begins with YFG1013, YFG1113 or higher, this procedure is not for you!
II. Necessary Downloads
1. [Download link available in this post]
2. [Download link available in this post]
III. Rooting the Nextbook 8
1. Extract to a folder on your desktop. You should end up with a file calleduImage_recovery with no extension.
2. Connect your device to your PC and copy both uImage_recovery and to your device's external SD card (not the internal memory, insert a microSD card if you don't already have one); do not put them into any subfolders just drop them in the main folder of your device's external SD card.
3. Power down your device and reboot to the modified recovery you have just copied. To do this, with the device powered off, press and hold the Volume Up + Volume Down buttons with the Power button until you pass the splash screen, a black screen and you see the recovery menu.
4. Use the Volume Up and Down buttons to highlight the 'Flash zip from EXT card' option and the power button to confirm the selection.
5. Once flashed, go back to the main menu and select 'reboot system.'
Once the Nextbook 8 reboots, check for the SuperSU app in the app drawer (install it from the Play Store if you don't find it) to verify you are rooted!
Sep 29, 2014 | Tablets & eReaders
I cant remember my cruz pattern to sign into the whole system. what can i do?
There isn't anyway to bypass the security pattern on an android device. So basically the only option you would have is to do a factory restore and start from the beginning. You can also use this opportunity to update to the newest firmware if you haven't done so.
The update can be downloaded from here. After downloading copy it to the root (not in a folder) of an SD card ensuring that the file is named 'PD_INX7E_ENG_6410POP.ZIP'.
Insert your SD card into the external SD slot on the device. With the device off, press and hold the volume up button. While continuing to hold the volume up button, press and hold the power button. Continue holding both buttons. The 'Cruz' screen will come up and then an android screen with a status meter will come up. Now release both buttons and let the update apply. When it's done the device will reboot and should start normally.
This does clear the internal memory of the device, so you will lose all the programs that you've installed. Any data on the internal SD card and external SD card will not be touched.
I hope this helps. Let me know if you have any questions.
May 17, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
Hello, i have samsung star duos B-7722,i have problem that when i open the images folder from my files options then a problem occur which is display by message as "Not enough resources available,...
Sounds like it's a software issue. Your phone might have gotten a virus. Yes, there are viruses for Androids.
Back up anything you need to save to the SD card, then turn the phone off and remove the SD card.
Next, hold the volume down + power buttons for approximately 30 seconds or until the HBOOT menu appears. Try volume up + power if the first doesn't work.
In the HBOOT menu (HBOOT is essentially BIOS for smartphones) select the "restore to factory defaults" option using the volume keys to navigate, and the power button to select it.
This will delete all apps and data on the phone, and return it to the stock settings, the condition in which you bought the device.
Re-insert the SD card and move the media you backed up back to the phone. If the issue persists, Please post your outcome,Best !!
Sep 29, 2017 | Cell Phones
How do i go about formatting my kingston sd card, step-by-step?
Insert card into card reader. Find which drive letter the card is in. Right click on that drive. You will see an option that says format. A warning will tell you anything on the drive will be errased. Once sure you have the right drive click OK.
Nov 28, 2009 | Kingston 4GB Secure Digital High Capacity...
What does no card mean? Thank you.
"No card" means that either
  1. You have not inserted a memory card
  2. The memory card is not formatted, or
  3. The memory card is damaged and therefore can't be read by the camera.
How to insert the memory card:
  1. Open the camera’s battery door by sliding it downwards.
  2. Insert the SD card into the slot as shown inside the camera’s battery compartment. The SD card can only be inserted one way.
  3. Press the SD card completely into the camera and then close the door. Open the door and press on the memory card if you wish to remove it.
Note: There is only one way to insert the SD memory card into the slot. Do not force the card into the slot. This may damage both the camera and the SD memory card.
Before you can use the card, it has to be formatted:
  1. Insert the memory card into your camera as described above.
  2. Turn the camera on by pressing the power button.
  3. Use the multi-select button to select the "SET" option.
  4. Press the right arrow button to set "System" then press down key to select "Format".
  5. The default option is ‘Format’. Select this option by pressing the OK button.
  6. Select "Yes" to format the card.
If all this does not work it might be that your SD card is damaged. Try to replace it with another one. If you have any more questions, just come back here and leave a comment - I'm happy to help.
Aug 08, 2009 | VuPoint DC-ST300-VP Digital Camera
My sansa will not load to the main screen and i have tried to fix it even when i plug it in to computer i goes to same screen
First, try a soft reset. Do this by pressing the center button and the up volume button simultaneously and try turning it on. If that does not work for you, you will need to get a micro sd card (it can be a dummy) and insert it into the slot on the side of the mp3 player. If you do not have one, you can use one of the round edges of a paper clip (be careful) to get it to come on. When you put either in, it should come on automatically, but if not, just press the power button. This should work.
Mar 22, 2009 | SanDisk Sansa MP3 Player
Reinstalling os
This is the ultimate solution that has worked for me couple for times. And it will work for everyone who would face this problem
Even after this if you face this problem, thow your phone:P
Remove the battery.
Simultaneously hold volume "down" - button and Red hangup button.
While still holding those keys, insert the battery and wait for the LED to go out.
Release keys, remove battery and insert it back, and device will hard reset.
Mar 07, 2009 | i-mate Jama 101 Smartphone
XO Vision XOD1735 Car DVD Player Logo
201 people viewed this question
Top XO Vision Car Audio & Video Experts
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
