Question about Speed Queen CTS99AWN Front Load Washer / Dryer
Inner tub is loose
Wobbles inside the drum
    Problem Solver:
  • 8 Answers
Could be a number of problems. Your bearings are shot, or you could be having problems with the belt
Posted on Apr 21, 2013
Have a GE WSXH208HWW Spacesaver, Washing Basket is wobbling. What is the problem and can I fix it myself?
2 possible problems. On the outside of the tub front and on the top back are cement counter weights that are bolted to the tub. If they are coming loose, they would cause the tub to go off balance and wobble. If just the stainless inner tub is the one that wobbles, that suggests a bad rear drum bearing. The counter weight problem easy to fix once you get the top and back off and just need re-tightened. The back drum bearing is something even trained techs want to avoid. It requires removing the complete tub/drum assembly from the washer----then splitting the outer tub in half to replace the inner drum and bearing assembly. Cost for parts will be excessive and not worth the repair.
Apr 04, 2015 | GE Washing Machines
How do I fix inner tub blanace
Replace the inner drum and spider
Apr 29, 2014 | LG Washing Machines
Spinning cycle makes a lot of noise
See if the tub will spin freely by hand. Spin it both ways. It should coast silently to a stop. If you hear a dragging sound or it doesn't spin smoothly look for a sock between the inner and outer tubs. Start looking in the upper left side at about the 10:00 and 11:00 positions. That's where i usually find them.
If it seems to spin ok then see if the inner tub wobbles separately from the outer drum. Push up on inner basket from inside. The outer drum and inner tub should rise and fall as a solid piece. If you feel a separation the bearings need replaced or the spider assembly has broken. Only a complete teardown can tell which. Hope this helps.
Jan 27, 2013 | Whirlpool Duet GHW9150P Front Load Washer
I believe the drum is off, it rattles badly. Also it seems taht the white plastic ring in between the drum and the rubber seal has broken.
If the inner wash tub does not spin true, but wobbles and rubs against the outer plastic tub, when you try to spin it by hand. The problem is that the support arms or spider arms have failed. It is an expensive repair since the wash tub and outer tubs need to be replaced and the washer has to be torn completely apart to replace them. Check your warranty and see if the manufacturer will help with the repair costs. Get a few estimates, before deciding whether to repair or replace this. Sorry.
Feb 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The drum inside my ge wbvh6240fww washer is loose. I can move it around with my hands. During spin cycles it sounds like a tornado, and the room fills with smoke from where the drum rubs. The belt is fine,...
There is one bearing in rear tub/bearing is part of rear tub...To repair that unit you will need a rear tub/inner basket with spindal and possible a front tub if it damaged..If i was you I would price the parts b/c you may not want to repair it as it can be costly .....Good luck
Jan 31, 2011 | GE WBVH6240F Front Load Washer
Loose inner drum
your bearing is gone. needs a new tub assembly. its pricy
Feb 05, 2010 | Frigidaire GLTF1240A Front Load Washer
Not spinning properly
You will need to replace the inner basket and front outer tub assembly. Likely, the spider on the inner basket (drum bracket) has broken which is causing it to be loose and rubbing on the inside of the outer tub. This can be verified by checking for excessive play of the inner basket (hold the front of the inner basket and check for play by moving it up and down).
It's not a cheap repair unfortunately. Be sure to always use a small amount (2 tablespoons for a full load) of HE (high efficiency) detergent to prevent future build up which could cause corrosion of the tub spider.
Feb 01, 2009 | Whirlpool GHW9100L Front Load Washer
Stainless steel drum loose
A loose inner drum usually indicates a failed rear tub bearing. The only solution is to replace the rear half of the tub. (which contains the bearing).... You can check if the pulley nut has come loose by removing the rear panel. There is a large nut that retains the belt pulley to the shaft of the basket.
Jun 04, 2008 | Kenmore Elite 45986 Front Load Washer
Frigidaire front load washer model GLTF1670ASO
Check the shocks on the bottom of the drum. I had the same problem and had to replace the shocks because they were broken in half.
Mar 02, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire Washer - Loose Inner Tub
the inner drum is most likely broken. go to sears.com select appliances then select parts enter model number and you can get a blow up. Hope this helps.
Jan 31, 2008 | Frigidaire FWT449
Speed Queen CTS99AWN Front Load Washer / Dryer Logo
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
