Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
My stackable whirlpool washer doesn't spin/work
It makes a loud noise and nothing works. It broke while in the "spin" cycle yet it won't spin anymore. We took it all apart and did not discover anything loose or missing or broken. Maybe something is wrong internally?
    Problem Solver:
  • 19 Answers
You may find a possible solution in this thread:
http://www.fixya.com/support/t1578111-lte5243dq6_tub_broken_loose
Posted on Jun 17, 2010
  • 478 Answers
The most likely cause is the motor coupling , its the plastic and rubber parts between the motor and transmission. Try turnig it with your finger.
Posted on Mar 13, 2009
Makes loud noise during spin cycles
bearing going bad, just keep on using it until you cant stand the noise anymore then get you a new washer, bearing is not worth replacing $200 to 300 bucks
Oct 27, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a samsung front loader washer model number we357a7w/xaa only 3 and a half years old that stopped draining water and making a funny noise. It wont even go on spin cycle. please advise?
Thanks for choosing FixYa and welcome. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive ir spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging. This noise is heard in the spin cycle.
Mar 18, 2011 | Samsung WF337AA Front Load Washer
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
Washer making loud noise and wont spin
Check and see if the inner drum is loose and floppy.if it is, it's likely the bearings have collapsed, and require replacement...If the drum feels stiff and tight, it could be that something is jammed between the inner and outer drums. Both situations could be costly...Get quotes....Good luck...Nomess
May 22, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Loud noise during spin cycle
what kinda noise, sqeeling, or clunking, mite be sumthing small that made its way behind ajatator an is causeing noise..or one of the springs that hold it broke..sorry i dont no what kind of noise.....
Jan 31, 2010 | Washing Machines
Spin cycle doesn't work with loud noise
yea sounds like a bad motor coupling ( this machine equivelent to a belt).
Mar 06, 2008 | Whirlpool LSR7333 Top Load Washer
Whirlpool Ultimate Care Model LSR8233EQO - Loud noise during final rinse/spin
Sounds like the clutch, mi9ne works fine but is noisey when spinning, repair guy said it was the clutch.
Feb 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
208 people viewed this question
Dan Webster
Dan Webster
Sal De
