Question about Euro-Pro Blenders
Do the NJ602 parts fit/work with the NJ600?
Was considering buying the smaller blender housing/blade because no where I shopped listed the height of the unit. It doesn't fit under our cabinets.
SOURCE: how to install replacement part
There is a slit in the middle of the bottom of the blender. You turn the gear drive until the metal slot in the shaft lines up with the slit. Put a flat head screwdriver through the slit into the slot in the bottom of the shaft. Now hold the screwdriver to keep the shaft from turning and remove the gear drive. It took me a few tries, but it finally came loose.
Posted on Mar 02, 2008
SOURCE: Kenmore KMB048 Blender
1800KENMORE
Posted on Aug 22, 2008
SOURCE: Philips Hand blender
My wife picked ours up at a rummage sale, and we've grown to love the little thing for making single servings of banana milk shake. (half a frozen banana, cover with milk, a drop of vanilla, and about one minute with the hand blender blade!) When my youngest boys dropped ours, I gathered up the pieces of plastic that connect the attachments to the motor shaft, and carefully super glued them together. I then wrapped the plastic piece with fine nylon thread and a thin layer of super glue and placed it back onto the motor shaft, then let it sit for 24 hours. It is now permanently attached to the motor shaft and good to go. Too bad Philips doesn't care enough to support their customers with a part their engineers designed to break and save the rest of the product. I'll remember this about Philips products when I buy an HDTV.
Posted on Jan 09, 2009
cactus bob
  • 267 Answers
SOURCE: blender blade not turning, rotating piece on base not connected
this is getting more and more common there is a part between the motor and the drive gear that snaps for no reason . its job is to snap if the blades jam as a "fuse" to save your house from a overheating ,jammed motor . the problem is there are no parts to buy to fix this . if its new take it back to where you bought it . otherwise shipping it 2 ways for repair to the factory is sometimes as much or more as a new blender ........ i would recomend you do one of two things : go to a goodwill or other type shop and get a nice vintage blender , it will last forever ! or move up to a vita mix . its costly but it will realy last you ... this new made in china junk is just bad news even when it has the kitchen aid name on it . its still the same junk ..... good luck........ Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Posted on Mar 24, 2009
SOURCE: can't get drive coupling off bosch unversal blender blade fixture
what you need to do is hold the blades with a towel to protect your hand, then, use a visegrips needle nose to grab the coupling (pushing the guard down) and twist it loose. It may be very tight, when I loosened mine, the plastic portion of the coupling pulled off leaving the metal "nut" tight to the shaft. Either way, remove the coupling/nut in the standard "lefty loosey" direction. Many thanks to the people at pleasanthillgrain.com for walking me through the process. Blessings to you.
Posted on Jun 01, 2009
Why does my ninja blender power light blink red
-Make sure the lip is closed at the correct position and press down to lock before it let you turn it on.
Good luck
Mai
Jun 04, 2017 | Euro-Pro Ninja NJ600 Pro Blender - NJ600
Where do I find lids for the nj600 blender
Ninja Professional Blender . if this link works it will show the lid for the blender. If the link does not work, do a web search " Parts and accessories-Ninja. On the top menu, click on parts and scroll down to Ninja professional blender nj600 and click on it.
Jun 06, 2014 | Euro-Pro Ninja NJ600 Pro Blender - NJ600
How do I replace the knife unit in a krups type 243 blender?
Take the blade assembly out of the jug, hold the blades with a towel and turn the driving clutch on the other end. Whichever way the motor turns those blades when operating, you need to turn the drive the opposite way to undo it. If the nut is seized up and wrecks the drive the parts list shows all parts as being available EXCEPT the white bearing housing AND the complete assembled blade and housing.
May 16, 2014 | Blenders
Ninja blender motor part is wore out
-I don't think they carry any replacement parts for Ninja Blender.
-Possibly not the spline plastic.
-Inside on top of the motor there is a planetary gear there. Possibly worn out or lose screws as well that not hold it in place to mesh together.
-But before you can reach to these parts you have to take the bottom cover off, remove the plastic spindle. IT's very tight.
Good luck
Mai
Jan 11, 2018 | Euro-Pro Ninja 1000 Watt Prof Blender 3...
How to remove the top
are you pushing the handle release button on the lid, swinging the handle straight up and pulling on the handle straight up?
see page ten figure 6: http://www.ninjakitchen.com/manual/NJ600_30_IB_ENG_100527.pdf
Nov 10, 2013 | Euro-Pro Ninja NJ600 Pro Blender - NJ600
The power button is flashing red in my ninja nj600
Arrow on lid, Arrow on handle. Line them up. I just did it. I knew it was something simple but I didn't think it would be that simple.
May 29, 2012 | Euro-Pro Ninja NJ600 Pro Blender - NJ600
My kenmore blender stopped blending!!!
There is a gear underneath the blender blade. This connects the blade to the motor found on the base of the blender. This gear usually get worn out specially if the load that we are giving to the blender is beyond its limit. I hope you could by a spare on one of the electric shop near or might as well consider buying a new set.
Oct 06, 2009 | Kenmore Blender Single-Speed Blender
Blender blade not turning, rotating piece on base not connected
Mar 24, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Blenders Logo
136 people viewed this question
Top Euro-Pro Blenders Experts
Kolbrun...
Mai Lor
Tom Chichester
Are you an Euro-Pro Blender Expert? Answer questions, earn points and help others
