Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Ice/frost buildup & loud noise
My fridge has frost builup in the back of the bottom freezer drawer and makes a loud running noise
  • rdryan Mar 14, 2009
    Fridge making loud noise....run constantly and ice building up at back of freezer drawer. DO NOT BUY KENMORE
  • 6,784 Answers
This is classic compressor failure. the core is freezing due to unregulated pressure in the lines. repairing the compressor will correct this issue.
Posted on Mar 11, 2009
GE profile fridge making loud humming noise
The door being open so long caused warm moist air to collect and freeze inside the unit.
Take everything out, unplug it and let it thaw out for an entire day. All the frost will thaw, and probably run water all over the place so put towels down.
When you plug it back it, it should work fine.
Jul 26, 2014 | Refrigerators
8 year old Whirlpool Gold refrigerator: Freezer icing up. Found ice on shelves and on the bottom under the vegetable hydrators. The shelves and drawers constantly have a humid film on them. Last week,...
for no frost type;cleaning of freezer cub underneat is a must...cloggged drain outlet buildup thick frost on your freezer cub..
.ie..for frost type;you must set your thermostat setting to normal,replace it with new one
Oct 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Frost and Ice Buildup
If everything is cooling fine and the frost is not on the back wall but just the floor at the bottom then your defrost drain is stopped up. Remove the bottom basket and clean up the ice on the floor of the freezer. Look on the back wall and you will see some more ice up a littler higher at the back. This is where the drain is. Clean all the ice out from this area too using hot water or a hair dryer. Once you find the drain hole make sure you get all this ice out of it as well. You can take a screw driver once you have melted the ice and gently push it through the drain hole. Once the hole is cleared you should be able to pour hot water freely through the hole. (It is best to turn the refrigerator off while you do this)
Jul 01, 2010 | GE Profile PSS26NGS Side by Side...
Fridge w/freezer on bottom will not chill
What you have is probably a bad defrost heater element is my first inclination. I would look for frost buildup on the backside of the bottom drawer. That is a sure sign of defrost failure. And most defrost failures turn out to be broken heaters. The defrost heaters mount on the evaporator coils and simply heat the area for a few seconds to melt frost. If left alone that frost will trun into snow and then into air flow blocking slab of ice and fail fresh food cooling. I have a 3 door repair manual you may want to look through just to see what you are up against. To do this repair the ice maker and all the rails drawers bins and food must come out so you can get to the rear where the evap coil and defrost heater is located.
LG FRENCH DOOR REPAIR MANUAL
Feb 14, 2010 | Refrigerators
Build up of ice in bottom of freezer compartment
During the defrost cycle heaters in the wall of the freezer are turned on to melt the frost build up. This melted frost "water" is supposed to run out a drain in the bottom of the freezer and collect in a pan under the refrigerator/freezer where it will eventually evaporate. If this drain is blocked it will cause a lot of water to collect in the bottom of the freezer and that water will eventually turn back into ice. I recommend defrosting the freezer manually, removing all the ice/water buildup in the bottom, and trying to unplug the drain line to the pan underneath. Also check the seal on the freezer door. If it's not sealing well it could be letting a lot of moisture enter the freezer which would lead to more frost buildup and more water during the defrost cycle.
May 22, 2009 | Hoover HCA390FFK Bottom Freezer...
My Bosch frostfree fridge freezer keeps icing up!
My Bosch Frost Free Fridge Freezer did the same thing - Ice forming in the bottom of the freezer area after a few days.
It was caused by a blocked drain pipe - When the freezer does the de-frosting cycle, the melted ice drips into a tray and tehn runs into a dish on top of teh compressor, through a pipe.
If this pipe gets blocked, the de frosted ice overflows from the tray and overflows into the bottom of the freezer and then re-freezes !
To fix, pull the freezer away form the wall, locate the pipe that runs to the dish on top of the compressor and blow through it - This should clear it. Alternatively, from inside the freezer compartment, pull off the cover at the back, but the clips holding it on will probably break off, as mine did ! You can sort of push the cover back on and re-fit the food draws.
Feb 23, 2009 | Freezers
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
FRIDGE FREEZER BUT FRIDGE STOPPED WORKING FREEZER WORKING OK
look on the back wall of the freezer is there snow? if so you have a defrost component out (timer, limit, or heater) the fresh food compartment gets cool air from the freezer so check for blocked air pathways the build up of frost in the freezer stops air flow so you will be cold on freezer side and warm on ref side
Apr 24, 2008 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Kemore model 795.7731 bottom freezer
You are probably correct that it is the evap motor. If you are seeing frost on the back wall then there is probably some ice built up around the motor and the fan blade is hitting it.
Try defrosting the freezer and look very closely all around the seal for the freezer drawer. It is common for moisture to freeze in the self closers in the drawer rails and not let the drawer close completely on one side or the other. If this happens the small gap will allow the freezer to frost excessively.
Sorrry to be slow in responding. I have been very busy this week and have not been on line very much.
Mike
Apr 10, 2008 | Refrigerators
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
478 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
