Question about Magellan Maestro 3225 Car GPS Receiver
I lost the small part where you plug in the power supply cord into the magellan
Can I buy this anywhere?
3 Suggested Answers
SOURCE: Lost fuse to Magellan 4250 and cannot find another for sale
I had a similar problem with a Mag. Maestro 4040. I searched high and low for the 4.6 x 16mm fast acting tube fuse 2a 250v. I called Magellan and they would not sell me or tell me where to find this fuse. Needless to say, I found it for $1 at Wayne Electronics in Wayne, NJ. Call them to see if they have the fuse you are looking for.
Posted on Nov 30, 2009
  • 7 Answers
SOURCE: Magellan Maestro 4250 fuse
It is a Fast Fuse Glass type 5 x 20mm, 2A, 250v. Magellan 4250 can only take 1A of current at 5Volts Radio Shack
Posted on Feb 08, 2010
Lost power supply chord to a general electric power amp. and it has no model number
those things usually use a universal desktop-type computer cord that you can find anywhere: Radio Shack, Walmart, Target, Best Buy, etc...
Oct 28, 2013 | Music
I lost power in my house. I cannot get the TV to power up. Is there a reset button? what do I have to do to get power on the TV? All the other components linked to the TV are working.
Now,there is no power to the tv at all?Yes.Tries tv unplug,replug it back like about and hour later.That the resetting tv back to the factory setting.The tv now should be working again.If tv still have the same result,tv power supply board have problems,that the board,where the power a/c cord plug into it.Check the tv power supply board fuse,because u lost main power to the house.If u lucky,the tv power supply board only have a dead fuse,fuse is near where the power a/c plug,plug into tv to get it power.Fuse can buy it anywhere like Radio Shack like $1.50.After u repalced the fuse,if tv still getting the same result,than sorry ur whole power supply board have problems and it is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Feb 23, 2011 | Samsung LN52A850 52 in. LCD HDTV
TV lost its power. will not turn on. Tested power cord and its fine.Plugged into another outlet and still will not turn on.
The tv power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 12, 2010 | Protron PLTV-32 Television
Power cord is not charging unit. There seems to be a loose fit in the socket of the Magellan Maestro 4000. Is the problem with the charger cord or the Maestro 4000 socket?
its probably not charging...very common problem with this and many others.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040,4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
or buy the port here
if you need further help, just let me know.
Oct 09, 2009 | Magellan Maestro 4000 GPS
When I plug it in to the powere cord no lights appear to show that it is charging. Is it completely Dead?
pull the battery and check it with a dc power meter that measures voltage if you got low/no power you'll have to buy another battery/ also try using the power cord w/o the battery installed. it theres no light anywhere means the ac power converter /supply has died.
Jul 09, 2009 | HP Pavilion ze2000 Notebook
Jun 10, 2009 | Magellan Maestro 4250 GPS
The hole of +- joint for external connection cord was broken
I have found my friend who is very familiar in electionic and small appliances to help me. I can fix it too, but unfortunately I do not have any soldering tools and parts here. I will bring it to Hong Kong and let my friend to fix it. It's very cheap if we find anyone to fix it in China where Magellan is assembled . Thanks.
Dec 28, 2008 | Magellan RoadMate 800 GPS Receiver
Brand new Magellan Maestro 4000 does not turn on or indicate powe
I had the same problem and I solved it by cutting a few strands of speaker wire and twisting them together and inserting them into the center of the generic car gharger end which plugs into the Maestro 4000, It seems that the 4000 has a very small center conducter on the GPS itself and by adding a few strands of speaker wire about 1/2" long into the plug before pluging it into the 4000 it allows it to makes contact with the small power inlet conductor which is smaller than most generic cigarette lighter 5vdc power cords. I did this to mine and it powered up right away. The other solution is to buy the actual car power cord from Magellan which has the proper size connecton and makes proper connection all the time.
Dec 24, 2008 | Magellan Maestro 4000 Handheld GPS...
Missing small adapter part
Hi marshaw40,
I'd recommend you attempt to contact Garmin support to see if they can supply you with this part. Their phone number is 1-800-800-1020 (U.S.). If they are not able to supply the part by itself then you may have to purchase a new power cord for the unit.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 10, 2008 | Garmin StreetPilot C330 GPS Receiver
Lost power supply
Yes, lcdpayless.com has this kind special power adapter. You can just search it by model# SDM-M81 at the homepage.
or just click as below link and check it out.
http://lcdpayless.com/productpage.php?productId=4125
Apr 10, 2008 | Sony SDM M81 18.1" LCD Monitor
Magellan Maestro 3225 Car GPS Receiver Logo
19 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
