Question about Carrier 38CKC042 Air Conditioner
Carrier air conditioner model 38yca030370, need to know what kind of capacitor it needs?
Ours went bad the HVAC guy took ours after he diagnosed the problem but attempted to charge $180 to replace
  • 31 Answers
Have him bring the old one back as it is yours. Check for the megaferons it has and the capacitance rating. Problem is hooking up thie wires needs to be done with knowledge of the system. $60 for a capacitor, $1200 for a blown compressor if hooked up wrong. You decide
Posted on Apr 23, 2013
yalmer
  • 549 Answers
SOURCE: Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Posted on Feb 25, 2008
  • 189 Answers
SOURCE: air conditioner replacement--new size required?
567C024RCU In this model number is the # 24. That stands for 24,000 btu's. This is a two (2) ton unit. Has this two ton unit cooled ok in the past? if so replace with the same size. But make sure yo change the indoor coil to match the size "and" efficiancy of the ew unit.
Posted on Apr 14, 2009
  • 340 Answers
SOURCE: I have a Carrier 38ckc036350 Air conditioner. The
Have you checked your circuit breaker? Capacitors are located in side the unit in the control box. TURN OFF THE POWER. you need a capacitor checker i assume you have one if not have a qualified service person check it out you'll be money ahead in most cases. good luck Tom
Posted on Jun 28, 2009
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Posted on May 21, 2010
SOURCE: Carrier 42QG24-C / 38QG24-C 24000 BTU SPLIT AIR
i want know that how can connection wiring of indoor panel and out door panel 0f carrier 42qg24-c / 38qg24-c ?
(i need wiring diagram)
Posted on Jul 06, 2010
My HVAC guy installed a Honeywell non-wifi thermostat that cost $248!! It doesn't seem any different from the ones that sell for $80. How do I find out what makes this TH6320U100 the Lexus of thermostats?
Try going to www.manualslib.com and
entering Honeywell TH6320U100
They return with five manuals, one
is WiFi ( you say your unit is not )
choose one of the other four....
We'll hope your HVAC man is not
just greedy. Good luck !
Apr 08, 2017 | Honeywell Heating & Cooling
I HAVE CARRIER AC MODEL NO. 38HQR18UP30-03, WHEN START THE AC ONLY THE INSIDE BLOWER IS STARTING OUTSIDE UNIT FAN AND COMPRESSOR DOESNT START.....
It could be a number of things. Check breaker panel inside your house for flipped breakers. Check for bad fuses and check your capacitors. But only if you know how to use a multimeter and shut the power off first and understand how to de energize the capacitor. Otherwise call an electrician of hvac professional. Otherwise doing so can be deadly if your are unsure of electricity
May 17, 2016 | Carrier Heating & Cooling
Would a bad speed sensor cause auto trans to to shift irratically and engine not idle?
We had the same problem in ours and the shifting was not affected. Also, engine idling was fine. When we changed ours, the only thing that changed was the check engine light went off. If your light is not on it could have to do with the transmission and a mechanic is best suited for diagnosing that.
Jun 27, 2014 | 1993 Toyota Corolla
Carrier HVAC model 58sta090 filter size?
Carrier Furnace Model 58STA090-16120 (58STA09016120 ...
www.repairclinic.com/.../Model-58STA09016120-Carrier-Furnace-Filter...
Carrier Furnace Model 58STA090-16120 (58STA09016120) Filter Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Carrier HVAC model 58sta090 filter size? - Fixya
www.fixya.com/.../t11662616-carrier_hvac_model_58sta090_filter_size
Feb 12, 2012 - Carrier HVAC model 58sta090 filter size? - Air Conditioners ... Main house central air? = 3 tons ... I assume the filter goes in at the bottom of the air ...
CARRIER Base 80 Furnaces
Feb 12, 2012 | Heating & Cooling
D4 LIGHT WAS FLASHING...SO I TOOK MY 93 HONDA ACCORD TO THE DEALER. THEY PERFORMED A MULTI-POINT INSPECTION AND FINALLY REPLACED THE TRANSMISSION CONTROL UNIT, DID A COMPLETE FUEL SYSTEM SERVICE AND...
When our speedometer and odometer went out it in our 94 honda accord it was due to our vehicle speed sensor being bad... once we replaced it with a new one, everything worked fine. I'm not sure about the rpm indicator though because that wasn't affected in ours... I hope this helps
Sep 19, 2011 | 1994 Honda Accord
Compressor just stopped working, does not cyle on for cooling
1. Is there high voltage(240 volts) power to the condensing unit?
2. Is there low voltage(24 volts) to the contactor?
3. Is the contactor pulled in and allowing 240 volt power thru?
4. Does the capacitor look burned or misshapen, is the top of the capacitor domed up?
If so the capacitor is bad and needs replacing.
If you have all the above items and the capacitor is good(the condensor fan should be running) and the compressor is still not running, then you need a professional to diagnose why the compressor is not running.
Sep 02, 2011 | Carrier 38CKC036 Air Conditioner
The problem of my unit carrier split type air-condition are about capacitor because i can't determine the voltage and wattage its all erase so i need your help to determine the details about this kinds...
it doesnt work that way. If the cap is metal it is a run cap, if its plastic its a start cap. I need to know the compressor name and the model number and I will tell you what to buy. Hope this helps.
Jul 08, 2011 | Carrier 38CKC042 Air Conditioner
Carrier model 38txa024300 ,condesor fan wont oporate with compressor unless the fan is spun befor energizing . is it the dual run capacitor that is bad? thanks for any help. jeff
If the fan spin freely then the capacitor could be bad. Otherwise, if it spin with difficulty then it need to be cleaned and lubbed.
May 22, 2011 | Carrier 36KCARMS Air Conditioner
When the air conditon unti is turn on the unit only hum. I f you turn the fan it will start turning. carrier 38ck024330
In most cases, the fan has a capacitor to assist in the starting. Check if the capacitor has a bulge or is leaking. If so, it is bad. Although, even if the power is dissconnected, THE CAPACITOR HAS A HIGH VOLTAGE CHARGE STILL IN IT! Discharge the capacitor by shorting the two leads together with an insulated screwdriver. Remember, if not comfortable, call a certified hvac technition. In some cases, if no bulge or leaking is obvious a tech will have a microfare tester to further test the capacitor.
Mar 19, 2011 | Carrier 38CKC060 Air Conditioner
Whenever it rains my 2004 Hyundai Santa Fe will not run well. Today it sputtered and died several times. Now its running again that it has dried out. What is causing this?
We went through this with ours recently. Hyundai diagnosed it as a bad crank shaft position sensor. We replaced it and we're up and running again. Not sure why the damp weather affected it but it did.
Sep 20, 2010 | 2004 Hyundai Santa Fe
Carrier 38CKC042 Air Conditioner Logo
130 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
