Question about Toshiba Satellite Computers & Internet
I used the restore where you hold down the zero and turn on and now my schoolwork is lost forever. Cant get the laptop to stay on? Doesnt even make it to the sign on screen.
The computer comes on for about 2-3 minutes and then it shuts off, All my school work is in there, Please help if you can.
  • Toshiba Master
  • 32,281 Answers
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Posted on Apr 21, 2013
  • 9 Answers
SOURCE: Macbook - screen white/blank after turning on
Sounds like it could be a corrupted OS; have you tried forcing it to start up with the OS disk, holding down the 'C' key? That's the first place to start...
If it won't start up like that, you probably have a hardware problem. (You can get excellent troubleshooting guidance at: http://www.ifixit.com/Guide/Mac/ ) depending on your level of geekness, and assuming the warranty is expired?
Good luck
dennismacfreak
Posted on Nov 17, 2008
  • 148 Answers
SOURCE: toshiba satellite x205-s9800 - Frozen boot screen
hi,
try this one
take out the battery and take out the Ac adapter now press and hold the power button for 15 sec this will release any static charge residing in your laptop.
now try start your laptop with battery in.
Further Queries are welcome
Posted on Feb 20, 2009
  • 10 Answers
SOURCE: My dell inspiron 1525 shuts off with no warning,
you can try blowing compressed air to remove dust from cpu heatsink and fan may be an overheating problem
Posted on Aug 08, 2009
SOURCE: I have a lenovo laptop, 3000 G410.
Hi every one.i have a lenovo 3000 g410.Suddenly the screen gone black and it doesn't restore yet .can you help me with this?
Posted on Dec 02, 2009
aquif1990
  • 190 Answers
SOURCE: MY LAPTOP IS ACER ASPIRE 5315/2492 WINDOWS
it seems u have done every try.So now i recommend u too backup ur necessary files and install a fresh copy of windows via cd.
I recommend u to use xp or windows 7.
Posted on Mar 31, 2010
Asus x553m laptop wont turn on fully?
Just before it tries to start windows, go to safe mode, press F8 and select safe mode, you may need an external keyboard. That will enable you to restore the faulty/damaged files.
Jun 14, 2016 | ASUS Computers & Internet
How do i restore my wife's labtop back to the factory settings and erase everything. I've tried a lot. I'm lost now.
Most laptops come with a "rescue disk", or let you create one. Boot off the rescue disk. It will wipe everything, and return the system to the way it was when you first got it.
Aug 29, 2015 | Computers & Internet
Need restore
The way to restore Gateways is to hold down the ALT Key and repeatedly hitting f10 then it should bring you to a boot sequence screen then choose the HDD and then hold down ALT and repeatedly hit f10 again that should promt the restore feature for gateway. If that doesnt work the only way to do it is to boot into windows and run the eRecovery program.
Jan 21, 2014 | Gateway NE56R10u Laptop Intel Celeron...
System restore factory settings no cd
Toshiba has built in system recovery partition in your hard drive
Make sure to back up important files in your Laptop to usb or portable hard disk before doing this.
Warning: In using System Recovery you files will be deleted, your laptop will be back to its factory settings
To access the Toshiba recovery partition, power off the laptop. Hold down the 0 (zero) key and turn the laptop on. Keep holding down the zero key until the TOSHIBA logo appears, where you should start tapping the zero key repeatedly. Stop if the unit beeps or when the TOSHIBA logo disappears. The screen should flash ** HDD RECOVERY MODE ** for a split second, then load the Toshiba recovery program right from the hard drive.
Feb 01, 2011 | Toshiba Satellite A45-S120 Notebook
I need to preform a system reboot/ restore for aSONY VAIOPCGGR250
Holding zero is the method for restoring Toshiba computers. Sony Vaio should use F10. From there you can do a full system restore to factory defaults.
Hope that helps :)
Apr 14, 2009 | Sony VAIO VGN-FJ270/B Notebook
I have to use my windows xp disk to boot my laptop tried everything to fix it
pls try to repair ur system thru ur backup OS disk which u r using to boot so u see ur desktop or u see only recovery console like thing u can always restore ur system to factory default but first try to repair it thru backup disk see if it works other wise let me know abt it
fast way to restore to factory settings
Toshiba: BEFORE TURNING ON THE LAPTOP, press and hold the 0 (zero) button on the keyboard, then turn on the computer while holding the 0 (zero) button down. When the Toshiba logo screen appears, you can release the 0 key.
pls rate me FIXYA for this if u like
Mar 13, 2009 | Toshiba Satellite A10-S169 Notebook
Sattellite A205-S4577
pls restore ur system like this pls rate me FIXYA for this help
Mar 06, 2009 | Toshiba Satellite A205-S4617 Notebook
Laptop wont boot toshiba logo stays on forever
Put Your Restore Cd Or OS Cd in and press and hold F8 to choose to boot to cdrom.. then Repair your OS Start up...
Or try pressing F10 on boot up to go into built-in restore options
Nov 19, 2008 | Toshiba Computers & Internet
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
