Question about JVC Zenkuman PFW-41 Video Capture
Major problems with JVC Zenkuman PFW-41 Video Capture
Hi There! I have an old camcorder, model is a JVC GR-DVL150E . I would like to know if its possible to transfer my footage from the tapes on to my PC and save it to discs! if so how do i do this and what...
You need to buy USB 2.0 Video Capture Adapter Card to do this action..
Pls visit the URL below as an example..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
EasyCap USB 2.0 Video Capture Adapter Card TV VHS DVD Capture high quality audio and video through your PC's USB port. Capture playback from VHS, Camcorders, TV, etc; capture audio without a sound card! Supports NTSC, PAL, Video format. NTSC: 720 x 480 @ 30 fps PAL: 720 x 576 @ 25 fps.
http://cgi.ebay.com/EasyCap-USB-2-0-Video-Capture-Adapter-Card-TV-VHS-DVD-/360339776240?pt=LH_DefaultDomain_0&hash=item53e5eca2f0
Jun 26, 2011 | JVC Video Cameras
JVC GY-HD100 is unable to capture to final cut pro. It shows "no communication" in the log and capture window. But It will capture useing IMovie with no problem. This creates an extra step in my...
You should select the Easy Setup preset that matches the cameras output before capturing.
You may need to start a new project for the Easy Setup to take effect.
Mar 03, 2011 | JVC GY-HD100 Mini DV Digital Camcorder
HOW TO LOAD VIDEOS FROM JVC VIDEO CAMERA?
Do you have the drivers that came with the camera? If not tell me and I will see what I can do.
Ryan Frame
Creative Energy Associates Technical Center
Aug 23, 2009 | JVC Video Capture Box GV-CB3U Video...
Connect old camcorder to new PC
JVC has the support page for the GR-SXM260U here: http://support.jvc.com/consumer/product.jsp?modelId=MODL027120&pathId=25&page=3&archive=true. This camcorder can be connected to a TV with the S-video connection (JVC recommends their YTU94146A S-Video cable) or two RCA connections. If you use an RCA composite cable, you use only one of the two audio connections (white) and the yellow video cable.
To connect this camcorder to a computer, you need a USB video capture device and some type of video capture software. Here are two examples: https://www.amazon.com/Diamond-Multimedia-VC500-Video-Capture/dp/B001FAE8MA and https://www.amazon.com/ION-Analog-Digital-Converter-Composite/dp/B002MT7JFQ .
I hope this helps.
Jul 05, 2017 | JVC GR-SXM260U Camcorder
How do I transfer video from JVC GR-DVM70 to computer.
The only way transfer video is using a "capture card"...This device which can be fixed on to a computer can capture any video inputs....
< PLEASE RATE ME AS FIXYA >for my help......................
Jul 31, 2008 | JVC Televison & Video
MY JVC GY-HD100 Wont capture properly in Final Cut Pro. Always shows time code breaks where there are none. Only capture a minute or two at a time. What can I Do?
Are you shooting 24p? Make sure you're using the correct capture presets. DV NTSC 48k 24Pa (presuming you're shooting 24p advanced)
if this doesn't help, close final cut and delete your com.apple.finalcutpro.plist file from library>preferences. This should solve additional cadence problems.
Apr 08, 2008 | JVC GY-HD100 Mini DV Digital Camcorder
Can't transfer video from cam to pc
You can't capture the video with a USB cable. The USB cable and software that came with the camcorder are only used to transfer still images.
To transfer video you'll need a DV cable (also known as a Firewire cable) and some additional software. I use Scenalyzer Live. It's not free, but you can download a demo copy to see if you like it before you buy it. Here's a link to the Scenalyzer website:
http://scenalyzer.com/
If you have the JVC manual you should read page 41. If you don't have the manual you can download it here:
http://www.devicemanuals.com/guide/Digital%20Camcorder/JVC/JVC-Compact-VHS-w-LCD-Screen-Camcorder-GR-D370AS-User's-TWpJME56VT.html
The download link is about half way down the left side. It's a little difficult to find, but it's there.
Lastly, all this assumes that your computer has a Firewirre port. Most new computers will have one, but if you do not you'll need to buy and install a Firewire PCI card. Let us know if you need more help.
Dec 04, 2007 | Video Cameras
JVC GR D250U
This camcorder should not require a driver in order to capture the footage. Start up your capture software, power-up the camera in VCR mode and then connect the Firewire cable. It should then allow you to playback the tape and capture the contents.
Here is the manual online:
http://resources.jvc.com/Resources/00/00/94/LYT1353-001A.pdf
If you need a simple program to capture the footage look to: http://www.virtualdub.org/
Your video-editing software (including Windows Movie Maker) should also capture the footage.
Nov 17, 2007 | JVC Everio GZ-MG21 Camcorder
GR-D350u driver problem
how do we get the software somebody just put it on the internet
Oct 13, 2006 | JVC GRD250 MiniDV Digital Camcorder
JVC Zenkuman PFW-41 Video Capture Logo
32 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
