Question about GN Netcom GN 8000 MPA Mulitpurpose Amplifier Headset
Interference on the line.
We just bought new GN 8000 MPA amplifiers. We started to use them you hear alot of interference. Also the people in the other end cannto hear us. We are using a digital phone system connected to a analog converter.
SOURCE: The other side cannot hear me.
Hi I don´t speak a good English but a question for you ¿You tested a microphone of you system? you can probe to interchange the handset may be it can solve the problem
Posted on Apr 12, 2007
SOURCE: GN 6210 with home cordless phone?
try
http://audio.manualsonline.com/search.html?q=GN+6210
Posted on Dec 07, 2007
SOURCE: Cannot hear anything out of the earpiece of my GN netcom 9120 wireless headset
I was also experiencing the same problem (also after a power failure / storm) -- apparently good battery charge, connections ok, etc. I then tried removing the battery from the headset itself, waited 30 seconds, and then reinstalled the battery. This seems to have resolved the problem.
It is fairly easy to open the clamshell, but you will need a very fine Phillips screwdriver to remove the battery hold-in (it's really not a hold-down, it just keeps the battery in place. Reassemble the same way -- be sure to keep positive to positive and negative to negative.
Posted on Jul 16, 2008
Peter Denton
  • 16 Answers
SOURCE: New Phone Causing Echo
It sounds like your microphone volume is too loud. Get someone on a call with you so they can tell you how it sounds as you adjust it. Turn down the mic volume by pressing the + & - buttons on the earpiece together once which puts the earpiece into mic adjust mode. Then decrease the mic volume by pressing the minus button a few times until it sounds right. The earpiece will automatically revert to normal mode within a few seconds.
If this doesn't work it may be that you need to adjust the compatibility setting for the new phone. This is the small black dial on the base station. The most common setting is 'A' but you may need to experiment with other settings for that phone.
Posted on Nov 05, 2008
  • 4 Answers
SOURCE: GN 1000 lifter/GN9350 headset with Nortel NTDU92 phone
I was wondering if you had installed the external ring sensor, this sensor most be over the telephones speaker, if the speaker isn't under the handset. hope this can help.
Posted on May 28, 2009
What Error
What's the question? We really need more information.
Feb 20, 2015 | GN Netcom GN 8000 MPA Multipurpose...
How much gain does GN 8000 provide
Define what you mean by gain, in volts, db what?
Jun 25, 2014 | GN Netcom GN 8000 Amplifier
Voip settings
I've been having the same issue, I tried playing with the channel slider switch on the right side (letters A - I) and one of them worked for audio and mic. D was the magic letter for me, could be diff for you.
Feb 28, 2013 | GN Netcom GN 8000 Amplifier
I have a GN Netcom 8000 and I hear a beep in the headset every 12 seconds. Any ideas why?
Had the same problem with mine did not realise that there are batterys in the unit and they are going flat. Open the top and look on the right side, there are 2 aaa's inside. Replace those and you should be fine
Sep 16, 2010 | GN Netcom GN 8000 MPA Mulitpurpose...
BMW M3 E46 Stereo whine
What you are hearing is ground loop interference. If you have an aftermarket headunit/amplifier this is a common occurrence. A ground loop isolator in line with the low level amplifier inputs should solve the problem. Otherwise, it may be a malfunction of the stock cd unit or amplifier. BMW used a balanced input on some of the stock amplifiers, which would make ground loop interference all but impossible.
Apr 18, 2009 | 2002 BMW M3
DTU 16D-2 Corded Phone
headset key has to be programmed on a key for it to work properly
Jan 23, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Echoing
lower the volume of your mic.
Nov 15, 2007 | GN Netcom GN 8000 Amplifier
Jan 08, 2007 | GN Netcom GN 8000 Amplifier
GN Netcom GN 8000 MPA Mulitpurpose Amplifier Headset Logo
50 people viewed this question
Top GN Netcom Radio Communications Experts
TO Lady
bigdawg7299
Tom Chichester
Are you a GN Netcom Radio Communication Expert? Answer questions, earn points and help others
