Sony bravia KDL46EX723 shuts off or won't turn on at all
bwery3
  • 137 Answers
SOURCE: Our Sony Bravia Tv was
If theres absolutely no power and no lights on, it sounds like the fuse inside the t.v.. It is pretty easy to change. You have to take out the screws on the back of the t.v. and take the back cover off. Look for a 3/4" glass tube fuse and see if the tiny wire in it is broken. Pop it out and bring it to radio shack and get a new one. Put that one in and try it, Make sure the t.v. has been unplugged for at least 2 hours before opening it so the capacitors have time to drain. They will hold power and could shock you if your not careful. Also, dont use anything metal to take the fuse out.
Posted on May 15, 2011
  • 56 Answers
SOURCE: My Sony bravia kdl55hx800 lcd 3d tv won't turn on
try unplugging your t.v for a few minutes, then plug it back in. if it continues check your owners manual or google your issue. this might be the red flash of death. hopefully unplugging it works. good luck!
Posted on May 18, 2011
  • 25 Answers
SOURCE: Sony Bravia KDL series 52"
Check the fuses on the power board. there is one fuse on primary side and one on secondary side.
Take of back panel and follow plug into the tv.where it ends is the power board.always use caution.the capacitors in there hold high voltage even after unplugged for a couple of days.Discharge capacitors before servicing the board.
Posted on Jun 28, 2011
caroldon
  • 17130 Answers
SOURCE: hi i getting a flashing
In most cases the standby light might blink with different rapidity to indicate a fault relevant to the processor. It is possible that most of these indicate that there are errors in the processing section . Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multimeter to check the continuity or shorting in components, if so detach from circuit and test . If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail.
http://focus.ti.com/docs/solution/folders/print/387.html
The processor must have the +5 voltage to the function properly , the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail.
Check for tips to check the SMPS unit:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Thank you for using fixya.
Posted on Sep 06, 2011
  • 11800 Answers
SOURCE: Sony bravia DVD disk won't
Mechanical failure of the tray's mechanism - the clicking you hear is made by the wheel on the motor of the tray skipping over its eject lever.
The mechanism will have to be extracted from the tv as a whole then dismantled to see if the wheel can be reattached to the lever. If that is impossible (both plastic parts have been damaged) then the entire mechanism is dead and it will have to be replaced.
Since this is a brand new model and you bought it a few months ago it means that it's still in the warranty period. Because of that the entire repair/ replacement of the BR unit will be done for free by the dealer. Under no circumstance you should attempt to fix it yourself - opening the tv or forcing the unit will void the warranty.
Posted on Sep 15, 2011
Sony bravia model number KDL46EX723 blinks two time and wont turn on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 10, 2014 | Sony " 46"" Class - LED - 1080p - 120Hz -...
Sony Bravia LCD tv model KDL40S4100 won't hold settings.
What you've heard is right. This is a main system control memory IC fault itself.
Jun 19, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony bravia won't stay on 52w4100, clicks with green light three thimes then shuts off and blinks red 6 times
Sounds like a power board reset switch gone bad. Have the power board replaced.
Good Luck Ed Pinero
Feb 03, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I have a Sony Bravia LCD tv an it won't turn on at all the standby light is not even there I've tried turning on an off and leaving unplugged for an hour still nothing.? Help,
You either have a problem with your power supply board or main board. I would start with having the power supply fuse checked as well as the power supply board!
Jan 26, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
My sony bravia model number kdl 46ex723 blinks four times what that mean
Solution for Sony Bravia KDL 46EX723 blinking red light 8 times. Information below is from Sony online support, it worked for me:
Please disconnect the Internet connection from the TV and your TV will work fine.
We are suspecting a network outage issue on Sony device, we are currently investigating this issue. I am really sorry for the inconvenience caused.Unfortunately we don't have any ETA on this,I request you to try at a later time.
Nov 18, 2012 | Sony " 46"" Class - LED - 1080p - 120Hz -...
Bravia NX720 55
I have the same problem, called sony up but they are not responding back. The tv is still under warranty and brought it from Amazon. My situation is same but my led error code is 4 or 5 flashes. Does any one knows what's wrong with it.?
Sep 09, 2012 | Sony KDL46NX720 - 46" BRAVIA NX720 Series...
Tv won't turn on. Blinking in standby in red. Won't start
This is an indication of protection error and might require attention of a qualified service technician.
Aug 17, 2012 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
My sony bravia klv40ex600 won't turn on,the light indicator for power,volume and channel is on, the screen is still black
Hi, have you tried pressing the TV button that is under the On/Off button on top right hand side of remote control? Some times its possible to accidently press the DVD or VCR controls and this by-passes the TV as a remote?
Another cause can be a poor or low battery in the remote itself. If you have no luck let me know & we can try some more things, however, I have heard that The On/Off Switch on the TV can be a problem. Goodluck, Jon..
Jul 22, 2012 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Tv Bravia won't switch on for days, when on only white light and sound no pictures. Help
I think fault is in electrolyte capacitor.You should check the supply volt of cathode & all relative component of RGB input.
Jan 12, 2012 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony Bravia SXRD KDS60R2000 won't turn on
May I know if there's a led light lit solid/blinking. If blinking, count how many times it will flash.
Oct 26, 2011 | Televison & Video
Televison & Video Logo
136 people viewed this question
Top Televison & Video Experts
