Whirlpool duet flashing f and h - Washing Machines
    President:
  • Washing Mach... Master
  • 662 Answers
First try turning off the machine for 30 minutes. Then check your inlet valve. Shut off valve, switch off machine & see if the water comes full flow. Check the fine filters on the machine inlet entry, they could be blocked, clean out.
The FH indicates a fill failure and this is usually caused by a bad water valve, flow meter or pressure switch.
One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within 1 or 2 minutes then the most likely cause will be the water valve or flow meter.
If the error doesn't appear for several minutes then the pressure switch can be the source of the problem.
Both water valves must be turned on and working. Even if a cold wash is selected at some point during the fill the hot water valve will be energized and if there is no water then the FH error will show up. Sometimes a consumer will turn the hot water valve off to save energy but you can't turn one valve off on some washers.
Inlet valves can be purchased thru the net and fitted by you easily.
Click if helped pl.
Posted on Apr 25, 2013
It starts and then stops and then F28 flashes
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
Not good! Probably motor control board or motor or wiring harness from control board to motor.
This leads to a Kenmore Video
Whirlpool, Maytag, Kenmore. Same machine different name different trim.
Whirlpool Duet f28 YouTube
Sep 21, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Gas Dryer, runs about 2 seconds then shuts down. Time remaining display flashes
raoul answered just now
come fare il reset della scheda della lavastoviglie whirlpool ADP 5555 per cancellare un errore dovuto a sensore sporco? non vorrei chiamare l assistenza solo per questo.
Grazie
Feb 06, 2014 | Whirlpool Duet GHW9150P Front Load Washer
I tried to start a load and an F-1 code flashes. I have a Duet Sport front load washer (2 years old).
Go to the Whirlpool webside and download a manual for free. They are good folks.
Here is mine...
https://secured.whirlpool.com/Service/.../Duet%20Job%20Aid.pdf
G.
Apr 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport front load washer
the panel below the door has 3 screws under the bottom lip of the panel. remove the screws to get the panel off youll see the pump right in front of you. you can unscrew the cap on the pump and remove it to clean out the punp. thats where 99% of clogges are on that washer
Nov 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
