Question about Whirlpool Washing Machines
Whirlpool AWM8121 says Door is open and will not wash. Is it Microswitch of something else.
  • Whirlpool Master
  • 2,479 Answers
Let'[s hope that is it.
These switches are made of plastic, and are really cheap.
It should be fastened with screws to the inside of the top of the machine, which you will need to open to access.
Be blessed.
Posted on Apr 21, 2013
Testimonial: "Thanks David. Have changed Microswitch Unit and it is all OK now. I had the same Problem with a Samsung, which is also OK now after fitting a new Microswitch, but the Samsung had burnt out where the Connector from the Loom attached to the Switch. As this was a special Connector, I had to remove it and replace it with 3 separate Spade Connectors. "
  • Howard Smith Apr 22, 2013
    Thanks David. I assume the Microswitch is just inside the Cabinet. Can it be accessed by removing the Rubber Seal Ring?
  • David Ellis Rhea Apr 22, 2013
    Probably you will need to open the top of the machine and take it out from the back. Be blessed.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
There's another listing on that may help. See:
http://www.fixya.com/support/t810804-whirlpool_awm8121_door_open_light
Posted on Oct 15, 2015
5 Suggested Answers
SOURCE: AWM8121 Drain/Spin cycle stops
it seems to point to blockage in drainage pipe from drum likely to be a lost sock remove pipe and check
Posted on Jul 05, 2008
  • 1028 Answers
SOURCE: I have a Whirlpool front
try removing dispenser drawer completely and cleaning thoroughly there may a buildup in drawer preventing the bleach from completely dispensing properly at the proper time ..press tab down on left rear corner to completely remove entire assembly
Posted on Aug 19, 2008
  • 4 Answers
SOURCE: Whirlpool AWM8121 ?door open? light flashing
I had the same problem about a year ago, I replaced the door switch but didn't fix it, I found the brushes in the motor has worn out - Replaced the brushes and fixed the problem.
Posted on Dec 13, 2008
  • 1531 Answers
SOURCE: whirlpool frontload washing machine door will not open after the
if there is still water in the washer you can use a wet dry shop vac and attach it to the end of the drain hose.Once all the water is removed from the washer you should be able to open the door.
then you need to check the drain pump for anything that may be obstructing the pump. make sure to check the hose that leads from the bottom of the tub to the drain pump.
Posted on Jun 21, 2010
How to fix a door that wont open whirlpool GT1195SH microwave
the door's microswitch acticator maybe defective ... call for tech asstance
Aug 04, 2014 | Whirlpool GT1195SH Microwave Oven
Where to put washing detergent in Whirlpool AWM8121?
Simply place detergent into wash ball and place inside drum on top of clothes,,,,fabric softener goes in smallest compartment in tray
Jun 20, 2013 | Whirlpool Washing Machines
WHIRLPOOL AWM8121 WATERVALVE PLEASE
http://www.whirlpoolparts.co.uk/?searchStr=AWM8121/S&_a=viewCat&Submit=Go
Jan 07, 2013 | Washing Machines
We have a Whirlpool 7KG frontloader washing machine (6th sense) model AWM8121. The problem is that the door light is flashing, the cycle has stopped at rinse (rinse light is on) and the machine is not...
We have an awm8121 and there seems to be a fault on the Spin cycle indicators with th 0 RPM and the 800 RPM flashing..
We can't seem to get the frontloader to finish the drain cycle and continue into the next was.
The last load of washing was still saturated when we managed to open the door.
Apr 20, 2011 | Whirlpool AWM8123 Front Load Washer
I used the self cleaning on my Whirlpool Gold, Accubake System. After the cleaning the door would not open. Eventually we found a latch we could move with a knife and open the door. But now when I start...
Either the lock needs to be replaced or the microswitch. By opening the door manually, you have bypassed the disengaging of the switch. The cooker still thinks the door is open.
Dec 10, 2009 | Washing Machines
Whirlpool AWM8121 stops working mid cycle. Bottom two lights flashing on spin speeds.
Fault code 3 = Drain failure or not detecting empty drum.
Check pressure switch, blocked drain, drain pump.
See link below for service manual.
http://www.user-manuals.com/advanced_search_result.php?keywords=857081253000&forward=plist
Oct 24, 2008 | Whirlpool AWM6120 Front Load Washer
I have a Whirlpool front loading washing machine (model AWM8121). We keep getting sporadic bleach marks on our towels and clothing when we take them out of the washing machine. Any idea what might be...
Aug 19, 2008 | Whirlpool Washing Machines
Bearing replacement
hi there,
just wondered if you found a solution.
thanks
Jul 28, 2008 | Whirlpool AWM6120 Front Load Washer
Jul 05, 2008 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
282 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
