Question about Sennheiser HD 201 Consumer Headphones
HD201 will not work with pc
Mac keyboard not working through SV211KDVI on windows
Chances are that the distance between the keyboard & the PC computer is attenuating the signal of the keyboard below the threshold (or level) required for interfacing with the PC computer.
Perhaps a shorter KVM cable between the KVM unit & the PC computer could be helpful.
Jan 18, 2014 | StarTech.com (SV211KDVI) 2port KVM Switch
Sennheiser HD201 headphones. Left hand cable completely broken about 3" below earpiece, so only get sound from right hand side. Have tried connecting with connector block, which does not work. Would...
there will be 2 wires in different colors inside the cable,
these wires are enamel coated and sennheiser has best quality coating over the wires, so soldering this could be a bit messy - this is the procedure to do so
first take out these wire leads out for about a centimeter from both the ends, try to loosen the leads and yo will find small clustered strands of fiber wound between the leads try to remove those fibers (only the visible ones) completely from both the ends of the exposed leads.
take a blade and try to wipe out the enamel coatings from the wires (make sure that the 2 leads does not touch each other after removing the enamel) now connect (solder) both the ends of the wire with their respective leads (eg. red with red or green with green as applicable) now you should be good to go
Please understand this is a delicate job and require atmost attention use cello tapes wherever applicable and tie knots at correct places to avoid further damages
Jan 30, 2011 | Sennheiser HD 201 Consumer Headphones
My flash disk2.0 does no work.
try the device in another pc. if it works, then try it back in the pc with the issue. windows normally recognizes usb's if you cant get it to work, try it in a second slot on your pc. if it still doesnt work, your pc usb slot probably does not work
Jul 31, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Hi MY Dell OptiPlex GX620 have a hardware
try the bios settings is your monitor in a grafics card slot
also see if plug and play is enabled only use a keybard and mouse with a ps2 conection not usb
Nov 24, 2009 | Dell OptiPlex GX620n PC Desktop
My speakers dont work
Why would they work with PC turned off? Aren't they attached to your PC? If they are then they only work when PC is on.
So turn PC on.
Jul 11, 2009 | Computers & Internet
Will virtual pc for mac v7 work with powerbook g4 running 10.4.11
Sorry, but the G4 and G5 desktops have chipsets released prior to the Intel agreement allowing pc's with CoreDuo and Macs with DualCore chips to exchange data, even though Virtual PC for G3 through G5 chipsets did work in running MS OS's prior to Vista, including XP, on mac platforms.
Now, if this helps, you might be able to secure an older version of Virtual PC, since your version works on current Macs and PCs with Vista, to run XP on your G4 and G5.
Mar 24, 2009 | Microsoft Virtual PC 7 with Windows XP...
PC will not connect unless Laptop is turned on?
first reset the connection, and try to connect the pc with switch and when net start working the connect the laptop
Mar 11, 2009 | Linksys WRT160N Wireless Router
Switching Between Vista PC and Ubuntu PC
I think your best bet will be in the ubuntu question page. It has quite a lot of ubuntu info there.
Oct 07, 2008 | Trendware TK-207K 2-port USB KVM Switch
Xbox 360 controller for pc
You know it works on the PC but nothing is working? Sorry, this isn't very clear, is the controller not working on the 360 or the PC? More explanation is needed here I think
Nov 12, 2007 | Microsoft Xbox 360 Console
Sennheiser HD 201 Consumer Headphones Logo
20 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Vito Vacirca Jr.
Gerhardus Stroebel
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
