Question about HTC Rhyme
Sim card not inserted
When i installed my sim card and turned on the phone message say no sim card not insrted
4 Suggested Answers
SOURCE: how to start htc touch
i have a problem with htc touch 3g mobile, i try to restart my mobile, I cannot restart, its showing only smart mobility screen after that its not responding.
Please give me a solution.
Posted on Jan 23, 2009
  • 3 Answers
SOURCE: i just had an software upgrade in my htc 3450
Do hard reset. Hold answer and end button at the same time and hit the reset button. hold all three buttons for a couple of seconds and release only the reset button. then when a message appear follow instructions on screen and you will bring your phone to original settings. CAREFUL SAVE ALL DATA BEFORE YOU DO. ALWAYS BACK UP BEFORE YOU DO ANYTHING. Good luck.
Posted on Feb 13, 2010
  • 73 Answers
SOURCE: Can receive all text message
Go to message setting and check if the settings are correct as per your service provider..
Posted on May 13, 2011
Lgce0168 insrting sim
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Oct 22, 2012 | LG CE0168 Cellular Phone
W880i insrt sim
when does your phone asks insert sim? try to check your phone by inserting other providers sim. if it accepts the card and works fine then the problem is with your phone. else if it does not accept the card or any other card other than your network provider then your phone is locked. you need to unlock it to use it with other sim. if it comes in unlocking there are many ways to unlock a phone. you can unlock it using software or hardware or through codes. if you ask me the codes are the best way to unlock it. unlocking through codes is the best and simple way to unlock any phone. i got my phone unlocked through this method only. you can get the codes either from your service provider or from any other service providers. getting codes from your service provider can be got only if your phone is within 6 months of the contract period.. i got the codes from a third party Superunlockcodes.com provider since my phone is much older
Aug 10, 2011 | Computers & Internet
My phone shows "please insert
You could try to remove your sim card.
Install battery and turn on phone without sim card.
Use phone without sim card and do some operations.
This will check if you phone is working correctly.
Turn phone off and install sim card.
Made sure sim card is install correctly.
If this does not work, it could be the sim card is bad.
Jan 15, 2011 | Cell Phones
Phone keeps saying invalid sim
Messages When You Turn on the Phone
  • When turning on your phone you may find a message requiring you to take a certain action before you can use the phone. If the message says "INSERT SIM," make sure the SIM card is installed in the phone or that it hasn't become loose. The SIM card is located in the battery compartment. Remove the battery cover and the battery. The SIM card should be located near the bottom of the phone under the metal hinge. Insert or secure the SIM card with the contacts facing down, reinsert the battery and batter cover, and turn your phone on again.
    If the message reads "PHONE LOCK," the SGH U600's automatic locking function is enabled. Enter the phone's password to unlock the phone.
    When using the phone for the first time, you will be prompted to enter a PIN. The PIN is given with the SIM card for your phone. Enter the PIN number exactly as given. You may also have the "PIN Check" feature enabled on your phone, which will require you to enter the PIN every time the phone is powered on. You can turn off "PIN Check" in the "Settings" menu.
    A message asking you to enter a PUK means you attempted to enter the PIN number three times and failed. You must contact your service provider to get a PUK.
  • Read more: Samsung SGH U600 Troubleshooting ' eHow.com http://www.ehow.com/way_5408527_samsung-sgh-u600-troubleshooting.html#ixzz11rVbifG3
    Oct 09, 2010 | Samsung SGH-U600 Cellular Phone
    No sim card inserted problem for nokia 2626 evn when the sim is inserted and the same sim is working properly on inserting in other phones but not in my nokia 2626... Please help me
    This problem happens due to problem in the sim card reader slot .
    Contact the service center where they will clean the metals plates and
    PCB board .And if necessary chnage the Sim card reader.
    Jul 08, 2010 | Nokia Cell Phones
    Phone saying No servce when SIm card is insrted
    try to check of you inserted properly simcard on your phone
    Jun 05, 2010 | Samsung SGH-A877 Impression Cell Phone
    Insert sim
    Is your sim card in the phone? Make sure it is inserted in there correctly and if it is and it still gives you that message the phone has a bad Sim card reader and although your sim is in the phone it is not reading it.
    www.usedcellphoneshop.com
    May 28, 2010 | Motorola Mobility RAZR2 v9 Cell Phone
    Insert SIM Card message in nokia 6080 though SIM is inserted
    May be its detecting your sim card properly. Check your sim card in another handset. Verify if its the propbelm with sim card not your handset.
    Nov 26, 2008 | Nokia 6080 Cellular Phone
    Insert sim card message
    i got problem with my phone n-gage,after i turned my n-gage on..itssays "insert sim car"..i already put my sim card inside of it
    Mar 01, 2007 | Nokia N-Gage QD Console
    HTC Rhyme Logo
    63 people viewed this question
    Top HTC Cell Phones Experts
    Ashutosh Khandelwal
    Level 1 Expert
    D. E. Hev
    Tech Leprechaun
    Tech Leprechaun
    Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
