Question about Kodak EasyShare C533 Digital Camera
CAN'T ALWAYS TAKE PICTURE
WE CANNOT TAKE PICTURE. WE READ THE MANUAL AND STILL COULDN'T DO IT. WE HAVE HAD 6 DIFFERENT GROWN-UPS TRY TO GET A PICTURE, BUT NO GO. I BET WE HAVE CHANGED THE "CODES" AND WE ARE NOT IN THE PICTURE TAKING MODE. I HAVE NEW BATTERIES CHARGING IN THE CAMERA NOW AND IT IS SITTING ON ITS DOCK. SOMETIMES I CAN GET A PICTURE ON THE SCREEN, BUT I DON'T KNOW HOW I GOT THERE. CAN YOU ALL HELP US? I FOUND OUT I CAN TAKE IT TO K-MART FOR HIM TO HELP, BUT REALLY WOULD BE INTERESTED TO GET HELP ON-LINE (WITHOUT LEAVING HOME). THANK YOU IN ADVANCE.
  • HILDA STANFORD Aug 03, 2007
    I tried what you suggested. I took it off the charger and turned it to the icon above the off. All i had was a blank screen.
    I replaced the camera on the part again and it showed Tagged Points(in a yellow bar). Below that in a white bar it said Print Tagged Pics. Below that in the blue background it said Review Tagged Pics.
    Below that was the word Exit.
    After about 2 minutes the screen went black and the green light next to the viewer started to flash (or may have been flashing all along).
    What else can I do?
  • 27 Answers
Hope this helps
Posted on Aug 03, 2007
  • Gene Cann
    Gene Cann Aug 04, 2007
    are you pressing the INFO button in part 2 of the picture I posted?
Sandisk cruzer
Try connecting it to another computer if that doesn't work try wiggling it gently and putting it in and out. Thumb drives are made cheaply and are not always dependable. Always get different types and keep back ups.
May 29, 2013 | Computers & Internet
Powering down
your not very clear but here is what I'm assuming your saying.
Pins 5 & 6 - Any-Mode Shutdown
1. Pin 6 of the 9-pin communication connector is used for "Any-Mode Shutdown"
of the UPS output. This control input may be used in special applications
to disable the UPS output power-both Inverter and Bypass.
2. The Options tab allows the behavior of the Any-Mode Shutdown feature to
be modified. When the program opens, or the REFRESH button is pressed,
the UPS setting is read by the configuration program and displayed.
Auto-Enable Output
Pin 6 Logic
If version 1.6 (or later) is used with an earlier Liebert GXT2U model (with an
earlier UPS firmware version), the Any-Mode Shutdown features cannot be
changed.
If the configuration program is used with an earlier UPS model (with an
earlier UPS firmware version) that does not support the modification of these
settings, the Options tab will display a reminder of the factory default
settings. These cannot be changed.
! WARNING
Note that when this option is selected and the UPS output is
disabled using Pin 6, the UPS output can turn on automatically
and without warning if the Pin 6 connection is changed.
! WARNING
DO NOT CHANGE THIS OPTION from the factory default
setting unless you are ready to install a normally-closed
connection between Pins 5 & 6. This connection must be
maintained to use the UPS or to use the configuration program
again, including the ability to change the UPS setting back to the
default setting using the configuration
Sep 05, 2011 | Liebert GXT2-10000R230 (GXT2-10000R230)...
Hello. I have a Mustek PowerMust USB 800 device. Few times a day (2-3 times) it shuts down my computer. It appears the red light instantly and it starts to make a sound. Even after i press the button and...
Did you read the manual for your UPS ?
I read it - there was something about lamp ledding - different ledding of lamps and different frequncy of noisy sound can mean different problems - try read manual.
I think, your description means that you need to change battery.
Battery work 2years +- .
Jul 05, 2011 | Mustek PowerMust 800 (POWERMUST800USB) UPS...
Hello. I have a problem with an COMPAQ R3000h USP. When it is plugged in to the electricity it turns itself off after a few seconds after manual switching on and than turns itself on again for a couple of...
a UPS that is 18 years old (1999)
first is a new main battery,, always.
the service manual is here.
thera are 17 LED on the panel, that have meanings.
see page 2.9 and read from there....
http://h10032.www1.hp.com/ctg/Manual/c00681632.pdf
Sep 20, 2017 | Compaq UPS R3000h UPS System
I buy a used technics sl-pg480a cd player and after i inserted a cd, there is "no disc" on display...i try with different cd's (mp3, avi,...) and it's always the same...i have opened a box and...
If it doesn't turn the disc it can't read the data and 'know' from that there is a compatible disc inserted.
You may have gotten hosed by the seller. Until you get it to play with a commercial music CD I wouldn't try anything non-standard or home-grown. It doesn't play anything but CD-A music so MP3 and AVI discs would not be recognized anyway.
Before you dive in and possibly wreck it, read this...
http://www.repairfaq.org/sam/cdfaq.htm
The manual:
http://www2.panasonic.com/consumer-electronics/support/Audio/Technics-Audio-DJ/Technics-CD-Players/model.SL-PG480A
Feb 20, 2011 | Technics SL-PG480A CD Player
Surt10000xli not switching on
my ups surt10000xli ups shows internal faulty LED On, i have checked main board but couldn't find the fault. please tel me the fault
Feb 15, 2011 | APC SURT1000XLI 1000VA 700W 230V UPS...
Do you have a picture of the ignition module and replacement procedure for a 1996 camaro?
No, but there is alot to a ignition module. I always get a manual and it will have all wiring hook ups and instruction. And we can always use manuals - Good luck
Oct 15, 2009 | 1996 Chevrolet Camaro
APC Smart UPS 3000VA - Dead UPS When I plug in the unit nothing happens no lights, no noise - nothing! Is there a replaceable fuse in these units? Cheers
ok how long you brought the ups and how long you had not start the the ups usaully ups is power dead change the battery and try to power up it should work be sure that all connection is connect properly before power up the ups.. if the ups doest work that will be the mainboard problem you hav to call for vedor to repair the unit.. yes these fuse for the ups but it unlikely to be blown so should worry of the fuse it self.. change of battery come with different spefc for the ups.. eg su3000rmi3u, sua3000rmi3u, su3000rmxl3u --- battery replacement is 8 pcs of 12v 7ah. sua3000rmi2u-- 6 pcs of 12v 7ah or 8 pcs 12v 5ah. su3000rminet-- 4 pcs 12v 17ah,
Sep 03, 2008 | APC Smart 3000VA (sua3000r2x145) UPS...
Sony KV-34HS510 blink codes
I would question that diagnosis, Did you get it online somewhere or did you have a tech check your B+ voltages ?
6 blinks is almost always caused by 2 chips on the "D board", they are both marked MCZ3001D you can order them here if you are a consumer not a tech 800-575-9833. Not to say that the jungle IC & those 2 caps couldn`t cause a dead set symptom but these 2 IC`s are notorious for the 6 blink code, I have personally fixed approx. 10 sony sets with the 6 blink code with those IC`s, hope this helps
Nov 29, 2007 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Kodak EasyShare C533 Digital Camera Logo
44 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Parshiv Luthra
Are you a Kodak Camera Expert? Answer questions, earn points and help others
