Question about Garden
How to replace the Pawl and spring of a stihl weedeater
Directions
3 Suggested Answers
lemmingleejn
  • 173 Answers
SOURCE: Stihl weedeater starts but won't run at high speed
This sounds like a timing problem.
It is too far retarded, and needs advancing a couple of thou.
There you go:)
Posted on Jul 25, 2009
moretons
  • 155 Answers
SOURCE: no power fs66 stihl weedeater
Hi When you cleaned the muffler out did you also clean the carbon out of the port on the cylinder as this can be blocked as well. Also you will have to retune the carby, There should be 2 screws 1 for low speed marked l on the carby body and 1 marked h for high speed to start with they should be set at 1 & 1/2 turns out from closed the low speed you set at an idle and the high speed you set at full throttle. Hope this helps.
Posted on Aug 04, 2009
The pull cord hasn't snapped it just wont recoil! is this an easy fix?
Sounds like the starter spring has broken, remove the three torx screws securing the starter and remove the starter, prise off the r clip holding the pulley and pawl on ( note the orientation of the clip on the pawl ) remove the pulley, the spring is in a cassette, remove the cassette and replace with new, refit the pulley, make sure the pulley locates properly into the hook on the starter spring, re fit the pawl and r clip, enter the cord into the cut a way in the side of the pulley, now wind the pueey around to tention the spring.
Apr 17, 2013 | Stihl Concrete Cutoff Saw Rewind Recoil...
Petrol stihl
Stihl machines have a plastic pawl in the rope pulley, a small r clip retains the pulley and creates some friction on the pawl, as the pulley turns the clip tries to stay still due to the tention this in turn drags the pawl out and into the flywheel drom, so you either do not have enough tention on the r clip, or the small plastic dog has broken.
Feb 09, 2013 | Stihl Ts400 Cut Off Saw Carb Carburetor...
How do i replace a rewind spring in a stihl fs 45 weed eater
you have to kake sure u wind it the rite way there should be tension on the spring when it is wound and if let go should return if it does that u have it rite...the little plastic peice must be connected to the hooh on the spring
Jul 25, 2009 | Black & Decker Garden
Stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Apr 23, 2009 | Ryobi Garden
Pull cord on weedeater wont recoil
sounds like the spring is broken itself.there should be a hook at one end and a loop at the other end.the hook usualy breaks off but the spring looks good.replace the spring with part number..4140 190 0600 ....that is the stihl part number.let me know if this helped you...if not give me a quick mail and i'll try to help some more......
Mar 12, 2009 | Garden
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
