Question about Car Audio & Video
Difference between 4 RCA and 2 RCA output
Some stereo have 4 RCA output, some has 2 RCA output. What is difference? For a car straight hook up without an amp, what type I should buy?
    Brigadier General:
  • 4,669 Answers
You use RCA output for amps. If you aren't running an amp, you don't need them. So go with the two or which ever one is cheaper.
Posted on Mar 12, 2009
  • Clint Smock
    Clint Smock Mar 12, 2009
Connecting a soundbar to Phillips TV
only some model and brand has an audio output. you can hooked up at the earphone jack of the tv to get audio out.just used a mini earphone plug with output stereo rca plug.
Nov 05, 2012 | Televison & Video
I have a LG 47 inch flatscreen.i cant find any audio output plugs to hook it up to surround sound.how are you supposed to hook it up.
this is from the LG website about that TV.
- Rear,
2 x Composite video/audio input (RCA phono x 3) - Side,
2 x S-Video input (4 pin mini-DIN),
1 x USB (4 pin USB Type A),
1 x Audio line-out (RCA phono x 2),
2 x Component video input (RCA phono x 3),
2 x Audio line-in (RCA phono x 2),
1 x Digital audio output (optical) (TOSLINK),
1 x Digital audio output (coaxial) (RCA phono),
3 x HDMI input (19 pin HDMI Type A),
1 x RGB input (15 pin HD D-Sub (HD-15)),
1 x Audio line-in (Mini-phone stereo 3.5 mm),
1 x Serial (9 pin D-Sub),
1 x Remote control (Mini-phone 3.5 mm)
Mar 20, 2011 | LG 47LC7DF 47 in. LCD HDTV
I am setting up 4 bose 901s to my home stereo and am unsure how to connect my components to tha 901s active equilizer. the 4 901s are connected to 4 marantz ma 500 amplifiers. the amplifiers are...
Hi -
Sony CD player Red / White RCA - > CD input RCAs on the Arcam.
From the Arcam Preamp Output RCA's, go to the Bose "Input". From the Bose "Output", you need RCA splitters to make them into four outputs to run your amplifier connections.clmrt5000_2.jpgclmrt5000_3.jpg
Jan 15, 2011 | Bose 901 VI Main / Stereo Speaker
What do i need to hook up ipod to bose 321. (wires etc)
This is the quick and easy way to adapt a standard stereo 3.5mm (1/8 inch) sound output into standard RCA plugs. Ideal for connecting your MP3 Player with a 3.5mm plug to VCR's, TV's or anything else that has RCA stereo sound inputs.
General Features:
- Fits standard 3.5mm (1/8") stereo phone jack
- Gives you two male RCA (left / right) sound outputs
- Great for converting a headphone jack to standard RCA sound outputs
- 6 foot length
- Straight cable (not a coiled cable)
Generally these connectors cost between $1.00 to $5.00
Pictures to help you find them
Search google for headphone to rca adapter for more info
Hope this helps
Jan 16, 2010 | Bose (321GS) System
Connecting a car stereo to an amplifier
you have to connect your 4 speakers to 4 speakers output direct to your car stereo no need of amplifier to 4 speaker but speakers should be small not like a woofer, and you have to connect your sub woofer by using amplifier don't connect direct. connect the output of your car stereo (using 2 RCA) to the 2 RCA inputs of amplifier. If u connect your 4 speakers to your amplifier then your car stereo does not support Left Right channel.
You can also connect your laptop or iPod direct to your amplifier.
Good Luck
enjoy music
Nov 24, 2009 | Kenwood Car Audio & Video
I hooked up my JVC-KD-G210 and worked fine all of a sudden all 4 speakers quit the amp and sub still work i even ordered a new plug for back of stereo thought it was problem and still diddnt work id like...
Your internal amplifier for the radio has failed (output IC). Probably due to a shorted speaker or speaker wire.
Repairing the unit will cost as much as another one.
You may be able to pick up a small used 2 or 4 channel amplifier instead and use the RCA signal to feed it for less than the repair cost.
You will be surprised in the sound difference between a dedicated amplifier, and the one built in the radio anyway!
The typical radio SAYS 50Wx4... however - realistically can put out 12-15Wattsx4
a small 25x4 or 50x2 amplifier can be had easily for under $50 used, and will make a tremendous difference in sound quality... without having to spend more on the radio for it to potentially fail again anyway.
A Dedicated amplifier will have a built in protection circuit that will shut down instead of blow the output ICs like your radio did.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Apr 14, 2009 | JVC KD-G210 CD Player
Legend Amp hook up manual.
Pretty Straight Forward get a 8 or 4 gauge amp wiring kit.
Run your hot wire to the +12V from the battery make sure to install the supplied inline fuse near the battery don't connect to the battery until installation is complete.
Run the REM to your stereo power ant. Wire. if available.
Run the GND to Metal Chassis Ground keep it as short as possible.
Run the RCA Cable from the back of the Stereo to the RCA Inputs or Low Level on the amp.
This amp is 2 Ohm Stereo Stable which means you can connect 2 (4 ohm) speakers in parallel to each channel or 1 (4 ohm) speaker on each channel or you can connect 1 (4 ohm) Speaker in bridged mode.
There are other speaker configurations you could use but you cannot drop the load below 2 Ohm in stereo mode and no lower than 4 ohm in bridged mode.
Hope this helps
Mar 25, 2009 | Legend LA1490 - American Legacy Series 2 -...
How much volts or ohms should be coming out of rca cables to my amp?
ohms does not make a difference for the rca cables, and the volts at the stereos max power will be whatever that brand and model is rated for the output cables, usually 2.5, 5, 7.5, or 9. your average output is for 2.5 volts on an affordable aftermarket radio
Jan 07, 2009 | Kenwood KAC-9152D Car Audio Amplifier
How to hook up a boston acoustic ba7500g speaker
you can connect the BA7500G speakers to a regular digital coaxial output by using a cable that has an RCA plug on one end and a stereo minijack on the other. However, the pole of the RCA must connect to the tip of the stereo minijack and the shield of the RCA must connect to the middle ring on the stereo minijack. Also set your soundcard to output at 16bit and 48khz.
Oct 19, 2008 | Acoustic Audio Players & Recorders
Still no sub woofer output
SET THE CROSSOVER TO "L.P.F."POSITION AND SELECT THE LOWEST FREQUENCY AS THE CROSSOVER POINT.
[AN AMPLIFIER IS SUPPOSED TO "AMPLIFY"(TO INCREASE)ANY OUTPUT.]
TRY CHANGING THE POLARITY OF WIRES FROM AMPLIFIER TO SPEAKERS /SUBWOOFER.{it leads to cancellation of bass output.}
if u still have doubt contact me again.
May 26, 2008 | Alpine CDE-7856 CD Player
Car Audio & Video Logo
425 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
