Question about Stihl Garden
Saw sounds like it is running out of gas but is not
    Sergeant:
  • 339 Answers
Inside the tank is a fuel filter, replace it and then see how it is.
Posted on Apr 21, 2013
    New Friend:
  • 17 Answers
Were you able to get the saw running? If not, I can help troubleshoot it.
Posted on Apr 23, 2014
I replaced gaskets and fuel lines now when i prime bulb gas runs out of carb,also need factory settings for H-L and throttle,i know i messed up somewhere?realy need my saw running,thanks
take apart your carb--sounds like your carb diaphram is not installed right the settings should be
1.5 turn out low jet
1 turn out high jet
that should get it running then some fine adjustment once its running
Sep 04, 2015 | Poulan P3314 14Inch 33cc 2Cycle Gas...
Let go the gas speed up by itself
I'll be honest, I am not exactly sure what you mean but it sounds like you are talking about a runaway. Sometimes gas powered saws will run themselves without hitting the trigger, and it's often caused by the carburetor set improperly. The older saws have a high and a low, and the new California approved only have the low (but the high can be tweaked with some effort).
Mar 26, 2013 | Husqvarna Air Filter In Cage For Partner...
Saw starts and loses power and dies when i pull throttle
It sounds like it is running too lean on the mixture, if it is new take it back to have the mixture richened up, if you carry on running with a lean mixture it could seize.
May 03, 2012 | Craftsman 38cc 16 In. Gas Chain Saw
I have the 455 rancher and when I start the saw I pump the bulb 6-8 times and the saw will not run right. It sounds as though it is running out of gas. It bogs down when I pull the trigger. The saw is 2...
Before you do anything else i think you need to check the engine is mechanically sound, remove the muffler, take a look at the piston skirt through the open port, any signs of scuffing on the piston and it will require removing the cylinder to assess the damage, they are x torq engines, due to the way the air ports work they are quite prone to carboning in the piston rings, make sure it has plenty of compression.
Aug 21, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Setting the carb twe jets
These people explain better than anyone else I have found. The sound files are very helpful too.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – not highlighted) files that I find most helpful, I think you will too. HTH
Lou
Dec 26, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Saw runs good when you prime it cant get it to get gas from tank
Sounds like you have a plug between the tank and the carb. I would change the hose between the two and clean the tank as well as the carb.
Jul 27, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Poulan 14" chainsaw, fuel coming out of fuel cap vent
The fuel cap has a rubber check valve in the top. This check valve allows air to enter the tank so fuel can flow. Much like the vent on your gas can. Sounds like the check valve in the cap is stiffening and not flexing. Best bet is to buy a new cap. Most caps like that sell for less than $3.
Feb 24, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Chain saw emitted sparks and now does not start.
Hi
When the engine get warm and die(I suppose)check the spark at the sparkplug.You can let the saw run until it ran out of gas and you will not distroy the engine.Change the sparkplug.
best regards savumihai71
Dec 16, 2008 | Garden
Brand new Husqvarna 340e chain saw dies after 10 to 20 minutes.
Hi
Find out where is its airating sistem.It equalises the presure between the interior and exterior of the gas tank.Disassembly and clean it.
regards savumihai71
Dec 05, 2008 | Husqvarna Garden
Chainsaw kills when I press the throttle
My 372 xp did that and when I talked to the repair shop they even showed me. There is a fiberglass gasket that is used to mount the carburetor to the engine. I have no idea on how this happens, but I saw it with my own eyes. The gasket had actually folded over. They replaced it with a rubber one and have had no problem since. The saw was hard to start, would run as long as I didn't try to cut anything and when I did it would open up and then die. I could be giving wrong information, but that sounds exactly like the problem I was having.
Oct 08, 2008 | Husqvarna Chain Saw 20" Bar
Garden Logo
308 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
