Chris, 1993 infiniti J30 thermostat location. Follow large radiator hose to intake manifold by water pump, at the end of the rad hose is the thermostat housing. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." How to Replace the Thermostat in an Infiniti J30 eHow Thermostat Replacement Write Up Infiniti Thermostat Replacement
Check power to your master switch it's unlikely the motors are bad could be connections at the motors but i'm leaning toward the duel switch on the drivers side
If this is just a basic tune up then the cost is about $135.00 (varies with local hourly labor rates), more if the distributor cap and rotor are in need of replacing
for the most part you have to put the car on ramps and remove the screws form the transmission pan and the filter is behind the pan give these websites a try www.alldatadiy.com and www.autozone.com if all fails stop by your local library and get your hands on a Haynes auto repair manual for your car wish you the best of luck Michigan Man.
