Question about Philips DVDRW 416K (DVDRW416K/00) DVD+RW Burner
DVDRW416 not working
Hi please help, i have changed over my philips dvdrw1640 drive to my older dvdrw416 as the draw on the 1640 was not opening. But now the dvdrw416 does not seem to be working. The draw opens and closes ok and i can see the new drive in device manager, i also updated the firmware from 1.2 to 1.4, but when i place a blank disc in the drive neither the cd or the dvd lights, light up. I am using xp home. Any advice would be great.
  • 1 more comment
  • mark reyes Aug 03, 2007
    The Main light in the middle between cd and dvd does light up at boot up but then turns off. I have tested the drive with both types of disks (cd/dvd) but still nothing. Do you think i need to say goodbye to this drive and buy a new one??
  • mark reyes Aug 22, 2007
    Thanks for all the advice, i did buy a new one and everything works great again.
  • 27 Answers
I believe this drive is faulty as it should try and spin light up upon power-up even if it only has the power cable connected.
Posted on Aug 03, 2007
  • Gene Cann
    Gene Cann Aug 04, 2007
    Yes I would buy a new one.
Firmware of ml 1666
need for samsung ml 1666 chipre set software
Aug 05, 2012 | Samsung ML-1640 Monochrome Laser Printer
My samsung ML-1640 wont work.but still can print test print. how to reset ML-1640?
Hi there!
You can try to reset your printer using reset software. Just go to www.nakshatraworld.com
Hope this helps.
Mar 30, 2011 | Samsung ML-1640 Monochrome Laser Printer
Phillips dvd player disc draw won"t open help
Usually, there's a pin hole beneath the tray that come out. If there is a pin hole, get a paper clip or safety pin and insert the pin or clip into the pin hole and push. That should pop the disk tray out.
Mar 21, 2011 | Philips Electronics - Others
The DVD Drive on my philips freevents 12NB5800 isn't working. The problem is that the draw opens but the laptop isn't recognising the disc. I had tried going onto my computer and double clicking on the dvd...
Either your CD/DVD drive is dirty & needs to be cleaned, or the drive has gone bad & needs to be replaced.
First, try to take the drive off the laptop. Open the drive & blow compressed air into it (from a can of compressed air) to clean it. You could also clean the lens (the small round glassy object inside the drive) using lens cleaning tissues & lens cleaning fluid.
If this did not fix the problem, you will need to replace the CD/DVD drive with a working one, or use an external CD/DVD drive
Aug 29, 2010 | Computers & Internet
The DVD player slide draw will not open or close
Check for a manual eject slide on the bottom near the front of the tray
Nov 21, 2009 | Philips DivX DVD Player
Philips dvdr 3480 disc draw refuses to open
Illustration:
This usually happens when you close the drawer with no disc in it. There is a strong magnet inside the DVD-drive that keeps the spinning disc in the correct position. But when the drive is empty, the magnet is connected to tough to its counterpart (no disc in between) and the worn out motor and/or transmission (belt) is not able to pull them apart in order to open the disc tray.
How to fix - "brute-force-attack":
Press OPEN and give the disc draw a couple of decent slaps (or snap at the tray cover with your forefinger) until it opens. Repeat procedure, if motor stops before drawer is open.
How to fix - "high-tech-approach":
Disconnect power chord. Locate the slot provided at the bottom of the device, near the smaller, left clip holding the front panel. Insert a screwdriver into it at the far right (when viewing from the front), so you can push a small white plastic-lever-thingy (can be seen thru the slot) to the far left. Now the tray is partly opened and can be pulled out completely.
Future outlook:
Don't you never ever close your old machine with no disc in the tray - or just start over again...
Jul 26, 2009 | Philips Televison & Video
Upgrading from 250 gig hard to a 500 gig hard and says mismatch. my first hard drive is dead
hi pete,
changing the bios will do the trick, find one that is most compatible with aspire 1640 for a 500gig hd, once you have this replaced, it will work.
for more laptop troubleshooting tispd, you may also check the link below.
http://www.laptoprepair101.com/
hope this helps.
regards,
voodoo
Apr 12, 2009 | Acer Aspire L100 PC Desktop
Philips cdr600
Needs a new laser or realigning service using philip's COMPair diagnostic system.
Oct 13, 2007 | Philips CDR600 CD Recorder
Philips DVDRW 416K (DVDRW416K/00) DVD+RW Burner Logo
77 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Steve Allison
Steve Allison
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
