How do I replace a main conrol board on a Frigidaire FGH52644KF1
I have the replace part I can find were to change it on the fridge
    Problem Solver:
  • 8 Answers
Sometimes the panel is behind the controls, possibly in the freezer or in the frige itself where you set the temp, you have to disconnect the fridge from its power source and take the panel apart. You can go to the web site and should beable to find out excatly where it is located.
Posted on Apr 20, 2013
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
Frigidaire fridge model FGUN2642LF6 fridge is not working. Code displays sy and ef, what is wrong
Your evaporator fan is not spinning.
Check to make sure there isn't any ice build up jamming up the fan. If there isn't then it's either the evaporator fan, or the main board.
Aug 14, 2015 | Frigidaire Refrigerators
Www frigidaire com.
Hello Friend, thank you for your post!
Generally, error code 4 means that your Frigidaire refrigerator is experiencing an issue with the damper. The damper is either not opening or closing properly causing the fridge compartment to not cool. One of the best ways to determine if this is a false error code is to reset the power to your refrigerator by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, the wiring between the damper and Main Control Board will need to be diagnosed by a professional. Depending on the results, either the damper or Main Control Board will need replacing.
Best regards! - Z
May 21, 2014 | Frigidaire Refrigerators
My frigidaire refrigerator side by side if flash a number 4 on the fridge side as it is not cooling
Good Morning John, thank you for your post!
Generally, error code 4 means that the refrigerator is experiencing an issue with the damper. The damper is either not opening or closing properly causing the fridge compartment to not cool. One of the best ways to determine if this is a false error code is to reset the power to your refrigerator by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, the wiring between the damper and Main Control Board will need to be diagnosed by a professional. Depending on the results, either the damper or Main Control Board will need replacing.
Best regards!
Jan 28, 2014 | Frigidaire Refrigerators
Frigidaire SY CF issues
Good Morning Jack, thank you for your question!
Typically error code SY CF indicates that your refrigerator has detected a communication failure after power up. The error code may possibly continue after replacing the part you have ordered. With this error code, a professional would need to check wiring between the main control board and user interface board. After proper diagnoses and if the error continues, the main control board may need replacing. Hope this information helps to some degree!
Dec 27, 2013 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire FGHS2644KF. Fridge just died. Flash code of 5YCF.
Hello erintu81 - SY CF typically indicates that the refrigerator has detected a communication failure after power up. The wiring between the main control board and user interface board will need to be accurately diagnosis. Depending on the results either or will need replacing. At this point, I strongly recommend connecting a professional to move forward accurately and to properly assist with the repair(s).
Mar 01, 2013 | Frigidaire FGHS2644KF (260 cu ft) Side by...
My frigidaire is displaying SY CF
Hello Angela Clark - Typically error code SY CF indicates that the refrigerator has detected a communication failure after power up. Contact a professional to move forward accurately. The wiring between the main control board and user interface board will need to be check and diagnose. Depending on the diagnoses the main control board may need replacing.
Dec 05, 2012 | Frigidaire FGHB2844L
Frigidaire fridge code 4
Hello j280connolly - Typically error code 4 means that there is a communication failure with the main control board and damper. Base on the intensity of the issue; a certified technician would have to check the wiring between the two. If problem still exist, might have to replace the main control board.
Oct 12, 2012 | Frigidaire FRS3R5EMB Side by Side...
I have a frigidaire fridge model # FSC238F7DSBA I had a blinking error of " E F" on the control panel. I checked out the error codes as well as called frigidare customer service and they both led me to...
After replacing the control board did you unplugged the fridge.?There is no resetting button.Unplugging the fridge for 1 hour will reset it.If still the fridge doesn't reset then leave it over night unplugged.
Thank you
Oct 19, 2010 | Frigidaire Refrigerators
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
