Question about LG enV VX9900 Cellular Phone
My env 2 inside screen wont show up (blank)
I dropped my phone like 2 times when i fell. and now the inside screen well it is black. the outside screen works. but i cant see inside screen
  • 3 more comments
  • Anonymous Mar 12, 2009
    My Envy 2 fell out of my pants when getting hit and hit ground had protective case on and inside screen is black now inside keys work, and outside is perfect
  • Anonymous Mar 15, 2009
    it sucks..i agree..it fell:(
    im sad
  • Anonymous Mar 19, 2009
    dropped it. took whole phone apart and still nothing. thought it was a bad ribbon cable but its not.
  • dean_rowe7 Apr 12, 2009
    Same. This is the second time it has happened! It usually never happens. Tisk Tisk LG
  • Anonymous Apr 26, 2009
    Okay. Well, I didn't even drop mine. I recorded today's Edwards' crash on Nascar and sent it to my boyfriend and my screen went blank.
  • 4 Answers
SOURCE: Flashing blank screen
If your phone is less then a year old bring it to a store that is owned by Verizon. You could also call 1-800-256-4646, then ask for the FRU (Factory Replacement Unit) department. They will get you a replacement phone.
Posted on Sep 08, 2007
Buschchris1
  • 474 Answers
SOURCE: Dim display on LG enV 9900
Here, this might help, You said you dropped it so its probably due to the shock and not the settings.
Most repair shops dont stock LG Envy parts becasue they ave no way to get it, So they may or may not be able to help.
If you cant get any help, try this, Take apart the cse on the side with the screens. its fours screws hidden under a stickey cover on the side with the big screen. Pry it apart carefully from one of the edges with a little knife or flat head screwdriver. Avoid getting finger prints on the screens, uses an eye glasses cloth to clena it if you do.
There is a ribon that is connected form the other part of the phone that presses in place, its rectangular. Make sure that is snapped securely in place.
The other connector is under the main screen, if you pull apart the main screen from the small screen, there is another connector that is between the two like a sandwich.
This one comes off easily so it may have come loose form the shock of dropping it.
You have to line it up and carefully press it together before you lay it back in the case and put it back together.
Its bassically a metal frame on one side and you line it up and press in the other side, when you lay it back down into the case, it may come apart again because its own weight pulls it apart, so its a bit tricky getting all together and in place but eventually you will figure it out, one you get it all in, mack sure the screens are clean of debre and fingerprints.
You dont want to do it all over again because theres a smudge on the inside or a hair in there, very pesky.
Everything snaps back together easily and then put the screws back in.
If the sticky screw covers survive you prying at them, then put those back on also, it looks nicer.
Give this a try and see, I tried tajing my phone to a supposedly reputable cell phone repair place and the first thing they did was say they dont have the parts and they cant order them. ( this is because LG doesnt distribut them, not even Verizon can work on them, they send them to LG and they usualy replace the phone if its under warranty.)
So dont get suckered in by a phone repair place because they will just check it for water damage and charge you $60.
Let me know if this works, i like hearing good news when it comes to the ENVY phone.
Posted on Feb 25, 2008
  • 905 Answers
SOURCE: Blank screen
pull the battery from it for a little while , if that don't do it its probably a display chip inside and it can't be replaced , they have been having problems with the screens on these phones , does the phone still work for recieving and sending calls? its not likely but not impossible the screen went
Posted on Oct 10, 2008
  • 8 Answers
SOURCE: LG Envy inside screen no longer works, did not drop or get wet, was using it fine then all of a sudden I opened it to text only to find a black screen, buttons still light up, but no display!
there is a small very delicate ribbon cable that connects the screen to the circuit board that has probally broken. it is a common problem on phones that flip like yours does.
Posted on Jun 01, 2009
SOURCE: I need to replace the internal screen on my env Touch.
p/s tell me setting for airtei live
Posted on Oct 23, 2009
My env2 was dropped. the outside screen works but
it's a good time to go get a new phone. that much damage would cost more in repair that it would to either replace or upgrade to a new phone.
Mar 23, 2010 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
Inside screen in black, outside is white
s see for software updations for your mobile in google & u can download it & install it in your mobile via data cable
Jul 17, 2009 | LG enV VX9900 Cellular Phone
EnV front screen has a black stripe
Its manufacturing fault which can be caused at any time while using or if it get hurts .. you can calaim its warranty or take it to near by mobile shop to get it fix .. they might change screen or the serial wire of screen
Jun 25, 2009 | LG enV VX9900 Cellular Phone
My envy 2 has a black inside screen but the outside screen is fine! Please help me!!!! SM
I dont know what is happening. If you dropped it then there might be a problem. Or the light prob. burnt out.
Jun 14, 2009 | LG enV VX9900 Cellular Phone
Jun 01, 2009 | LG enV VX9900 Cellular Phone
LG ENVY BOTH SCREENS BLANK
well it seems like you need the charger port service or resoldered , the flexcable in the phone may need to be replaced.
May 30, 2009 | LG enV VX9900 Cellular Phone
envs are ****- get a different phone
Apr 14, 2009 | LG enV VX9900 Cellular Phone
Dropped Env2, Screen wont show up
Well, its possible that you just need to turn the phone off, and turn it back on. Or maybe when you dropped it, something inside the screen itself broke.The only way to be sure is to take it in and have them look at it. Good luck.
Apr 12, 2009 | LG enV VX9900 Cellular Phone
Outside and inside screen is "black", but still "glows" when powered on?
My phone is doing the same thing. My phone hasn't been dropped or exposed to any liquids, but the screens are not working. LG suggested that I send it to them. If they can't fix it, they will just replace it. The only thing I have to pay for is sending it to them. I can make and receive calls but I can't read text messages which is why I mainly got the phone. Just send it to LG Wireless. Call them and they will give you a number that has to be attached to the package and the phone. Within two weeks, they will fix it or replace it. I had to get my LG 8500 replaced, and it was no problem.
Apr 04, 2008 | LG enV VX9900 Cellular Phone
LG enV VX9900 Cellular Phone Logo
462 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
