Question about Mitsubishi WS-65908 TV
MITSUBISHI WS-65908 red crt going off and on
Had recently repaired the smudged colors and arked picture with a set of sanyo stk-392-570 worked great for a couple of months.. (:....... Now my red crt keeps going on and off giggled all the wires checked all connections with no effect could stay on all day or for half a movie or maybe be off for a week and be fine for a week so we watch a green picture hoping the red will come on sometime it does and sometimes will not .. anyone had this problem or have a fix or something I should check in the dark all 3 crt's are lit on the bottom by the circuit board at all times. red crt top of bulb just works when it wants too thanks
  • NITRO FISH Aug 03, 2007
    MITSUBISHI WS 65807 is my model number not ws65908 Had recently repaired the smudged colors and arked picture with a set of sanyo stk-392-570 worked great for a couple of months.. (:....... Now my red crt keeps going on and off giggled all the wires checked all connections with no effect could stay on all day or for half a movie or maybe be off for a week and be fine for a week so we watch a green picture hoping the red will come on sometime it does and sometimes will not .. anyone had this problem or have a fix or something I should check in the dark all 3 crt's are lit on the bottom by the circuit board at all times. red crt top of bulb just works when it wants too thanks
  • Anonymous Dec 03, 2007
    Red crt going off had some arc problems but would fix itself now no red color
You don't have enough soder on the STK392-570 unit ! I had to re-soder mine and is OK now
Posted on Sep 06, 2007
SOURCE:
No red on mitsubishi ws-65908
DTV is HD input but look to see if red lens is lit====set does have a hard reset which might cure it if it is a issue---it is based at the exact model number, a four digit code and the working Mitsubishi remote control.
Aug 26, 2012 | Mitsubishi WS-65908 TV
Mitusbishi Model ws-65819 color convergence repair. How does one go about fixing it?
The two stk-392=570 chips need to both be replaced===they are along with the rest of the circuit on the middle board.
May 20, 2012 | Mitsubishi WS-65819 TV
Picture is no longer working properly. Picture is blurry and colors are all wrong. Ghost image. Happened all at once not gradually. What needs fixed mitsubishi 65" medallion series. appox 7 yrs old
Your Convergence ICs have failed. It is very common on rear projections. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
When you notice the symptons Use this simple test to verify.
Go to the users menu on the tv.
Look for the converge option probably under setup or video setting. Converge is short for convergence to align the red and blue colors to the green color.
If you cannot move the red either horizontal or vertical, then the STK chip has failed for red section.
If you cannot move the blue either horizontal or vertical, then the STK chip has failed for the blue section.
If you can move both in each direction then the problem is something else.
Note if one STK chip fails, you replace both regardless.
Feb 19, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Top and bottom of picture in center of screen dips like a bow tie
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board reqiured changes it 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board problems to solved the tv picture convergence picture problems.The shop,will cost like $300-350 for parts and labors.
Feb 01, 2011 | Mitsubishi WS-65908 TV
I have a mitsubishi ws 65807, i get trouble code 23
The problem is most likely convergence integrated circuit failure. I recommend finding a local Mitsubishi repair center.
Dec 05, 2008 | Mitsubishi WS-65908 TV
Ws-65908
The fact that removing the front helps does not really means anything but is good that you have notice,the age of the set has a lot to do with the problem,I am sure it has many loose conections that need to be resoldered regarless,all sets have many components that disipate a lot of heat and over the years the solder cracks and it forms a ring ,this makes the set intermiatnt until no conection exist any more and it stops working for good.What does the unit do when it shutsdown? does it show a picture with lines that is red ,green or blue and then it shutsdown? or it just goes off? if it shows you a color like I mention it could be the picture tube of that color and the repair will be expensive but it could also be a loose conection somewhere in the power supply or the deflection panel,If you are familiar with repairs ot TV's you can possible take care of it but if you are not familiar with electronics call a qualified technician.I hope you can use this information.
Nov 30, 2008 | Mitsubishi WS-65908 TV
Mitsubishi prjection screen WS-65908
You have a convergence problem,all this sets show this problem sooner or later,you have 2 or 3 amps for the red,green blue colors and this amps go bad and need to be replaced then you have to do a convergence aligment from the service mode and not form the customer controls,a qualified tech should be able to correct the problem since is a common one.
Sep 09, 2008 | Mitsubishi WS-65908 TV
Mitsubishi WS-65908 picture problem
since this happened after you moved i would look for loose connections on the convergence ic's
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Projection red is above other colors
Look in your menu for something called "horizontal static convergence" or just "convergence". Adjusting this will align all three tubes electronically. If physical adjustment is needed, then you have to do this manually inside the Tv. keever
Dec 09, 2007 | Mitsubishi WS-65908 TV
Mitsubishi ws 65807 RED CRT
What I usually find on sets like that is that there is a loose solder joint on the CRT board itslef. You must get to the bottom of the picture tubes, pull off the CRT board from the red CRT and examine all solder joints on that board. Chances are one or more will be cracked, and resoldering all joints on the board should clear up your problem.
Aug 04, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-65908 TV Logo
129 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
