Question about Sony FD Trinitron WEGA KV-27FS120 27" TV
Probleme de couleur du tv triniton sony kv-2199st
welcomejee
  • 10594 Answers
SOURCE: tv turning off
Hello
Sony FD Triniton Wega KV-36XBR400 service manual has no info for 11 times flash. It has info up to 7 falshes. Please count again. Error codes are in below pictures...
Regards,
Posted on Aug 27, 2008
SOURCE: sony kv-21x1u
Press and hold for a few Seconds the 2nd Button from the left on the front of the TV. The auto tune menu will appear on the bottom right of the screen. Wait until it disappears and then check the channels by using the buttons on the remote.
Posted on Oct 04, 2008
crazyhcris82
  • 34 Answers
SOURCE: How do I tune in Sony Triniton tv please
Hello
The first thing is to try going in the tv's menu
It should be similar to this:
Menu>setup>channel setup
once you find something similar, run the channel setup and it should add in the channels
If that doesn't work, screw on the cable wire, unplug the tv for a good few minutes, then replug the tv and it should automatically scan
Hope this helps
-Chris
Posted on May 01, 2009
  • 5 Answers
SOURCE: Dropped my TV :( Now all I see is a RAINBOW of colors...
Hello, my TV was dropped (rolled forward) and experienced the same problem. The shadow mask has shifted. In general this shift should be localized to section of the screen (usually the top). I managed to fix the problem using an array of magnets. It took a few days to arrange the magnets to compensate for the shifted mask. I used 10 strong small circular magnets. The picture has normal color but has some nonlinear streching (barely noticable) near the top of the screen.
Hope that helps if you need more advise try me at sunny3141@yahoo.com.
Sunny
Posted on Aug 27, 2009
SOURCE: Problem for Sony FD Trinitron WEGA KV-36HS500 36
ONE: Unplug it for at least 4 hours. That is what we call a hard reset.
TWO: If the hard reset does not help, then it will need further diagnostics.
The following bulletin may be of help in your learning about what is going on. Please refer to it below. Then let me know if you need further assistance.
Have a great day,
Cleggsan
Sony Blinking Codes
Many of the later model Sony TV's have a built in Self- Diagnosis function. If
the timer/standby indicator is blinking, this could be an indication of the
problem with the unit. The diagnostic blinking will occur automatically with no
action required by you to engage it.
The timing of the blinking you see would be as follows: two to eight blinks
(depending on the fault) about a third of a second apart, then pauses for 3
seconds, then the two to eight blinks about a third of a second apart again.
Here is a list of the problems that might have occurred indicated by the
number of blinks. The words in parentheses are those which you will see for
each of these faults on a diagnosis screen described later in this article.
Unit is dead and there are no blinks---Problem in the standby power
section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should
show open)
Continuous Blink Once A Second, No Pausing As Discussed Above---
No reply from the jungle IC301 (data bus is busy, shorted to ground or held
high), IK video path is defective.
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby
mode then displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single
horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with
the video. Check video out, Q705, 732, 761 and other components on the C
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and
blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
Intermittent problems ?? This is a great feature. You can also bring up
these fault codes ON-SCREEN to see a list of the problem numbers with the
abbreviation of the problem and the number of times this problem has
occurred. This is slightly different than entering the service mode. To see the
diagnostic screen, Press the following buttons:
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up
a screen with a list of the problems and number of times they have occurred.
Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
We have repeated them in parentheses in the text for the "Blinks" described
above so you can correlate between the diagnostic screen and the blink
codes.
So, now that you know about these self-diagnostics, how do you use them?
Say that you have a set with a black screen. You see that the LED is blinking
4 times....This would tell you that you have no vertical and that is why the
video is muted. If it was blinking 6 times, you would know that you have a
horizontal fault.
It's not a sure cure, but it's a little better than a poke in the eye with a sharp
stick.
IMPORTANT: after you repair the unit, PLEASE clear the values on this
diagnostic screen. These codes do not reset themselves after the fault is
corrected, so if you don't clear them, you'll be seeing "old" fault codes the
next time you enter this screen.
Clearing is done by going into the service mode ( display, channel, 5,
volume plus, then power ) then press 8 and Enter, which of course returns
everything to the factory preset condition.
Posted on May 31, 2010
My tv wont turn on ,It seem it is going to turn on and close itself
Searching for tv turns off but will turn right back?
  • Service Manual of KV-32XBR400 shows error info regarding red light flash 2, 3, 4, 5, 6, & 7 times only. Each flash corresponds to different problem in TV. Please check red lighe flash count again.
Nov 26, 2012 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Stand by timer sony triniton color tv Model kv-32hs420
How many times the standby button blinks before going OFF at one time switch ON?
Apr 17, 2012 | Sony FD Trinitron WEGA KV-32HS420 32" TV
TV SONY KV-DX 27 TDschedule service
have sony triniton color tv---kv-xg29.Turn it on, it blinks red twice ,but no picture or sound.what went wrong???is it the tube or burn out???
Feb 06, 2011 | Sony Televison & Video
Bonjour, j'ai un problème avec ma MP600. Elle n'imprime plus en noir. Pourtant lorsque je lance une impression noir et blanc elle fonctionne comme si elle imprimait, mais à la sortie, la feuille...
English to French translation bonjour il se pourrait que votre t?te sur votre imprimante est bloqu? aller ? la maintenance de votre imprimante et faire le nettoyage de vos t?tes dans la partie maintenance de votre imprimante, il vous dira everthing comment le faire
Oct 08, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Schema TV SONY KV 2584MT.
bonjour j'ai un probleme avec mon tv sony trinitron couleur KV2584MT c'est qu'apres 5mn d'allumage l'ecran s'eteint .on apuyant sur les boutons la led s'allume .pour reallumer il faut d'brancher la source et rebrancher et le meme probleme reviend merci de votre collaboration
Mar 30, 2009 | Sony Computers & Internet
Hi I have a sony KV-XR34/KV-XR29/KV-XR25 Triniton Color tv and a sony dvd player DVP-NS575P I want to use the dvd remote to control both tv channels and volume and to play dvd how do I do this I have been...
On the DVD remote there is a TV on/off button. Press and keep holding the button while you press 01. Now release the On/Off button. This will solve the problem
Dec 23, 2008 | Sony DVP-NS50P DVD Player
TV SONY KV-HA21M80 BG2T
Thanks for reply and nice to know that you are in Algeria.
You need to pay attention on Screen Volts as wrong G2 (screen volts) can be cause of 4 times blinks as you already replaced vertical out put IC.
You can download service manual of KV-HA21M80 from HERE and it is free. Download all 3 parts of file and use WinRaR to unzip it. You will have complete manual in pdf format.
Good luck.
Dec 19, 2008 | Televison & Video
Tv turning off
Hello
Regards,
Aug 27, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony kv-21x1u
Jan 05, 2008 | Sony KV-27S35 27" TV
Sony FD Trinitron WEGA KV-27FS120 27" TV Logo
120 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
