Question about Klipsch Audio Players & Recorders
Need manual for Klipsch SW-450 Powered Subwoofer
Instruction manual
Hi. I have a Klipsch sw-350 subwoofer and my problem is that it doesn't turn on. A fuse checked..and it checked out fine. Are there more then one fuse?
Only 1 fuse. Sound slide the auto turn on sensing circuit is out. Will need to be taken or sent for repair. Contact manufacturer for repair or replace the entire amp. Replace amps are available from sources like partsexpress.com
Oct 29, 2016 | Klipsch Audio Players & Recorders
Klipsch sw 350 subwoofer not working in auto on off position
The audio signal on the subwoofer output of your amplifier turns on the subwoofer after a brief delay to prevent "popping". Sometimes you have to crank up the gain to turn on the sub, then turn it down to a comfortable level. If this approach does not produce results, there may have been a component failure in the input circuit.
Jan 14, 2014 | Klipsch SW-350 Subwoofer Speaker
I have a Pioneer VSX-1123-k receiver and a Klipsch SW 450 subwoofer and the connection is not clear. Can anyone help?
Should be an rca connector on the back of the receiver marked subwoofer or sub preout. connect that to the rca connector on the sub and it should be good to go.
Sep 26, 2013 | Pioneer Audio Players & Recorders
Pioneer VSX-822-k Subwoofer problem
Go to manual setup, selct the subwoofer and set it to Pus.
Jul 29, 2012 | Pioneer Vsx-822-k 5.1-channel 3d-ready...
I have a Klipsch Sub-10 It is NOT working. I am not sure what happened. It was just fine last week. It's powered up and everthing but not throwing any bass. It was also detected during the auto setup.
If you're saying the auto setup produced sound then the sub and its amp are fine.
So we need to examine the source electronics for actual playback settings. Give a hint of what that might be.
Feb 19, 2011 | Klipsch Synergy Sub-10 Subwoofer Speaker
Klipsch subwoofer doesn't work with Pioneer receiver
Make sure the subwoofer is hooked up correctly and powered. Also, be sure to make sure the subwoofer is turned on in the Head Unit's settings which can usually be accessed via a button on the face of the Head Unit.
Best Regards,
James
Jul 21, 2009 | Electronics - Others
How to hook up speakers to emachine t3638? i have the klipsch 5.1 set
The EMachines T3638 comes with High Definition Audio support and you should be able to connect a 6 speaker system (1 subwoofer and 5 speakers).
I believe they are color coded as well. I believe the speaker set you are referring to is the Klipsch ProMedia Ultra 5.1. Is that correct?
Below is the a link to the connection instruction manual. It is a pdf document that you can print out. The instructions for installing the Speaker set is on pages 3 & 4 under Signal Connection and Speak Connection.
http://www.klipsch.com/media/products/owners-manuals/ULTRA51MANUAL_ENGLISH.pdf
It should be pretty straight forward, but send me a note if you have any questions about the process.
MO
Jul 13, 2008 | Computers & Internet
179 people viewed this question
Top Klipsch Audio Players & Recorders Experts
rhodesworks
richie46
Are you a Klipsch Audio Player and Recorder Expert? Answer questions, earn points and help others
