Question about Kitchen Ranges
I purchased a used Jenn Air gas range. I discovered most of the model # was unreadable. I need an instruction booklet and seals for the the top burners. Just tried to contact Jenn Air to see if they could help figure out what my model # would be but they are not open on the weekend
    Top Expert:
  • Kitchen Ranges Master
  • 34,814 Answers
If Jenn Air is unable to help, try an appliance parts supplier
Posted on Apr 20, 2013
5 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Problem with conversion of used Whirlpool Range from NAT to LP
Take a 1/2 inch open end wrench and adjust the orifice on top of the oven gas valve.
Tighten it down until the flame is normal. Blue with white tips.
Posted on Feb 21, 2009
SOURCE: Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Posted on Sep 05, 2009
SOURCE: My gas bake burner won't ignite.The igniter is
If the bake ignitor comes on - check the amperage on the bake ignitor wires when it's on. Amperage should be 3 - 3.6A. If less than 3A - replace ignitor.
Ignitor part numbers (any will do, but the first one is a direct replacement): 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
All those are interchangeable, if you can splice the wires.
Posted on Jul 15, 2010
blueextc3221
  • 15935 Answers
SOURCE: jenn-air gas range probe light f1-10 code
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
Jenn-air jdr8895 sabbath error
Faulty range/oven parts aren't the only worry a gas range owner has; the threat of carbon monoxide is very real and should be paid close attention to when doing repairs on the range.
If your range or oven gives off soot, you definitely have a carbon monoxide problem. Soot is the result of inefficient or incomplete combustion. There are always elevated levels of carbon monoxide with soot production. Properly adjusted range/oven parts do not give off soot. You may have poorly adjusted gas pressure, the air shutter may need to be opened, or you may be supplying fuel the oven isn't designed to handle. Don't use natural gas in liquid propane stove or vice-versa.
Increase Engine horsepower.
Jun 02, 2012 | Jenn-Air JJW8230D Electric Double Oven
I purchased a house w/ a Jenn-air elect. drop-in range. The Model # is 87946 or 87847. I believe the range was originally purchased in 1975. I am in need of an instruction manual .
Neither of these are a typical Jenn-Air model number. http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US suggests that the model number is on the back wall under the burner on the right side of a drop-in cooktop. For a range the model number is often on the frame inside the oven door, below the vent or on the back of the top of the range.
87946 or 87847 are the part numbers for the cartridges (the elements or the surrounding housing).
Look at the model number locations at the "Help me find my model number" link and try to locate a model number on your range. Then enter that model into the search box. The manual is probably available with the correct part number. Most Jenn-air electric cooktops start with JEC in their model number.
I hope this helps you locate the manual.
(I did try JEC87847 just in case you left off the leading alphabetical characters.)
May 08, 2011 | Jenn-Air Microwave Ovens
I purchased a jenn-air model JDR8895AAS LPgas range and want to convert it to natural gas.What do i need?
you may need to not change anything but i have not experienced that yet but look around and see if you pull anything up on google
Jan 02, 2011 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn Air JGR8750 - Oven heats _very_ slowly; take 45 to 60 minutes to heat to 450ºF. I can hear faint ''whump whump whump'' from the oven as it heats. Purchased in 1998.
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Sep 28, 2010 | Jenn-Air JGR8750 Gas Kitchen Range
No wattage given with electrical requirements for gas cook top
A gas range requires minimal electric current. "Any ole" circuit will do.
Charlie
May 13, 2009 | Jenn-Air JGC8430 Gas Cooktop
Jenn Air gas cooktop
pop me an email at b4829@yahoo.com and reference your cook top you can rate me later
Mar 29, 2008 | Cooktops
Jenn air range
1.black top nice and shiny, as far as streaks your gonna ahve to find a cleaner that works for you , i have a black cooktop and my wife uses clorox wiped to clean and then with paper towel wipes off and dries
2. as far as "saddle grill" calling the manufacture (number inside your manual) will be best source of info on that, of course unless you can find an aftermarket 3rd party maker
Mar 15, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Don't know if the oven part of range is gas or electric
open the door on the left side low down you will find the model and serial number .
Visit the jenn-air website @ www.jennair.com or click
https://www.jennair.com/customer_care/contact_us.jsp
to email them and they can tell from the serial number and mail you back...
Nov 15, 2007 | GE JBP68 CleanDesign Electric Kitchen...
Installation of down-draft exhaust duct for Jenn-Aire cook top
We're buying a JES9900BAF for an island and found ducting instructions in the installation guide. Go to jennair.com and find the page for your range model. Then click on the "Specs/Literature" tab (it's about 2/3 down the page). The installation guide is a PDF document.
Nov 07, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Kitchen Ranges Logo
164 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
