Question about Saws
The blade wont turn - Saws
    Sergeant:
  • 468 Answers
What do you mean with that? Can you add more details? You may want to visit this blogsite for proper instructions for blade tracking, installing blade and tensioning the blade.
Posted on Apr 22, 2013
2320 wont maintain rpm when mower deck is engaged drops to 1500 or less and stalls out motor. everything seems to be turning properly.nothing obstructing blades
Would check blade spindle bearings, loosen belt to deck and try to spin blades they should turn freely if not probably bad bearing in spindle.
Oct 10, 2017 | Garden
Why wont the blade turn
Something is damaged, worn out or broken.
Sep 17, 2014 | Food Processors
Why wont my hp pavilion all in one turn on?
Problem with Andis ProPet Clipper Kit in Storage Case with size 10 detachable blade set- Model MBG2
May 23, 2014 | Andis ProPet Clipper Kit in Storage Case...
Mower blades wont turn while sitting but turn when you stand up
I think you have a switch under the seat, which is malfunctioning
Mar 24, 2013 | John Deere 22HP VTwin 48" Riding Mower
Blades will not turn on lawn mower
You haven't given enough information of the problem. The blades themselves wont turn when you try to spin them by hand or they wont turn when you engage them with the lever or the switch?
Jan 11, 2013 | Yard Man Yardman Riding Lawn Mower 38in...
Ninja blender blade wont turn with food in container.
make sure blade is pressed tightly onto shaft... should click into indent. if not then you need a new blade piece.- stripped
Aug 18, 2012 | Blenders
Cub cadet rzt 50, hit stump, blades wont engage but not bent
The blades on this cub cadet are activated with air pressure. Chances are that when you hit that stump, you either blew a fuse or the control module that allows the blades to spin. Begin by checking the fuses. J.
May 28, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Blade wont tighten
Here are some directions on installing the blade to ensure the proper procedure has been followed when installing.
  1. Set the blade orbit selector lever to position III.
  2. Fit the supplied screwdriver into the top plunger hole and loosen the internal blade securing screw about 3 to 4 turns counterclockwise.
  3. Insert the blade into blade plunger at a 90° angle to the cutting direction. With a slight upward pressure, turn the blade teeth forward (direction of cut) and guide the back of the blade into the groove in the center of blade roller guide.
  4. Pull gently down on the blade to seat the blade tabs in the plunger.
  5. With the blade in the proper position, securely tighten the blade screw by turning the screwdriver clockwise.
I hope this helps. Please rate on how helpful the answer was. Good Luck and have a great weekend.
Apr 03, 2010 | Bosch 1581AVSK Top Handle Jig Saw Kit
The blades wont turn around when its turned on it just clicks once and then does nothing
It sounds like one of the blades is damaged causing them to lock up. Take each of the heads out andturn the blade insice the comb with your fingers on each one. They should turn freely. I speculate that one of them is damaged and the blade is embeded into the comb not allowing it to turn. If this is the case, you will need to replace the heads. You did not mention your specific model number so I cant direct you to the correct blades that you require. You should be able to find blades for your model at shaveroutlet.com
Jan 31, 2010 | Philips Health & Beauty
Auger blades won't turn
You need what they call a "friction wheel" replaced.
Oct 31, 2009 | Garden
Saws Logo
32 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
