Question about Saws
Blade won't rotate
It powers up but the blade will not go round
    Sergeant:
  • 468 Answers
Are both two wheels turning?
Posted on Apr 22, 2013
Wheels won't turn, runs and blades work
if by turn you mean they wont rotate, then check if parking break is on, if you mean you cant turn the steering wheel, or cant make make it go around corners, then check the linkage
Apr 20, 2013 | Cub Cadet Riding Lawn Garden Zero Turn...
Toro self propelled mower. blade won't stay tight
Use a block of wood to hold blade stationary while tightening bolt. Ensure threads are cleaned with a wire brush before tightening. Is there a spacer or washer missing?
Jun 26, 2012 | Toro Power Lawn Mower
S107g won't take off
I may be out of my area of expertise on this one, but it is possible to install the blades backward? That would cause the copter to try to go downward with the normal rotor rotation....just a friendly suggestion.
Dec 30, 2011 | SYMA Toys industrial New Syma S107 Radio...
Shark SV736R motorized brush won't rotate
The 2 metal pins of the motorized brush are not in contact with the vacuum cleaner. or the Motorized brush is clogged up. You have mentioned that it is cleaned, but still give a thorough inspection. For the metal pins, firmly insert the motorized brush into the air-intake nozzle. This will connect the motorized nozzle to the unit power supply.
Oct 21, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Hi there I've recently made a buscuit mixture using the large bowls and large blade. However, I am unable to remove the blade from the mixer or the bowls. The handle turns anti clockwise but...
Hi Leisha,
It is just about impossible to insert the paddle wrong ( I assume this is a mixer, not a microwave, please post in appropriate department on next go round ) so can you unlock and raise the head? I have not heard of any type of mix not being able to be removed before, perhaps you are missing a step???
Sep 17, 2011 | Microwave Ovens
Badger insinkerator, 1/3 HP does not start. Please help...i try the red button and didn't work...the blades aren't rotating....
Use wood broomstick handle down into disposal.
Wedge broomstick against side of sink opening and rotate blades free.
Or use allen wrench on bottom of disposal to free cutter blade.
If blades rotate freely and disposal has power, and reset is not tripped or will not reset, then disposal is bad.
I wrote ez disposal replacement steps:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Sep 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a Porter Cable biscuit jointer, model 527 and I'm an amateur woodworker, NOT a mechanic. I can't locate my owner's manual on this tool and have the smaller blade in the tool currently. ...
Model 557 is shipped with a 4" diameter blade installed. This blade is used
for all operations except for the "FF" biscuit. The "FF" biscuit requires that
the 2" blade (furnished with the tool), be installed as follows:
DISCONNECT TOOL FROM POWER SOURCE.
1. Loosen four blade cover retaining screws (A) Fig. 10, and remove blade
cover.
2. Depress and hold spindle lock button (B) Fig. 11, while rotating blade by
hand until spindle lock engages.
3. Continue to hold spindle lock button while using the 5/32" hex wrench
(furnished with tool), to remove blade retaining bolt and flange, (by
rotating counterclockwise).
4. Remove blade and store in a safe place for future use.
5. Place 2" diameter blade (furnished with tool), onto blade mounting
flange (orient with teeth facing in same direction as directional arrow
cast in housing, see Fig. 14).
6. Position blade retaining flange (flat side out), to spindle, insert blade bolt
and rotate clockwise until hand-tight.
7. Depress and hold spindle lock button (B) Fig. 11, while rotating blade by
8. Continue to hold spindle lock button while using the hex wrench
(furnished with tool), to tighten blade retaining bolt securely, (by rotating
clockwise).
9. Rotate the "quick set" depth adjusting turret (A) Fig. 12, to the "FF"
position.
10. Lift safety lever (A) Fig. 13, fully retract the plunge mechanism, and
reposition the safety lever as shown in Fig. 14. Slowly release pressure
on plunge mechanism.
11. Reposition blade cover plate to tool, and secure in place with the four
retaining screws (removed in step 1).
DO NOT OPERATE TOOL WITHOUT BLADE COVER INSTALLED
Sep 06, 2017 | Masonry Tools
I'm trying to change the blade on my Plasplugs tile wet saw, after not having used it for over three years. No matter what I do, I can't get the nut off! I've tried WD-40, graphite, hammering...
Try rotating the nut COUNTER-CLOCKWISE.
Usually, nuts and bolts are Righty-Tighty, Lefty-Loosy, but frequently saw blad nuts use a Lefty-Tighty, Righty-Loosy.
They are built so that when the blade starts to turn, it puts a momentum on the nut that tightens it, so that a loose nut won't come flying off, and get someone injured.
Jun 26, 2011 | RTO Plasplugs DWW406US Power Master Wet...
I have a circular saw that is locked and the blade won't rotate its brand new how do you free the blade?
Its sounds like the blade lock button is depressed.
looking from the rear of the unit, you should see a button between the left side of the handle and behind the blade shield.
check that. it probably is locked in the depressed position or it may be damaged.
I hope this helps.
May 18, 2011 | Dewalt DC390K 18v Cordless Circular Saw...
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
