Question about Garden
What is the right throttle cable replacement for the fr44 mcculloch?
Gas trimmer bought at yard sale for $5...tickets says runs fine but needs throttle cable. Can't seem to find any info on this product that is conclusive on the right model replacement. Any help?
gisvc
  • 40 Answers
SOURCE: I need a manual for a McCulloch Timber Bear Model#60013414 chains
hi,
i believe this is the manual you are needing it is on ebay Item number: 150322102913 rtcurve.gif
good luck.
Posted on Mar 29, 2009
  • 4088 Answers
SOURCE: need to replace gas line inside mcculloch chain
You need to disassemble the case to get to the fuel tank. Pull out the plug fitting and replace the internals with new factory grade parts.
Posted on Jul 04, 2009
dontbother10
  • 2220 Answers
SOURCE: Need to remove & replace primer bulb on mcculloch mac 3516
There are 4 different IPLs for this saw. Fuel detail are on multiple illustrations.
http://www.ordertree.com/modelinfo/MCC/22-600035-18-Mac-3516-IPL-211318-01/139.22-600035-18-Mac-3516-IPL-211318-01.1.59.1.html
A helpful video, a few of my suggestions, and a schematic follow:
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly.
HTH
Lou
Posted on Nov 16, 2009
cmcduncand
  • 714 Answers
SOURCE: chainsaw won't stay running at full throttle
15 years old...
One cause to look in too is a leaking seal around the crank, this is causing a vacuum leak.
Hope this tip helps.
R/
David
Posted on Jan 29, 2010
smartr10U
  • 1305 Answers
SOURCE: i bought an older montgomery ward chain saw at a
Here's some basics.. a typical gas oil mix is 40:1 to 50:1... in that range you'll be fine. Also clean the air filter, check the fuel filter and clean and/or replace the spark plug. If the gas has been in it for a while... clean it out...It may run fine for a bit,but it will most likely be harder to start, and eventually gum up the carb and lines and foul the spark plug.
so if you got those things cleaned and serviced.. you should be pretty good to go..
Starting helps:
1. close the choke and prime with the prime bulb if it's got one, then pull it thru a couple of times until you hear it try to unsuccessfully start.
2. Set the choke 1/2 way and pull it again, it should start and once it builds up a bit of pressure in the gas tank, you can set the choke to off and you're up and runnin'.
I couldn't find any model info for you, but a local saw/lawnmower shop should be able to dial in parts for you.
Posted on Apr 22, 2010
Feather lite trimmer only runs on half throttle and idle dies on full throttle. unit is new
When I bought a new poulan gas trimmer, I had the same problem. Solution was to return it and get another one. They come with problems, even new. Just keep returning them until you get one that works correctly. Mine works great, but like I said, had to return it and get one that was right.
Jul 01, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Need Gas Line installation instructions for a McCulloch Lawn Trimmer I bought New Neoprene tubing (Gas line) for My McCulloch trimmer model B400128-11. The old lines hardened over the years, and broke off...
Hi Start from the filter in the tank to the bottom of the carby then from the top of the carby to the short primer pipe then from the long pipe on the primer back to the tank. Hope this helps.
Aug 24, 2009 | Garden
My Kawasaki Trimmer is running bad. It will run
Check the throttle cable. You probably need to tighten it up. You will find it on the left hand side of the engine that is mounted it the top of the trimmer, thats where it normally is, but with the japanese you wouldn't know!! Have a look for it, won't be hard to find anyway. Also check the finger throttle. probably slack too.
Once you found the throttle cable at the top, find a optimum idling value and then tighten the cord at that point. (there should be an adjustable screw there.)
Hope it help's.
Hughie.
Jun 16, 2009 | Troy Bilt Tb70ss Gas Trimmer
My TB475SS starts and then dies right away. i
It usually wont idle very well when it's cold, Goto #1 on the choke give the rope a couple of "quick" tugs, and then move it to #2 Give it one or 2 more tugs with a little throttle, now it should be running witha little throttle, let it run like that for a minute then move it to #3 kinda still pumping the throttle a little and it should take off fine. If this is the 4 stroke, mine did the same thing until it was broke in good. (About 4-5 uses), now I have to say its more reliable than any 2-stroke I've owned and I use it commercially. 1st or 2nd pull everytime and is ready as soon as it fires! Hope this helps!
Apr 14, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
