Question about Mtd Garden
Engine brake cable and lever stuck - Mtd Garden
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 49 Answers
Soak top of brake cable with WD/ 40 or liquid wrench let it sit for a while then spray again move bar back and forth carefully to loosen cable repeat till it loosens up and moves free
Posted on Sep 13, 2013
Ford Galaxy 2011 gear stick stuck in park won't move
Lots of modern vehicles fitted with auto transmission have a safety lock preventing the gear lever being moved unless the ignition is on and the brake pedal applied.
This probably applies to your car and if the system is faulty it will leave the gear lever stuck. Usually it is possible to hear the lock release.
If the transmission end selector lever is accessible, disconnecting the cable or rod from the lever and moving it by hand will provide a clue whether the problem is inside the box or the cable or gear lever.
Jul 02, 2016 | 2011 Ford Galaxy 2.0
Emergency brake stuck to floor will not release
Hi Barbara:
I'm guessing that when you pull the release handle it moves, but nothing happens.
Odds are that whay has happened is that the cable has come out of the release lever, Or, the cable sheath has slipped out of its retaining slot.
Either way, you have two things to do:
1) Get mobile so you can go home. To do this, put it in park or low gear with the motor off. You will need to access under the dash where the release mechanism is located. Use a pair of pliers (or whatever else will work) to pull or pry the release lever away from the firewall (towards the seat. The parking brake will release.
2) Go home (or wherever, just don't use the parking brake.
3) Repair the brake:
- Release the Cable Sheath from the retaining slot.
- connect the cable to the release lever
- Re-install the cable sheath into the slot.
Ta Da!!!!
Mar 26, 2016 | 2004 Nissan Quest
Problem Starting Mower
if the brake cable does not disengage the brake all the way the pull cord will not work properly.It will seem stuck.
Apr 02, 2015 | Gcv160 Gas Engine
Park brake stuck on
if you look under truck at the backing plates you can see the cables going in. there is a spring and a lever.take a hammer and punch to tap the levers away from springs(to make cables longer) it should release brakes
Jul 25, 2014 | 2005 GMC Canyon Extended
Gear lever stuck in park.
usually a cable that moves when pressing brake pedal that takes gear lever out of lock allowing you to move gear lever. check the cable.
Nov 28, 2013 | 2002 GMC Envoy
I used my cars emergency brake for the first time over the weekend. I released the brake but it seems to be stuck and the car doesnt want to move either forward or backward. It's like the brake is stuck....
Ok not sure what car u have but most rear brakes are the same unless it has disc brakes on the rear. Release the brake and then crawl under the car and look at the back of the rear brake drum, you will see a cable going either in or across the rear drum to a lever.Try tapping the lever away from the cable and see if this frees up your brakes. Good luck.
Aug 23, 2010 | Chevrolet Cavalier Cars & Trucks
1986 Fiero: my e brake on my 85 fiero is stuck and i need it t...
It probably got stuck from lack of use/lubrication. But if your lever is also stuck up it could be a function of the actual lever action. I'm assuming you tried pushing the button in to release the lever?
Step 1) Get a haynes manual if you own a fiero, VERY valuable tool
Step 2) Check the physical action of the lever, is the lever not releasing down because of the lever itself? --> frozen/rusted? something physically blocking it on the floor of the car? Or is it not releasing due to the cable tension?
It's been awhile since I looked at it, but there should be a way to take the cover off of the lever to see the cable come into the shaft from underneath the car. Follow this cable to the rear of the car where it goes to the driver side rear brake caliper, then across the car to the passenger side caliper. You can adjust the tension for the cable using the nuts on the cable.
Also, there is a spring on each caliper that is supposed to put tension on the cable when pulled, so when released the cable returns to driving position and thus releases the brakes. Are these springs missing?
Are the brakes engaged because of the e-brake being stuck?
If you are in a pinch and need to use your car and can't because the brakes are on due to a stuck e-brake, it's not smart and can be illegal in your state, but you could just cut the e-brake cable. Should be pretty easy to do where it meets the lever on the inside of the car.
Let me know if you need more help
May 16, 2010 | 1986 Pontiac Fiero
How do i remove the front brake cable? im having a
Is it off the brake lever on the handle bar? If not shorten the outer cable by turning in the knurled adjuster at the back of the brake lever. This will make it easy to take the inner cable off the brake lever. Once that is off you can work on the hub and you should now be able to swing the inner cable round to slide it off the lever on the hub. If that is damaged it might be difficult to clear the cable and the end nipple, so you will need to open the gaps using a flat screwdriver as a lever. When you put it all back together it will help to lubricate the inner cable with some engine oil which you can run down the inner from the brake lever end. Moving the inner cable up and down helps the oil to travel down the cable.
Mar 16, 2010 | 1972 Suzuki T 350
I have 1996 galant. the emergency brake light is on and seems like the brake is stuck although the lever is down. the brakes are grinding and the car does not roll when in neutral. i checked the brake...
your emergency brake cables or at least one is frozen up or the brake shoes are frozen to the drum try removing the stuck tire and pour boiling water on the brake drum this should free up the shoes,the light is on because of the lever is not all the way down until cable goes back to normal.
Feb 01, 2010 | 1996 Mitsubishi Galant
Unable to pull start cable. seem as if cable is stuck
make sure you are holding down engine brake lever before starting
take out the spark plug and try to see if it will spin and look if any oil shoots out spark plug hole. let me know
Jul 14, 2009 | Craftsman Garden
Garden Logo
47 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
