Question about Pioneer VSX-D407 Receiver
Vsx-d407 unit says poweroff
I plugged in my receiver and it says poweroff. it has been like this for some time now and im trying to find solutions to fix it can any one help
SOURCE: PIONEER VSX D810S POWEROFF
Hay que chequear los alambres de los parlantes..yo tuve el mismo problema..desconectè todos los alambres de los altavoces y luego los reconectè...y allì estuvo la soluciòn...
Posted on May 29, 2008
SOURCE: VSX-D308
Maybe the audio amplifier IC is damaged and you gotta change it.Good luck.
Posted on Jun 12, 2008
dthomas1969
  • 4 Answers
SOURCE: Owner's Manual - Pioneer VSX 455 Receiver
It should be compatible with all of them. I have one that works just fine with my Sony HD/TV, HD DVD PLAYER, etc. The only difference is that its is stereo w/ a middle speaker hook up, if you so desire.
I find it just as enjoyable and easy to use as my Denon 6.1 with fewer speakers. That is because as men, our hearing range is poorer especially as we grow older.
Email me with any other concerns you may have.
Thanks,
dthomas
Chicago, IL
dbondick@comcast.net
Posted on Feb 07, 2009
  • 336 Answers
SOURCE: I have receiver VSX-D509S. Have had it for
Check for a bad ground on the input circuit board. you will need to re-solder them. Remove top cover and rear panel (many screws on rear panel) The input board can easily be accessed and resoldered. you should also check for a bad ground on the speaker jacks. If it is not repaired, sooner or later you will probably need an output IC. good luck.
Posted on Oct 16, 2009
  • 336 Answers
SOURCE: VSX-D457 Display's power off and then shutdown
Most likely it needs one of the output ICs. But check for cold solder rings on the ground connections of the input board. Est. for it to be repaired $100-$120
Posted on Dec 17, 2009
Will not turn on
Have you tried to plug it in? if that doesnt work, try to see if any of the connection is fryed or clipped on the back.
Mar 03, 2011 | Pioneer VSX-D407 Receiver
Poweroff indication with no output
Have you tried the owners manual (not the repair manual)? It will probably have something about this. It may be that this is the generic message that the unit gives you when you have a bad output channel which would put it into a protection mode.
Jul 29, 2007 | Pioneer VSX-406 Receiver
I have a VSX-D407 receiver. Unit says "power off" after I turn the receiver on...and immediately shuts off.
Probably needs an output IC. but check for bad solder connections on the input board. If you get it serviced I est. about $90-$120 for the part and labor.
Dec 06, 2009 | Pioneer SX-205 Receiver
I have a VSX D710S and it flashes poweroff then
Im having this same problem. It happened after I had the music up really loud for about 3 hours. Also, where it has the volume all i see is -- instead of a number when i try to turn it on
Nov 29, 2009 | Pioneer VSX-D906S Receiver
Oct 16, 2009 | Pioneer VSX-D509S Receiver
Mar 30, 2008 | Pioneer VSX-D810S Receiver
Components do not work
Yes there is bound to be at least one internal low-voltage fuse - so get inside with unit completely removed from any mains source!!
Good luck.
Mar 04, 2008 | Pioneer VSX-D407 Receiver
Pioneer vsx-456
I have um Acquitance Groundbreaking VSX -456 as you I turn on appears Poweroff and he turns off automatically if he may go feasible ma ajudem,pois did not what to do. thank you Awaiting recurrence for its email: domingosdsm@globo.com
Nov 20, 2007 | Pioneer VSX-456 Receiver
Vsx-d506s problem
It may be a PROTECT MODE. Check is your other equipment properly connected to receiver.
Oct 09, 2007 | Pioneer VSX-D506S Receiver
POWER OFF alert
When you turn on receiver it will power off. Poweroff shows up and than turns off. if the front panal reads over load the output ic pac001a is defective i had repaired this model before
May 29, 2007 | Pioneer VSX-D710S Receiver
Pioneer VSX-D407 Receiver Logo
46 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
