Question about Frigidaire Refrigerators
Frigidaire frt04l5db0 wont start, has light working and thats all
Model frt04l5db0. Light comes on and that is all. Will not cool or start cooling. Please help. Tom
HVACRH20
  • 237 Answers
SOURCE: Not cool at all!
If the compressor is running you should be cooling unless there is a major loss of refrigerant. What we do for these complaints is to first let the refer run for a few hours then pull the interior rear panel off the freezer section back wall and check the frost pattern on the coils. It should be a nice white frost pattern all the way across the coils (no bare alum. showing and no mass of ice either). If you don't have that pattern then there is a sealed system issue. If you have a massive block of ice all over the coils then you have a defrost cycle issue (not getting proper air circ. due to the block-o-ice thing). Let us know what you find... oh, you can sometimes find the leak by looking for oily residue from the compressor lubricating oil (it leaks out where the gas does also).
Posted on Jan 17, 2007
SOURCE: Frigidaire stand alone Refrigerator won't cool Fans and Compressor work
Ended up having a freon leak in tubing around door. Luckly the warranty was 5 years in sealed system. New one was FREE.
Posted on Feb 23, 2008
SOURCE: Refrigerator not cooling freezer working fine
Refrigerator suddenly not cold enough . Drip pan clean and dry. No dirt or dust.
Posted on Oct 06, 2008
joecoolvette
  • 5660 Answers
SOURCE: Frigidaire model ftr18b freezer works, fridge is only cool
Info relating specifically to the Frigidaire FRT18B5ABB:
1.Refrigerator unplugged remove the bottom back panel. (Access cover with label. The rectangular shaped panel on the back, at the bottom) Place the screws in a container.
Also remove the Kickplate Grille in the front, and the defrost pan.
2.Use the wand tip on your vacuum cleaner, and vacuum this area out. Pay special attention to the condenser coils, and the fan. Use care as you don't want to bend the fan blades. After you have vacuumed up as much as possible, see if your vacuum has where you can attach the hose to blow air through it. An air compressor, hose, and air nozzle would be REAL handy right now! Blow the condenser coils, and all areas clean of any gunk. (Hair, spider webs, etc.) If this is not feasible for you, you'll need some sort of long, thin, dust 'bunny', and have to dislodge this 'gunk' physically. Then vacuum.
3.BE SURE to replace the bottom back panel, (Access Cover)! It is a VERY necessary item! If your fridge doesn't have one at present, make a temporary one of cardboard, and tape it on. This access cover is needed.
If your refrigerator side is only cool, and your freezer is cold, you may have a problem with the Cold Control, (Temperature Control), or the Defrost Timer. (Timer-Defrost)
http://disruptit.com/manualgateway.cfm?pdfwanting=34242&username=anon&AV=123345&I=99.169.118.45
Posted on Jul 05, 2009
We had a similar problem - it was the compressor start device. Ordered a new one from repairclinic.com, and it works great now. The old start device rattled when we shook it. We opened it up and found lots of burnt little bits. Check to see if your compressor kicks on & off a lot. Ours would run only about 10-15 seconds, then go off for a minute or two - then back on for a few seconds. If that is happening, it could be the start device. Hope this helps.
Posted on Aug 13, 2009
Frigidaire refrigerator wont cool or freeze
Hi Teddy,
It's my understanding that your Frigidaire refrigerator, model# MRS20WRGW2, has power with the lights coming on, it's just not cooling in the freezer or refrigerator portion. Since you are receiving power to the appliance, I would check to see if you can hear the compressor running. If the compressor is not running that might be why your refrigerator is not cooling. Still, I would contact a local authorized technician, for a full diagnosis. This way it can be determined what exactly is the cause of the NO COOL issue.
-Best Regards-
WP
Apr 04, 2014 | Frigidaire Refrigerators
We have a frigidaire model number frt045gb upright freestanding fridge and the light is on inside but the motor isnt running,it is warm in the freezer and fridge part
Since the light comes on, but nothing else runs, check the defrost timer. If it is stuck in the defrost cycle, the light will come on, but nothing else works.
BGA
Apr 19, 2011 | Microwave Ovens
Same model as alot of others posting FRT04L5DB0 COMPRESSOR will not kick on all else works fan is on and with freezer door open and goes off with fridge door open and closed light is on evap is...
Hi this is either a shot compressor or start relay for the compressor, relays are $25-50.00 you could try that first if ifts the compressor your looking at $500+ to have it changed.
Sean
Mar 28, 2011 | Refrigerators
Frigidaire model cfmv156fmc allows programming, lights work but when hitting go wont turn on yet timer is counting down.
If the inside light comes on when you try to cook, but the turntable and internal cooling fan do NOT, then that's a bad bottom door switch or that switch's mount.
See this helpful text file.
If the inside light, turntable, and internal cooling fan DO all come on when you try to cook, but it does not cook, then you have a bad relay or connection on the control circuit board, which we can repair for $39.95. Details here.
We have the service manual and have uploaded it to our site here to help you.
Jan 11, 2011 | Frigidaire Microwave Microwave Oven
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
Fridge powers on but does not cool
Try pressing light blub switch whist doors are open as fan will only start when doorsclosed. If compreesor is running but not chilling it is either the compreesor has gone and wont be pumping or it has lost its refigerant. Hope this helps
Aug 23, 2007 | Frigidaire FRT18B4A Top Freezer...
Self cleaning oven instructions
I tried pressing clean then the up arrow. Nothing. THEN I HELD DOWN THE UP ARROW FOR A FEW SECONDS AND 3 HOURS CAME UP AND it worked and my oven is now cleaning itself. Remember...HOLD DOWN the up arrow for a few seconds and it will work
May 26, 2007 | Frigidaire FEF352 Electric Kitchen Range
Refrigerators Logo
66 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
