Question about eMachines Computers & Internet
JLPC connector wiring diagram
Wiring diagram
I need the wiring diagram for a Toyota AD6801 model 09355959 radio
If it is the one that came with the vehicle, Google
year make model (of the car) wiring diagram
and look at the images tab. The wiring diagram for the car shows the wiring for the radio.
There is this site as well
http://www.tehnomagazin.com/Auto-radio-car-connector/TOYOTA-Car-Radio-Wiring-Connector.htm
Google
Jan 09, 2017 | Toyota Cars & Trucks
I have a DELPHI fuel pump but no wire diagram how do I find out what wires go to what wires
Hope you marked the wire colors, on how the old connector was wired? Was the old connector numbered or lettered?
If you want a wiring diagram, I need year--make--model?
Oct 09, 2016 | Cars & Trucks
Wiring Diagram For Usb flashdrive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually ((red white green black)) make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
or
PRODUCT NAME
FRONTX USB Type A Internal
PRODUCT CODE
CPX101-2
BAY USAGE
Half of large bay
CONNECTORS
USB type A female
1x5 header connector female
CABLE
USB cable (UL 2725)
Length - 2.5 feet (762 mm)
WIRE ASSIGNMENTS
Red: + 5V / Voltage + / VCC
White: D - / Data - / USB -
Green: D + / Data + / USB +
Black: GND / Voltage - / Ground
Black: S-GND / Over Current / Shielding
The S-GND wire is fatter and can be easily recognized. The connection of S-GND wire to the header pin is optional.
HEADER CONNECTION GUIDES
Diagram 1: On most motherboards, the USB header/pin-out consists of 9 pins arranged in 2 rows, which allows for 2 USB connections (i.e. USB1 and USB2). Normally, the pins for USB1 and USB2 are in seperate rows.
Diagram 2: Simply plug the connector onto the 5-pins row, and make sure that the pin assignments and wire assignments are matched correctly.
Diagram 3: Alternatively, you can plug the connector onto the 4-pins row, and leave the S-GND wire unconnected.
You might have to rearrange the wires to match with the pin assignments, or change the header connector if necessary, depending on the layout of the USB header.
On some motherboards, there is a NC pin in the USB header. You can connect the S-GND wire onto this pin. NC simply means "no connection" and NC pin is an "empty" pin.
2X5 PINS HEADER
Refer to the diagram below, for 2x5 pins header, simply plug the connector onto one row of the pins, and always make sure that pin assignments and wire assignments are matched correctly. You might have to rearrange the wires if necessary.
2X4 PINS HEADER
Refer to the diagram below, for 2x4 pins header, simply plug the connector onto one row of the pins. Please note that there is no S-GND pin in this header. You can leave the S-GND wire unconnected. You might have to rearrange the wires if necessary, in such that the wire assignments and pins assignments are matched correctly.
ACTIVE PINS NOT IN THE SAME ROW
On some motherboards, the 4 active pins are not located in the same row, as shown in the example below:
To connect to this type of USB header, you need to change the header connector to 2x5. Simply rearrange the wires within the 2x5 connector to match with the pin assignments. If the green wire is connected to the USB2+ pin, the white wire must be connected to the USB2- pin. The red wire can be connected to any +5V pin, and the black (GND) wire to any GND pin. If there is no S-GND pin provided, you can leave the S-GND wire unconnected.
hope it helps
Sep 23, 2012 | Lexar Media Echo ZX 32 GB Flash Drive
Looking at vehicle module which is a port and b port
If you are refering to the Engine Control Module (ECM) for your 1987 Blazer, there are two connectors. One is the "A/B" connector (24 Pins) and the other is the "C/D" connector (32 Pins). The letters represent the rows in which a particuler wire or wire connector can be found. For example, if the wiring diagram shows the wire to be going to ECM connector B4, The actual location would be in the 24 pin connector at the ECM and would be the fourth wire in the "B" row of connector pins. SEE DIAGRAM BELOW.
Apr 10, 2012 | 1987 Chevrolet Blazer
P0340
I think the 2004 Accent only came with a 1.6 liter engine as far as I know. In any case below is as much information I have as far as your code including a wiring diagram of that circuit (CMP sensor). The wiring diagram doesn't tell the wire colors but does tell you where the wire goes or what "pin" number it is at the connectors. I included the connectors which is by number and marked the ECM connector for you. I had a picture of the CMP sensor location but not the ECM location but can tell you the ECM connector is located behind the dash fuse panel. Hope this helps....
Mar 14, 2012 | Hyundai Motor 2004 Accent
Need a wiring diagram for a Insignia ns-c5112 cd car stereo
you can order one from here:
http://www.mcmelectronics.com/product/INSIGNIA-/C-501800-77235
I had a wiring diagram, but I sold the radio and the diagram went with it.
Apr 04, 2009 | Car Audio & Video
PS2 Controller Wiring Diagram
heres the diagram
http://www.curiousinventor.com/guides/ps2
Dec 09, 2007 | Sony PS2 Dual Shock 2 Controller...
Computers & Internet Logo
212 people viewed this question
Top eMachines Computers & Internet Experts
brian soufane
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
