Bluescreen 0x00000050 error on laptop won't go into safe mode or command prompt
Hi, my very young niece has a phillips feevents x50 laptop , it now won't load windows xp home edition , it just restarts over and over to safe mode option screen , I have disabled auto restart and got bluescreen error 0x00000050 caused by file scsiport.sys. I have tried booting in safe mode but which ever option I do same happens, I have tried going into the bios and changing to boot from disc by inserting a. New windows disc but I only have a copy of the professional version. It accepts the disk and starts to install files for a couple of minutes then it goes to another bluescreen stop code 0x000000d1. Acpi.sys. Driver irql not less than equal, we don't have any back updisks for this laptop it was a hand me down, but I would really like to get it going again for my neice as I just don't jave the cash to get her a new one , any advise would be greatly appreciated
kape2
  • 4 Answers
SOURCE: toshiba a8/420cme
Did you try restarting in safe mode F8 ?
It should then lead you to operate normally.
Posted on Sep 20, 2009
rohithn
  • 57 Answers
SOURCE: Let me tell the problem in details:
How did you try to do the fresh install? Using a bootable CD? Make sure you format the windows partition before installing.
Posted on Feb 16, 2010
andcal
  • 182 Answers
SOURCE: i have a hp compaq
The blue screen is called a blue screen of death (abbreviated BS or BSOD), and is a notorious phenomenon when using Windows.It can mean that a key piece of hardware (memory or hard drive) is failing on your computer, or it can mean that one of the drivers (piece of software) that allows a piece of your hardware to work has a bug, or is corrupted.If you just installed a new piece of hardware, then physically unplug that hardware and try again.If one of the options you are presented with is "last known good configuration," then make sure you try that option.If that doesn't help, you can try removing hardware one piece at a time, and try booting the computer in between each removal. There is probably a screw on the bottom of the laptop will allow you to remove the optical drive. If the computer still does a BSOD with the optical drive removed, then it is not causing the problem, so go ahead & put it back. If the memory is installed in 2 separate sticks, you can try booting with first just one, and then just the other (this tests to see if one of the sticks of memory is failing). If one of the memory sticks is bad, you can buy a new one at www.crucial.com. It shouldn't cost much on a laptop this old.Apparently, there is something called a USB Digital Drive on the left-hand side of this computer, but there may just be a floppy drive there. See if you can figure out how to remove this. If it is causing the BSOD, your computer may start after removing it. If no difference, put it back.
If none of that works, it could easily be your hard drive. As old as this computer is, one would expect the hard drive to fail at any time. If you still have the Windows installation disks, you can buy a new hard drive for less than $50, and reinstall windows. You are going to need a 2.5" IDE ATA hard drive (not SATA) anything that is 2.5 IDE ATA, larger than 10 GB, and not SATA should work. If you reinstall windows and it still does a BSOD, then the problem is caused by a piece of hardware that is not removable, which means get a new computer.
Posted on May 08, 2011
  • 3940 Answers
SOURCE: Dell Latitude 810 will not
Boot to the WIndows XP CD (Press spacebar when prompted to press any key) at first prompt in setup, press R to enter recover console.
At the C:\Windows\System32\> prompt type bootcfg /rebuild then press enter
http://support.microsoft.com/kb/330184
reboot see if error resolved.
If not then try running diagnostics by pressing Fn plus power button, see if there is a HDD malfunction
Posted on Jul 17, 2011
  • 6771 Answers
SOURCE: Toshiba stuck on start-up screen.
The windows files have been corrupted, I was hoping you might get into safe mode to try a system restore but your system will not allow it. If you can find your recovery disc a clean install is the best way to go. Try www.toshiba.com contact customer support about a replacement recovery disc.
Posted on Jul 21, 2012
Windows won't start with safe mode (windows7 i meant)
Do you have the Restoration/Restore Disk?
If so pop it in the optical drive (CD/DVD drive), and when asked choose Repair.
(Non-Destructive Installation)
Post back in a Comment.
Regards,
joecoolvette
Apr 13, 2013 | Dell Latitude D520 Battery PC Notebook
Download a new safemode for dell. my safemode wouldn't work too.
I have an HP notebook. I was on Skype with a friend when suddenly it froze showing green colors on the screen. Nothing would un freeze it so I opted to turn it off through the power button. ...
Step 1:
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer also Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
Feb 11, 2013 | Computers & Internet
I had to launch start up repair and the battery died half way through... The laptop now says "Computer build error. File exception failed to find c:/ (etc)" and it won't turn on, just...
Step 1:
Enable VGA mode
Reboot
Feb 07, 2013 | Computers & Internet
My computer screen turns blue and restarts window vista
Hi jjlishus,
I see you mentioned that you are having issues with you computer going into a blue screen then it restarts.
You can try to boot into safe mode to see if Windows Vista will Load without having the bluescreen and if it will not shut down or restart, from Safe Mode, try and do a system restore to a data where the problem has not happened yet.
From there-on see if the issue will still happen or no
Getting into Safemode:
restart PC keep on tapping F8 on your Keyboard this will prompt you options, Look for Safemode then press enter this should bring up the safemode screen.
If during the loading of safemode and still happens are any error show up or it goes to a blue screen, you can try going into safemode with command prompt.
to get to safemode in command prompt just do the same as ging into safemode and select safemode in command prompt.
once in the command prompt
Type CHKDSK , then press enter it should check the system for 5 mins or so depending on your PC/Laptops speed.
if still the issue is the same reformatting or restoring your windows back to defaults may fix the issue.
I hope that this will help,
mvincentc
Jun 07, 2012 | Acer Brand 14.1 WXGA Matte Laptop...
My HP Pavillion dv7 3112sa won't boot and remains
Hi, at startup try pressing f8, this should give you a menu, select 'start windows with last good configuration', this should restore windows to the state before it started rebooting randomly. Failing that...try starting in 'safemode with command prompt' and then do a 'system restore'- press f8 again at start up and then follow the instructions below. this should restore your system to a previous state when the computer wasn't doing random things.
  1. Restart your computer, and then press and hold F8 during the initial startup to start your computer in safe mode with a Command prompt.
  2. Use the arrow keys to select the Safe mode with a Command prompt option.
  3. If you are prompted to select an operating system, use the arrow keys to select the appropriate operating system for your computer, and then press ENTER.
  4. Log on as an administrator or with an account that has administrator credentials.
  5. At the command prompt, type %systemroot%\system32\restore\rstrui.exe, and then press ENTER.
  6. Follow the instructions that appear on the screen to restore your computer to a functional state.
I hope that this helps you to sort out the problem. Toni
May 27, 2012 | HP Computers & Internet
When the computer boots, it display bluescreen
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.If after running the Check Disk Utility you still have problems you will probably need to reinstall windows. Look into doing a Repair Install so that you don't lose your data.
Apr 24, 2012 | HEWLETT-PACKARD 630 Notebook
Igxprd32 error
Apr 13, 2012 | Computers & Internet
Can't download CD to laptop
try this:
reboot in Safe Mode:
- Click Start - Run, type command , and then press ENTER.
- At the command prompt, type cd \ and press ENTER so that you are at the C:\> prompt.
- Now type cd windows\system and press ENTER so that you are now at C:\Windows\System>
- At the command prompt, type msiexec /unregister , and then press ENTER.
- At the command prompt, type msiexec /regserver, and then press ENTER.
EXIT
Mar 06, 2012 | Computers & Internet
My hp mini 1000 wont boot up. when i turn it on it goes right to a screen that asks how i want to start up windows ( safe mode, safe mode with networking, safe mode with command prompts, and start windows...
hi blinkgirl556
was there a new hardware that was added to your laptop? bluescreens often are caused by hardware.
while the laptop is booting up when you are asked for options on how to start you computer is there an option for start windows using last known configuration? if there is try that and if it still goes into bluescreen you may want to try and recover your laptop using the hp recovery cd or recovery tool. if it still doesn't work most likely you have a bad memory chip.
hope this helps
contact me for any updates
janc30
Feb 08, 2011 | HP Mini 1000 Netbook
Open Questions:
Computers & Internet Logo
David Payne
David Payne
