Question about Kenmore Elite 45986 Front Load Washer
Elite 73952 will not start
The dryer is 8 yrs old has recently been shuting off until it cools down then it will restart. last night wife went to dry,and will not start, makes loud buzzing noise only.
  • 70 Answers
Sounds like it is the motor, open the door and press the door switch in ,have another person push the start button,and you tunr one of the drun fins. IF itstarts, you need a motor
Posted on Mar 12, 2009
Bosch tumble dryer
Try holding down the start button for 10 sec's to reset it.
Jan 15, 2014 | Dryers
My electric dryer starts then shuts down after 5 seconds
Centrifugal start switch, built into motor, may not be releasing when motor comes up to speed. A little light oil on sliding part of switch might help.
Dec 13, 2013 | Kenmore 73952 Gas Dryer
Last night my wife was using the washer and when the washer went into the spin cycle it sounded like the washer was chugging. The drum was turning but not at full capability. the washer is a Kenmore...
I had a Kenmore washer that had a somewhat similar problem. It had a rubber sprocket that had started to deteriorate that caused my drum to stop spinning. I'm not sure if your is the same but you might try pulling the back panel and see how the drum is driven. I am guessing the sprocket or belt has started to wear out.
Jan 27, 2011 | Kenmore Washing Machines
Shuts off before clothes are dry, will restart and shut off again
Most likely, the operating thermostat has failed. When the dryer heats up, it gets too hot and the high limit thermostat turns the machine off. After it cools down, it will start again.
Unplug the machine! Check the thermostats for continuity with a multimeter. All thermostats should have continuity at room temperature.
Apr 27, 2010 | Kenmore 73952 Gas Dryer
Dryer stops mid cycle-restarts when cooled down--is it some sensor?
Good day,
Yes it's a sensor, but if you have to restart it manually after the cool down period, it is the sensor built into the motor.
That sensor measures motor temperature and current draw. It locks out the motor until it reaches normal temperature.
If it restarts on it's own, then post back with the complete model number. It would be a different problem.
Mar 09, 2010 | Kenmore Dryers
Dryer won't start until it cools down
motor bearings are going out. What happens is in the motor there is a thermal overload switch. This switch activates when the motor gets too hot to prevent fires. That is why you always see the "thermally protected" sticker on the electric motors. If the bearing are going bad or possibly windings in the motor the switch kicks in and will not restart until the temp. of the motor cools to a certain level. Take the model and serial # to an appliance parts supply for replacement of the motor.
Hope this has helped you
Dave
Jan 18, 2010 | Kenmore 73952 Gas Dryer
No heat from dryer
i believe a while back, this model had a timer issue, but would need exact model to be sure,
anyway its a pretty asy repair and the part is easily available at
appliancepartspros.com
the average timer is around 80
and about ten minutes repair
Oct 15, 2009 | Kenmore 73952 Gas Dryer
Have-kenmor-80-series-dryer-about-5-yrs-old-losess-flam-about-6-min-into-cycle attemps to relight no flam.
replace coil kit no 279834.coils will be found on top of burner, unplug wires, 2 screws remove bracket,easy fix part~ $20 .Hope this helps ,please rate my solution :)
420.. 20 min fix .hope thuis
Jun 27, 2009 | Kenmore 73952 Gas Dryer
My Kenmore Elite dryer spins with no heat
please check the thermal cutoff. these are the parts with 2 thick wires attached to it. they are normally located near the heating element ( if electrical ) and (near the exhaust if it is gas).
these parts control the heating element.
tnx 4 using fixya,
drcool
Nov 05, 2008 | Kenmore 73952 Gas Dryer
Kenmore Elite 45986 Front Load Washer Logo
144 people viewed this question
Sal De
fordexpert
Robert Rankin
