Question about Jandy Pool & Spa
Need to cancel filter programs
There are seven different filter pump programs. How do I delete some?
    Top Expert:
  • Jandy Master
  • 8,502 Answers
Go into the system set up and go to programs then delete or edit
Posted on Mar 05, 2016
I need to re program my pump filter timing
go to program highlight filter pump open program then cancel
Sep 02, 2014 | Pool & Spa
How do I cancel filter programs
go to system setup go to program if there is a program it will let you edit or delete
Apr 02, 2014 | Jandy Aqualink Rs4 One Touch Control...
I want to know how to cancel a program on an AquaLink RS8
go into system setup find program then delete the one you dont want if using a all button just press cancel
Jul 15, 2012 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
I have an aqua link rs4 and it has 4 programs for the pool pump I need to cancel three and can't figure out how
I just tried this and had luck.
Press the "Cancel" button, first.
Then, press "Programs".
Then, select "Pool Pump".
At this point it will tell you you have 4 programs. I "think" if you hit "Enter", it will offer you "Cancel All" or "Cancel Some". From here, you're on your own!
I would "Cancel All", then just add back the one program. Seems cleaner that way, but ... that's just me.
Jan 04, 2011 | Jandy Aqualink Rs4 One Touch Control...
How do I delete program times for the filter pump on the Aqualink rs8 panel?
These are great systems: Go into "MENU" (MENU BUTTON) Scroll down until you see "MENU/HELP" Scroll down to "PROGRAMS" - HIT "SELECT" when you find "PROGRAMS" It will say "PROGRAM 1 of 1" that is what you want - Hit enter - This will tell you what time the program is set to run
If there is more than one program, You will see "PROGRAM 1 of 2" or however many programs you have programmed.
If you need to delete a program, go to the program you are looking to delete, it will ask you if you wish to delete the program and you will use the up and down arrow on the panel.
It is really that simpe!
For deletion of all programs (factory default). There is a SMALL reset button. The lights will go out and then light up. Will light up to the left and then to the right. Resetting this will erase all run times back to factory default. You will not loose your programs (memory of knowing what system it is) it just resets the times to factory default (1200 Military times). ***IF YOU HAVE A COMPLICATED PLUMBING SYSTEM WITH SEVERAL RUN TIMES - DO NOT DO THIS!**
If you are looking to just erase additional run times and only need the one run time (for circulation) this might be the better option to resetting and erase all run times and reset back to a basic 1 of 1 run time.
Dec 07, 2010 | Jandy Pool & Spa
How do you reset the programs? Unit is saying
You need to hit the menu button and go into program. In there you will see each item, such as the filter that is on a schedule. When you hit the filter, it will have 3 options, add, remove, or change. Just hilight the schedule and hit remove, that program will be deleted.
May 15, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
When the filter pump comes on, the cleaner booster
check the programs or better cancel all the programs and restar from the begining if still after this the spa side switch need to be replace
Sep 11, 2009 | Jandy AquaLink RS2/6 All Button Dual...
When I cancel the printer does not print other items that have been scanned. it gets hung up.
when you print an article on-line. it goes into your printers memory. 10 pages for instance. if you cancel after 5 pages. the printers RAM ( memory ) stores the remaining pages to be printed. the only way to do this, is to cancel printing. then go into printer program. and delete the queue, or pending items, before exiting windows.
hope this explains your dillema.
mike @ Compurepair.
Feb 20, 2008 | HP DeskJet F380 All-In-One Printer
What is the Digital Effects Control (DEC)?
With this function, you can adjust exposure, contrast, and saturation through the viewfinder itself, prior to image capture. You can check how your adjustments will look using either the viewfinder or the LCD monitor. This feature makes it easy to get the unique images you want in many different shooting situations. DiMAGE 7i is capable of setting contrast, color saturation and filter in the following increments. Contrast: In seven levels from -3 to +3 Color Saturation: In seven levels from -3 to +3 Filter: In seven levels ranging from warm (reddish) to cool (bluish) colors.
Sep 15, 2005 | Konica Minolta DiMAGE 7i Digital Camera
Pool & Spa Logo
57 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
