Question about Hotpoint FFM70 Bottom Freezer Refrigerator
Fridge Smell I have a hotpoint fridge freezer frost free. But the freezer back wall iced up. I have defrosted this, my fridge has a bad fishy smell was wondering if any way to get rid of this or need new fridge. No smell when the thing was unplugged.
    New Friend:
I have a whirlpool fridgefreezer and their is a very bad smell comming from the back of it what can it be
Posted on Aug 01, 2011
    Novelist:
  • 135 Answers
Wash it out with bleach. Nearly always solves this problem.
Posted on Aug 02, 2007
I have a hotpoint fridge/freezer ,there is a strong fishy smell coming from fridge cleaned all inside not solved the problem, Model FF7190 EP,CAN ANYBOBY HELP.
Posted on Feb 24, 2013
  • derek pepper
    derek pepper Feb 24, 2013
SOURCE:
I have a dometic rv fridge, the freezer works not the fridge
you have to send the brand name and model number so i can help you.all that happens is the evapcoil in the freezer gets cold,the evap fan motor blows cold air from the freezer into the fridge side,depending on your model you could have a bad damper,this is a door that is in the fridge section,it opens and closes letting the air come in,try this,open the freezer door,if you don't hear the fan blowing you could have a bad fan motor,also touch your hand on the back inside wall of the freezer,if you have frost or like ice on the back wall you have a defrost problem,ice is biulding up on the coil and the fan can't blow the air over to the other side..if you need more help,do these tests and send the model number off of the machine and brand name,side by side or freezer on bottom,open the fridge door,look up on right hand side wall near ceiling or on ceiling,freezer on top look on left side in fridge section.
Jul 12, 2012 | Dometic Refrigerators
My Kenmore Refrigerator is not refrigerating
if the freezer and fridge are warm check the start device on the compressor,alot of times you can smell a burning oder when this pops,also you can remove it and shake it,if you hear pieces rattling around then it's bad,also if there's ice on the back inside wall of the freezer then you have a defrost problem,also when you open the freezer door do you hear the fan blowing,if not you could have a bad defrost fan motor,open the fridge door,up near the ceiling on the right side you'll see the model number,send it to me,let me know if you found ice or frost on the back wall of the freezer or what you see and i'll be glad to help you
Oct 31, 2010 | Kenmore 53642 / 53644 Side by Side...
Fridge Icing Up
Sounds like you have a defrost Prob. Take back cover off. Turn defrost timer in to defrost mode you will feel a click. timer may be located in fridge. ceiling or back wall if not there check bottom of fridge. behind kick plate or in back bottom of fridge. by compressor. See if heating element gets hot if not check for 120 volts at heater and defrost thermostat ( Terminator ) if not check defrost timer if you do have 120 volts check for 120 volts at heater terminals if no voltage or weak voltage replace terminator if you do have good voltage replace heating element. When ice builds up the fridge. starts to get warm turn off for 24hrs turn back on fridge. will run OK till ice builds back up.
May 22, 2010 | Refrigerators
Fridge/freezer cooling inefficiently
Either the repair guy did not wire up the heater correctly or he replaced the wrong part, if the heater was good it was likley to be the defrost thermostat...I would call the repair guy back to check.
Jun 23, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Freezer not blowing air - bad smell in fridge
Your automatic defroster coil is open and needs to be replaced along with the fan in the freezer that blows the cold air around and also blows air into refrigerator.
Bad smell down below is food rotting in that section because it is not cold enough.
Mar 22, 2017 | Hotpoint  21.8 Cu. Ft. Top-Freezer...
Bad smell coming from fridge
Unplug fridge. Remove the panel on the back of the fridge look for dead rodents or fungal growth in the drain pan. consult your local appliance parts distributor for a product called kleene air or try www.reliableparts.com
Apr 01, 2009 | Refrigerators
Frisdge/freezer and ice smell
I had a side by side refrigerator with an Ice maker from Sears. The ice it makes smell fishy so bad that I could not use to drink with anything else but throw away to the plants. So I unscrewed the ice maker . It is not that bad, but quite simple to take it out. I noticed rusted pieces of metal generating strong fishy smell. I could not get rid of rust with soap, detergent, oil so I wrap it in plastic bag then screw it back into the refrigerator. Screwing back the ice maker. Voila. The smell is going away. The ice is good. Pina Colada and Daiquiri here we go .
Jan 24, 2009 | Jenn-Air JBL2086HES Bottom Freezer...
Fridge not holding tempreture
if there is frost present on the rear vertical wall of the freezer compartment then the defrost function is broken and needs to be repaired the freezer is like an ice block and yo get cooling up to the refridgerator compartment air has to be able to flow and that can't happen if the frost is not eliminated
Dec 15, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint rfa18 Fridge Freezer
Is the back wall full of frost? If so you have a defrost problem, most likely the defrost is stuck in the run mode. this is located above the controls area in the fridge.
Nov 14, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Ice and Refrigerator and Freezer smell like alcohol chemical
I believe that you might have a coolant leak causing the chemical odor. You really should get it checked out by a fridge repair-person because it's not healthy to breathe in the fumes.
May 21, 2008 | Hotpoint HSS25GFP Side by Side...
Hotpoint FFM70 Bottom Freezer Refrigerator Logo
1,962 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
jasbo
jasbo
Steve Allison
Steve Allison
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
