Question about Intex Pool & Spa
Is there an o ring for the filter top?
The pump is leaking water out of the top of the pump with the filter in it. Should there be an O-ring in the top?
jgwhomeequip
  • 1902 Answers
SOURCE: I cannot get the pump to pump water, motor still works.
Sounds like air has gotten into the pump and froze the pump. It will need to be replaced due to that reason. You can get a repair kit for the pump but it will not be gaurenteed to work
Posted on Jun 02, 2009
  • 93 Answers
SOURCE: O-ring came out with filter basket and need help putting it back
it fits around clear basket cover put all the way up hope it helps
Posted on Jul 08, 2009
jharwell668
  • 640 Answers
SOURCE: My model 603 filter pump leaks at the top under cap
It could be the o-ring on this model. There is a seal on these pool filters that looks like a rubber ring inside the lid. You might need to replace this ring if your pump is leaking here.
Posted on Sep 08, 2010
kel1guy2002
  • 3740 Answers
SOURCE: After priming my filter, the
Somewhere in your connections you have an air leak on the suction side. That is the sole reason that you have air bubbles in the strainer. If you have a leak on the suction side the only way you will see it is by adding water to the strainer basket and then checking for wet spots on the suction line. There can be a break a long way from the pump in the ground that you can not see.
Another way of troubleshooting is to remove the pump output line and install a cap with an air valve stem then block the suction line with an expandable plug. Then add regluated air at 10 PSI or less to the air valve and listen for a hiss in the line or the sound of water gurgle / bubble underground. I hate to say add any kind of dye (food coloring) but by doing so the leak would be visble. Problem with doing that is it would get introduced into your water once repairs were complete unless you have a way of bypassing the output overboard. If you can overboard the food coloring by all means add it to the filter basket with a full load of water. You will find the leak.
I suspect you have a leak near your recent pump replacement. However...... this thought comes to mind. Did the old pump fail from losing prime? If it did... you must find the leak in the suction line.
Your on the right track with noting the bubbles in the strainer box. You have little choice but to locate the source of the suction leak. You will not see a leak during pump operation because it would be drawing air and water under a vacuum. The only way to find the leak is to pressurize the line as I stated above. Cap the output line, install a way to use compressed air and then add air at low pressure listening for the leak. The drain / suction source must also be blocked with an expandable plug!
Thanks for choosing FixYa,
Kelly
Posted on May 10, 2011
briones93
  • 119 Answers
SOURCE: Water leaks out the top of the filter housing. I
Here's the diagram for the 635T.. The o-ring for the top valve should be part number 10264- #3...small o-ring. The housing cover is the bigger o-ring 10325 #5.. Hope this helps you...
Posted on Aug 12, 2011
What else can cause this leak
there is a plunger inside them takes o rings too
May 02, 2015 | Refrigerators
Leaking canister
remove the O ring and clean it as well as the top and bottom housing. use an approved lube to treat the O ring (not vaseline). while applying lube, look for checks or cracks in the O ring. it doesnt take much for a leak.
when you are putting unit together, make sure the air release valve is open
Apr 21, 2014 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
Water squirts out of where you tighten top to filer holder
If I understand you correctly, water is leaking out of where the two halves connect? I will assume, this filter has some age to it and the housing may show signs of warpage. A quick fix is to use grease to help the o-ring to seal. Liberally apply grease all the way around the o-ring and then try sealing the housing.
Apr 07, 2013 | Hayward Star Clear Plus 90 sq.ft....
Water leaks out the top of the filter housing. I ordered "o" ring 10266 (filter housing "o" ring) and it is too larger. Where can I find a schematic with part numbers.
Aug 11, 2011 | Intex Krystal Clear Model 635 Pool Filter...
I'm hearing air like sounds around the multiport valve. There's bubbles visible in the filter going to the pump. Bled the air on the filter itself and bubbles continues. Could the multi port...
Air only gets into the lines of your equipment if it enters somewhere on the suction side of the system. That means from the pump housing and strainer BACK to the pool on the inlets. Once the water passes from the impeller out the discharge of the pump it is under pressure and any leaks will result in water escaping from the line.
While your filter may or may not need work air is likely the result of failing gaskets or a seal in the pump. Replace the strainer lid ring, the pump body ring and the mechanical seal first. If there is still air look at the valve or valves in front of the pump for controlling inlet water flow...check for leaking stems or failing pipe joints.
John
Jul 21, 2011 | Pentair Kreepy Krauly Inground Automatic...
Leaking after installing a new top mount multiport valve SP0714T
There should be a rubber "O" ring in there. Check for that
Jun 11, 2010 | Hayward SAND FILTER, PRO SERIES
Apr 30, 2010 | Intex 2500 Gal Easy Set Swimming Pool...
Water surging back to pool when shut off
sounds like you have air built up inside the filter when the pump shuts off. the most likely cause is a suction side air leak, bad lid o-ring or union o-ring or maybe even the threaded fitting going into the pump. When you turn the pump off, you may be able to see water squirting out wherever the leak is. Once you find/fix the suction side leak the filter should stay filled with water and not surge backwards when the pump turns off. Make sure you keep the filter clean as well.
Apr 22, 2010 | Hayward SAND FILTER, PRO SERIES
All o-ring attachments to filter leak
My neighbor had this trouble also she was trying to put the o ring in the grove of the top it does not go there it just sits on the unit and the top screws down
Dec 08, 2008 | Intex 2500 Gal Easy Set Swimming Pool...
Pool & Spa Logo
11 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
