My remote control for my samsung ps42c450b1 tv has stopped working, changed batteries but still nothing. Any ideas???
    Top Expert:
  • Televison & ... Master
  • 75,311 Answers
If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter
Posted on Apr 21, 2013
SOURCE: Proline tv remote control code.
try 0067 0568 0655 0664 0321 0102 0651 1406
good luck
Posted on Jan 03, 2008
SOURCE: Innovage Jumbo Universal Remote Control
If you don't have the code do this! I worked for me.... Hold code search until light stays on... then select item to program <tv, vcr, dvd,exct..>... then press power button once... It will blink every couple of seconds and run thru the codes it self..... wait for the item choosen to turn off.... Then quickly press enter... TADA PROGRAMED!!!!! continue for each item to be programed. Be patient there are up to 500 codes! Can take Up to 10 min, But better than wasting $10.00$ good luck
Posted on Aug 04, 2008
  • 43 Answers
SOURCE: I have a Bose remote control RC18S2-27 that
Check your settings on the receiver , it might be off.
Posted on Aug 18, 2009
SOURCE: The Sony TV remote doesn't work (with good batteries).
NSE urc22b-12 please pin code forTV SONY model KV-A2921D
Posted on Sep 28, 2009
  • 1335 Answers
SOURCE: my samsung remote BN59-00852A just stopped
Try the instructions below. If you need to replace the remote, you can order one from:
http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=BN59-00852A&uuid=12967730823440
Before replacing the remote, try the following:
How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote. If you do then the problem might not be the remote but the sensor on the TV unit.
Let me know if you have further questions. Please make sure to rate this solution. Thanks.
Posted on Feb 03, 2011
Samsung LE32C450E1W TV remote control stopped working, changed batteries no luck, turned off at power source for 30 min which fixed prob temp but has happened again and now turn off doesn&#39;t help....
Check the remote control for its infrared emission. Check it with fresh batteries. Clean the battery contacts inside its battery compartment. If these do not help you, you remote control need cleaning. If you wish to know more about how to clean and repair a remote control check this site. Pull up older posts. One among it has details.
Mar 24, 2013 | Samsung TV Remote Control
My remote control just stopped working to control the volume or channels. Changed batteries...what else can I do?
make sure nothing is damaged on the remote. after doing so unplug you're tv. when the tv is turned back use the remote close to the tv and use the remote. make sure the sensor on the tv is not blocked by anything (movies,books anything). if it still isn't working consider buying a replacement
Feb 28, 2011 | Samsung TV Remote Control
Samsung remote control - UE40B8000XWXXU
This is odd.. I have a UN model, the 6000 actually and all remotes have stopped having any effect on the Television, even the units original remote. I can access every other device except the TV, it's as if the RF sensor on the TV has failed to function anymore. Let me know if you found a solution to this problem!
Dec 11, 2009 | Samsung Televison & Video
Samsung HT-Q100 - Changed Battery on TV remote control
Just try to clean your remote,this the common problem of dirty contacts of remote it plays a certain unit but to the other won't play.Just open it take a toothbrush with an alcohol brush the remote control board,and dry it for 1minute and close it back then check if working..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 17, 2008 | Samsung HT-Q100 System
Toshiba TV Remote Control not working
i have bought universal remote controls and they do not work. what can i do? i have bought rca universal philips universal remote,
Nov 17, 2007 | Toshiba 36HFX71 36" TV
Samsung TV remote control
I HAVE THE SOLUTION TO THIS PROBLEM.
Confirmed with Samsung tech support. Problem is with remote. to fix, simple take the batteries out of the remote. Press and hold the UP Volume button for 2 Mintues (no cheating, it has to be at least 2 minutes), this Reset's the Remote Control. Put the batteries back in. Bob's your uncle. all fixed.
Sep 28, 2007 | Samsung TV Remote Control
Controls not working on Philips 28" TV
We had this problem with a 28PW6515. The control would work for 30 seconds after switching on, then nothing. It was diagnosed as the "glue chip" which handles all the control functions. About £200 to fix it as it's a surface mount chip.
Sep 19, 2006 | Philips 28PW6506 28" TV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
