Question about Garden
Where is the fuse on a Husqvarna model YTH1542XP riding mower
Did you ever find the fuse? I have looked at the diagram & tried to locate w/no success
Posted on Jul 03, 2013
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
panilling9
  • 284 Answers
SOURCE: what kind of oil for a husqvarna riding mower?
Yes Briggs and Stratton recommends sae 30 in most all their engines even overhead valve (OHV)
Kohler uses 10w-30 in most of their overhead valve engines
Briggs has their own bottled oil with their label and additives and can find at lowes
Kohler the same
Posted on Jun 14, 2009
  • 95 Answers
SOURCE: Husqvarna Mdl YTH2448 Riding Mower - Electric PTO Not Working
It sounds like your charge system is not working. If you jump the battery the engine will run with a weak battery but the pto clutch needs a strong battery to stay engaged.Try this to test it,after you jump it leav the jumper cables hooked up and try to engage the blade clutch,if it runs it is either a battery that wont take a charge or a charge system not working. If you put a volt meter on the battery while the engine is running and the voltage is 13 volts the charge system is working and the battery is bad.
Posted on Jul 31, 2009
  • 9 Answers
SOURCE: 2007 Husqvarna Riding mower blade will not engage
Sounds like you electric blade clutch is bad. I just had the same thing happen to my exmark mower. I was cutting grass and the engine just shut down. It would not crank over. Checked the fuses and replaced one blown fuse. The engine wanted to crank over but it was locked up. I looked the engine over and seen that the bearing in the electric clutch seized up causing the clutch to melt.
Posted on Apr 25, 2010
Testimonial: "Thank you! That doesn't sound like an inexpensive solution. We appreciate your help, though."
SOURCE: Blades will not engage on Husqvarna riding mower.
I have a Husqvarna GTH2548 and the blades will not engage. It is free from all debrie
Posted on Sep 04, 2010
Mower shuts off after running about 5 minutes. i blew thru gas line towards tank and seemed like there was resistance tnen it opened up. ran another 5 minutes and same thing happened . model is husqvarna...
Check the fuel tank cap. It needs to let air into the tank and has a small hole to enable this. Try running the engine with the cap loosely in place to verify this is the cause. If you can't clean it get a new one.
Jul 01, 2014 | Husqvarna Lawn Tractor - 54in. Deck, 26...
What type of oil do you use in a Husqvarna YTH1542XP trans-axle ... and , how much ?
For the trans-axle use 2 quarts and use 10w-30 any brand that you would like, be careful when unscrewing the cap you do not want hot oil over you.
Thanks.
Jul 20, 2011 | Husqvarna Garden
Yth1542xp take the deck off to clean
See page 19 and a very good diagram for this procedure in Figure 16 to do this. This is your owners manual. You will need Adobe Reader installed on your computer to view it. It is a free download if you don't already have it.
http://www.husqvarna.com/ddoc/HUSO/HUSO2003_USen/HUSO2003_USen_O0302029_.pdf
Jul 03, 2011 | Husqvarna Garden
The mower starts but the blade switch won't conect yth1542xp
Husqvarna uses an electronic clutch to engage the mower deck. When the clutch works itself out of adjustment it will quit working. Sometimes it will blow the 20 fuse and the tractor will continue to run, but the blade won't engage. When you then shut off the tractor it won't crank again until you replace the fuse. When you attempt to engage the blades again, the fuse will blow again.
Follow this link for a detailed description of the adjustment process:
http://www.lawnsite.com/showthread.php?t=164509&highlight=clutch+adjustment
Nick
Apr 22, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I have a yth1542xp when i run it for 30-40 min. it starts to move slower and when up an incline it will stop and start moaning. anybody with a fix out there.
It sounds like the hydro static drive in the rear of the mower is over heating. Remove the battery and carrier tray under the battery and check that the cooling fan and hydro static drive are free of grass etc. Regards Phil
Apr 14, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I have a Husqvarna Lawn Mower YTH1542XP. when it is in gear to move, i have to use my foot to hold the pedal back for it to go. if i don't hold the pedal back, it barely moves. any suggestions are...
It sounds like the transmission drive belt is slipping. When you pull the pedal back you are increasing the tension on the belt. You may also want to make sure the spring that pulls tension on the idler pulley is in tact. Hope this gets you in the right direction.
Feb 23, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Blowing fuses
try unplugging the pto, starting the mower and then engaging the blades. If it still blows a fuse the problem lies in the mowers wiring. If not the problem is the pto. Hope this helps
Jul 13, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
169 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
