Question about Garden
My Craftsman 247.25000 rear engine riding mower does not start
I have checked that all the levers are in the right positions. There is only a faint click when I turn on the ignition. Nothing happens when I turn the key to "start"
  • 203 Answers
SOURCE: Sears Craftsman riding lawn mower will not turn over
http://www.mytractorforum.com/showthread.php?t=129440&highlight=starter+click
Posted on May 23, 2010
SOURCE: Where is the fuse for Craftsman 17.5 HP 42 Riding Mower
I'm not sure the solenoid/relay would even energize at 10 volts (so you may not hear the clidking).
The battery is essentially dead at 10 volts -- try charging again for 4 hours or so, and then measure the voltage.
If it's not up near 12 volts, you have a dead cell and need a new battery.
Posted on May 03, 2009
mowerman1857
  • 389 Answers
SOURCE: craftsman 19.5 42' deck will not start.when i turn
Check both battery terminal bolts for good, clean, tight connection. Also locate the fuse just behind the engine on the right side of the mower and see if it may have blown
Posted on Sep 17, 2009
nova2nv
  • 197 Answers
SOURCE: my riding mower won't start. It's a Craftsman
Check your seat switch and brake switch for loose wires.Most likely brake switch do to no spark at plugs,see if PTO switch/lever isnt on.
Posted on Nov 22, 2009
SOURCE: rally ride on lawn mower not starting. briggs and
i have a rally lawn tractor when i hook up the battery it wants to start key is off only thing i did was change the belt. was working fine before .
Posted on Jul 29, 2010
Craftsman riding mower back wheels not rolling, seem locked up, engine won't start. Clutch and levers still move freely. Was running fine last use. Not sure what is causing this
Grass always gets caught in mowers. THis may help.
Turn mower off, detach battery.
Turn mower on side.
Clean grass everywhere you can clean grass.
Right side mower.
Attach battery.
Start.
Does that help?
Jun 28, 2017 | Craftsman Garden
How to start a Craftsman 20 hp riding mower?
Your question is mighty broad, but I would start at the battery, making sure you have a fully charged battery. Sit in the seat and push the brake pedal down. Make sure the blade engagement clutch is off or the lever to move the deck up and down is in the up position. Unless a safety switch is defective, the mower should start. If you just hear a click, you have a dead battery or loose wire. Until you get more specific, this is the best I can do.
Jul 20, 2014 | Craftsman 20 hp 42 in. Deck Yard Tractor
Front wheels on manual mower lock when pushing for awhile.
1 Locate the height adjustment lever on the inside of the left rear wheel.
2 Kneel next to the mower and push the left height adjustment lever toward the center of the mower. This will unlock the lever from the locking pin on which the height is currently set.
Read more: How do I Adjust the Height on a Great States Reel Mower? ' eHow.com http://www.ehow.com/how_6834215_do-great-states-reel-mower_.html#ixzz21NOr1e8d
3Rotate the lever toward the front of the mower to lower the height of cut, or toward the rear of the mower to raise the height of cut.
4 Release the lever over the locking pin closest to the desired height of cut.
5 Repeat these steps with the adjustment lever on the right-side rear wheel. Be sure to set the right wheel lever to the same position as the left-side wheel's lever for an even cut.
Jul 22, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Removed mower deck with no problems. Cannot re-attach. Do you have a step by step instruction for this process?
1. Raise attatchment lift lever to its highest position
2. Slide the mower deck under the tractor with deflector shield (grass Chute) to right side of tractor
3. Lower lift lever to its lowest position
4.. Connect the front links to the mower deck and secure with the retainer springs.
5. Connect thye suspension arms to the rear deck brackets and secure with their retainer springs.
6. Connect the anti-sway bar to the chassis bracket and secure with the retainer spring.
7. Push the clutch cable housing guide into the bracket, and slide the collar onto the guide and
secure it with the large retainer spring.
8. Place the flat washer and clutch spring on the idler pulley bolt and secure them with the small
retainer spring.
9. Re-install the blade belt onto the engine pulley it goes on.
Apr 23, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 17 HP 42" craftsman mower. When I disengage the blade lever, the blades do not fully disengage until I slow down the engine with the throttle lever. This has only begun recently. The tractor...
There are blade brakes, one on each blade pulley. You will need to check that the brakes are in good working order and that the springs holding them against the pulleys are in place. Also there is a spring to return the idler pulley to the neutral position. The spring could be broken or the idler pivot rusted not allowing it to return to fully neutral position. This should get you going down the right track. Hope this helps; please vote yes. Thank you.
Nov 21, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My riding mower won't start. It's a Craftsman
Nov 22, 2009 | Craftsman Garden
Craftsman mower with 18.5 hp Intek Will run wide open only, regardless of throttle position. Linkage appears to be okay. Stuck float? What about the bowl electric solenoid valve?
check the lever biside the mower that connects to your carb. move it by hand while running if no change the governor has broke,, need to take engine off and replace, but if you move it and it slow down change spring
Aug 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 15.5hp 42'' changed hydrostatic fluid with mobile 1 synthetic 15w50 and now the wheels will not rotate at all. Checked everything belts on right pulley turning on top of tranny, disengage for...
Purge the transaxle by pulling the freewheel lever at the back of the transaxle.With the lever in the freewheel position run the engine full speed with clutch out,work the forward/reverse control back and forth 10 times and then try it.Also make sure that if you had the wheels of that you didn't lose a wheel key.
Aug 15, 2009 | Craftsman Garden
Craftsman zts 7500 will not run with levers engaged
Cody,
Yes, I am sitting when I do engage the blades on my craftsman zts 7500. All you do is pull/push the engaged button to your left well you are seated.
Apr 05, 2009 | Craftsman Garden
Garden Logo
471 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
